Jump to content
AVIC411.com
Condi's HACKMODE v2.2 - AUTOINSTALL! working also with F40BT, X940BT etc! [updated: 27.09.2012]
  • Replies 1.2k
  • Created
  • Last Reply
Top Posters In This Topic
@ Pionara or Condi:
Questions for my AVIC F930BT:
The file USER/PRG0/Apl is cleaned from Hackmode files and the Av.EXE file is made originally again. The device starts up normally, but:
  1. What is the function of USER/PRG1?  Is it used for starting up the device?
  2. After deleting the files added by Condi hack, in USER/PRG1/Apl....., the device did not start up, Why is that? Are these deleted files neccessary to function normally?
  3. Condi's Hack does not automaticaly copy complete USER file to the SD card. Is that correct?
  4. Before installing update AVIC F930BT 2013 is it wise to backup NAND2 with all ndata files in it? (for the TTS files e.g.).
  5. When the update does not start up automatically what is wrong then? Maybe because of the hackfiles present in PRG1?
Can anyone, with these specific knowledge, provide these information for better understanding before executing the UPDATE 2013.
Untill now I did not execute the update 2013.
Thank you for your answers so far, it helped me a lot with a proper working device. :-P
Greatings John5
Link to post
Share on other sites
  • 2 weeks later...
what password did you use during the decompression of the file? I used avic411 for the first password box pop up but it didn't work on the next password window.
i had the same issue when using my mac, worked fine on a PC though using avic411
Link to post
hello,
before all excuse me for my english because i'm french and my english is not very good.
i want update my f20bt with the 2013 update.
i will make a backup before the update with testmode but it's work not.
i see that the condi's hackmode V2.2.1 contains the testmode.
i've install the condi's hackmode.
the install work good but now,i can't go back on the normal mode of the f20bt.
I listen the radio,i can navigate in the "menu demarrer" of windows,i can go in the explorer file and i can go in the testmode.
I've read the 66 pages of the topics but i'm lost in all the solution.
before the installing of condi's hack,i'm in version 2.00.300.
I've download the CNSD-210fm EU update and the CNSD- fm update.
Can you help me and say me that i can make?
Thank you
Link to post
Hello,
Ditch I "ve read your topic, could you (or anyone else here) tell me please where you have downloaded the CNSD-210fm Eu ..I can't find it anywhere and all link I found were not good anymore ..... thanks a lot by advance ! (Ditch je suis francais aussi alors tu peux me répondre en francais ! lol)
Link to post
ok read 64 pages of all this i have a 930bt just want to unlock i as everyone else changed batteys and now in same boat can anyone or would anyone be willinjust send me a sd card loaded and ready to go with instuctions i will pay you for your time please let me know thanks scott
Link to post
  • 2 weeks later...
hello to all
I have a F940BT, the tutorial on post 1, is designed to perform
a full backup of the avic F940BT? (if I understand?)
Condi's HACKMODE this file v2.21 - AUTOINSTALL serves only has access to the pioneer to copy the SD all the important files pioneer?
once important files copied (thank you specify which files ,for F940BT?)
I remove the SD card, then ...... the pioneer starts normally, or reboot Still in "hack" mode?
thank you to explain to a beginner (my English is very "light" .... a French can explain? ...)
thank you
Link to post
Bonjour,
Premièrement, ne pas (je répète: NE PAS) utiliser la version v2.21.  Elle est largement reconnue pour bousiller des modules et les administrateurs de ce forum s'en foutent.  Utiliser la version v1.14 car, avec TestMode v1.14, il est possible de faire la même chose que v2.21 sauf que l'interface est simplement moins intuitive.
Le dossier USER est important à prendre en backup avant une mise à jour du firmware.  Le reste devrait être OK.
Link to post
merci Lyverbe , heureusement que tu est passé par içi !!!......
j'allais faire une bêtise !!....
donc il faut prendre ce fichier  --->
Condi's HACKMODE v1.4 BASE - INSTALL VIA TESTMODE.zip   5.32MB
 ensuite l'extraire dans une SD le mettre dans l'AVICf940bt et allumer
 le pioneer , laisser le moteur tourner
 le pioneer boot sur la SD et install le programme.
 ne rien toucher  , il reboot
 le pioneer demande si on veut entrer en "hack mode" ,je choisis  "oui"
 j'arrive sur un écran de bureau windows ,je choisis "file Manager" (fichiers)
et la je fais quoi ? quels fichiers copier pour être sur que je peux "récuperer"
mon avic f940bt si je fais une mauvaise manipulation ?  (user...seulement ?)
quand j'ai terminé la copie de sauvegarde ,le pioneer ,ne rebootera pas a chaque fois en "hack mode" ?
il y'a quelque chose a faire pour que le pioneer reboot comme avant ? (fonctionnement normal )
merci
Link to post
Oui, v1.4 absolument et éviter v2.21 à tout prix.
Il faut voir v2.21 comme étant une version Windows de la version v1.4 qui est comme une version textuelle.  Il est possible de manipuler des fichiers/répertoires et c'est ce qui permet de prendre en backup un répertoire complet.  Tu fais ainsi une copie complète du répertoire "USER" sur la carte SD.  S'il arrive un pépin, un restore de ce backup va aider... *croise les doigts!*
Au démarrage du module, il regarde d'il y a une carte SD d'inséré.  Si oui, il regarde si elle est bootable via TestMode.  Si tu mets une autre carte ou aucune carte, ton module va démarrer comme si de rien n'était.  La différence avec HackMode v2.21 est qu'il modifie DIRECTEMENT des fichiers systèmes internes du module pour s'exécuter et c'est là que tout bousille qu'il n'y ait aucune carte SD ou non.
Donc, avec TestMode v1.4, il n'y a aucune inquiétude que ce soit.  Bon, c'est sûr que si tu es sur le dossier "USER" et que tu sélectionnes "Erase" par erreur, c'est autre chose.  Il faut quand même faire attention, mais v1.4 est innofensif en soit.
Link to post
ok, seul "user" est a copier pour une sauvegarde  ?
rien d'autre ?
tu me conseil une clé SD de 4 ou 8 Go ? ...Kingston ?..(pour travailler avec la SD sans problème ensuite)
merci
( depuis que je fréquente ce forum ,c'est la première fois que je lis des choses tres précises ,merci a toi )
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
