Condi's HACKMODE v2.2 - AUTOINSTALL! working also with F40BT, X940BT etc! [updated: 27.09.2012]
ok, seul "user" est a copier pour une sauvegarde  ?
rien d'autre ?
tu me conseil une clé SD de 4 ou 8 Go ? ...Kingston ?..(pour travailler avec la SD sans problème ensuite)
merci
( depuis que je fréquente ce forum ,c'est la première fois que je lis des choses tres précises ,merci a toi )
Rien d'autre.  Libre à toi de copier tous les fichiers du module, mais le répertoire "USER" est le plus important.
  • 3 weeks later...
  • Replies 1.2k
Hello made an account for this.
I have the password written down but can't actually input the thing. Like the keyboard shows up to input the password and then as I press the letters and numbers nothing happens. Please help.
P.S I checked the password file already and it was correct (incase I was going insane)
Driving safety protection. Pull the handbrake to enable the keyboard.
  • 2 weeks later...
  • 3 weeks later...
Well, I advise against using this file as there are several threads on how to recover from using this... but if you insist, the password is in the first post: avic411
What are you trying to accomplish?  If you want to look at the file system or something use this file instead: http://avic411.com/index.php?/topic/35253-advanced-puzzles-testmodekey-scriptexecini/&do=findComment&comment=255788
you are posting in the F series forum but you have an X series Avic.
I'm not sure what you mean by "unlock".  Is it a password thing?  Is it just not working?  The link I gave above will "unlock" it to developer mode.
If you are trying to load other gps software onto your x930bt then re-read the first post again.  It says you can load the new software but the gps part doesn't work.  Seems like a deal breaker to me.
This condi hackmode is just a way to put the avic into a development/test mode.  It never accomplished its goal.  It doesn't work.
Hi, following the advice to use the version 1.4.
I have done all the steps: in /user/prg0/apl folder I deleted av.exe. I copied the folder condihack. Reset the unit with hackmode.key but it does not enter in hackmode.
Additional Information:
I have a pioneer F920BT firmware version 5 (which mentions a partner in post # 996)
I have made ​​a backup of the entire folder USER
I have made ​​a additional copy of av.exe file before to be deleted in the process
I looked at the size of folders and prg1 prg0 and is different (slightly larger prg1).
More Information:
I check USER backup. I have PRG.FLG in USER and:
EU090APL.HTM in PRG0: Release Version : 4.010000
EU090APL.HTM in PRG1: Release Version : 5.000000
Then, like I have PRG.FLG in USER then boot PRG1
What I can do?
1. Return PRG0/APL to original state (delete Av.exe and others files and folder CONDIHACK and re-copy original Av.exe to folder) and then hack PRG1/APL
2. Delete PRG.FLG after backup-it?
  • 2 weeks later...
Has anyone had the issue where they get stuck on the Pioneer splash screen after installing hackmode when trying to boot Norm, W/O an SD card?
I followed the instructions, and simply wanted to use Hackmode to replace my Navi.exe in PRG1, and when I was finished it wouldn't go past the splash screen no matter what I did. I could although put in the SD card and boot to hackmode, just not Norm mode...
I ended up just reverting back to the 5.1 update, but I would really like to replace this file. Any ideas?
x920BT
x920BT
HackMode should be called ScrewMode (and I'm being polite here) since it screws up most unit. I'd say 2 or 3 users really know what it does to the unit so I don't think you'll get an answer.
Stay away from it.
It is a pretty neat concept, it just seems unfinished. It really wasn't that hard to un-do, all I did was re-install the last update to 5.1.... It was just kind of scary when it didn't boot to anything but a splash screen after reading sooo many posts of people who bricked their units. I ended up today using the SUPERtestmode that was available in the posts.
Not sure about everyone else, but I definitely don't have $700 to unload.
I came to find out too that just Testmode doesn't copy/paste... Had to get the Super upgrade :)
