Lyverbe Posted June 8, 2014 Report Share Posted June 8, 2014 ok, seul "user" est a copier pour une sauvegarde ? rien d'autre ? tu me conseil une clé SD de 4 ou 8 Go ? ...Kingston ?..(pour travailler avec la SD sans problème ensuite) merci ( depuis que je fréquente ce forum ,c'est la première fois que je lis des choses tres précises ,merci a toi ) Rien d'autre. Libre à toi de copier tous les fichiers du module, mais le répertoire "USER" est le plus important. Quote Link to post Share on other sites
Konbanwa Posted June 25, 2014 Report Share Posted June 25, 2014 Hello made an account for this. I have the password written down but can't actually input the thing. Like the keyboard shows up to input the password and then as I press the letters and numbers nothing happens. Please help. P.S I checked the password file already and it was correct (incase I was going insane) Quote Link to post Share on other sites
Lyverbe Posted June 25, 2014 Report Share Posted June 25, 2014 Hello made an account for this. I have the password written down but can't actually input the thing. Like the keyboard shows up to input the password and then as I press the letters and numbers nothing happens. Please help. P.S I checked the password file already and it was correct (incase I was going insane) Driving safety protection. Pull the handbrake to enable the keyboard. Quote Link to post Share on other sites
BlakeStone Posted June 25, 2014 Report Share Posted June 25, 2014 Just guessing, but you might need to have the parking brake on, to enable the screen. EDIT: ha! Lyverbe beat me by one minute! Quote Link to post Share on other sites
Ishmael27 Posted July 4, 2014 Report Share Posted July 4, 2014 Might be a stupid question but where is the downloadable fire for this hack? Quote Link to post Share on other sites
the_tombstone Posted July 21, 2014 Report Share Posted July 21, 2014 Is there a password for extraction? I keep getting password requirements. Quote Link to post Share on other sites
BlakeStone Posted July 22, 2014 Report Share Posted July 22, 2014 Well, I advise against using this file as there are several threads on how to recover from using this... but if you insist, the password is in the first post: avic411 What are you trying to accomplish? If you want to look at the file system or something use this file instead: http://avic411.com/index.php?/topic/35253-advanced-puzzles-testmodekey-scriptexecini/&do=findComment&comment=255788 Quote Link to post Share on other sites
the_tombstone Posted July 22, 2014 Report Share Posted July 22, 2014 I am trying to unlock an AVIC-x930BT Quote Link to post Share on other sites
BlakeStone Posted July 22, 2014 Report Share Posted July 22, 2014 you are posting in the F series forum but you have an X series Avic. I'm not sure what you mean by "unlock". Is it a password thing? Is it just not working? The link I gave above will "unlock" it to developer mode. If you are trying to load other gps software onto your x930bt then re-read the first post again. It says you can load the new software but the gps part doesn't work. Seems like a deal breaker to me. This condi hackmode is just a way to put the avic into a development/test mode. It never accomplished its goal. It doesn't work. Quote Link to post Share on other sites
macluinux Posted July 25, 2014 Report Share Posted July 25, 2014 Hi, following the advice to use the version 1.4. I have done all the steps: in /user/prg0/apl folder I deleted av.exe. I copied the folder condihack. Reset the unit with hackmode.key but it does not enter in hackmode. Additional Information: I have a pioneer F920BT firmware version 5 (which mentions a partner in post # 996) I have made ​​a backup of the entire folder USER I have made ​​a additional copy of av.exe file before to be deleted in the process I looked at the size of folders and prg1 prg0 and is different (slightly larger prg1). More Information: I check USER backup. I have PRG.FLG in USER and: EU090APL.HTM in PRG0: Release Version : 4.010000 EU090APL.HTM in PRG1: Release Version : 5.000000 Then, like I have PRG.FLG in USER then boot PRG1 What I can do? 1. Return PRG0/APL to original state (delete Av.exe and others files and folder CONDIHACK and re-copy original Av.exe to folder) and then hack PRG1/APL 2. Delete PRG.FLG after backup-it? Quote Link to post Share on other sites
juanmo21034 Posted August 4, 2014 Report Share Posted August 4, 2014 in order for me to extract the files its asking me for a password, I have no clue onto what the password is Quote Link to post Share on other sites
z0ned Posted August 7, 2014 Report Share Posted August 7, 2014 Has anyone had the issue where they get stuck on the Pioneer splash screen after installing hackmode when trying to boot Norm, W/O an SD card? I followed the instructions, and simply wanted to use Hackmode to replace my Navi.exe in PRG1, and when I was finished it wouldn't go past the splash screen no matter what I did. I could although put in the SD card and boot to hackmode, just not Norm mode... I ended up just reverting back to the 5.1 update, but I would really like to replace this file. Any ideas? x920BT Quote Link to post Share on other sites
Lyverbe Posted August 7, 2014 Report Share Posted August 7, 2014 Has anyone had the issue where they get stuck on the Pioneer splash screen after installing hackmode when trying to boot Norm, W/O an SD card? I followed the instructions, and simply wanted to use Hackmode to replace my Navi.exe in PRG1, and when I was finished it wouldn't go past the splash screen no matter what I did. I could although put in the SD card and boot to hackmode, just not Norm mode... I ended up just reverting back to the 5.1 update, but I would really like to replace this file. Any ideas? x920BT HackMode should be called ScrewMode (and I'm being polite here) since it screws up most unit. I'd say 2 or 3 users really know what it does to the unit so I don't think you'll get an answer. Stay away from it. Quote Link to post Share on other sites
z0ned Posted August 8, 2014 Report Share Posted August 8, 2014 It is a pretty neat concept, it just seems unfinished. It really wasn't that hard to un-do, all I did was re-install the last update to 5.1.... It was just kind of scary when it didn't boot to anything but a splash screen after reading sooo many posts of people who bricked their units. I ended up today using the SUPERtestmode that was available in the posts. Not sure about everyone else, but I definitely don't have $700 to unload. I came to find out too that just Testmode doesn't copy/paste... Had to get the Super upgrade Quote Link to post Share on other sites
ola46 Posted August 11, 2014 Report Share Posted August 11, 2014 Hi Condi I just fixed my radio F930BT after a visit to my garage! Thnx mate buy yourself a beer cheers! Quote Link to post Share on other sites
Join the conversation
