kamilekrr1 Posted April 13, 2015 Report Share Posted April 13, 2015 http://avic411.com/i...otten-password/ IT WORKS ! Thanks BlaeStone. I skip first 3 steps according Pionara suggestions. Quote Link to post Share on other sites
aboky Posted April 16, 2015 Report Share Posted April 16, 2015 Hi! On F940BT work? Quote Link to post Share on other sites
codi Posted May 2, 2015 Report Share Posted May 2, 2015 Hello, in the last release V2.2 ist there any GPS problems now or is that problem solved? Quote Link to post Share on other sites
djvirus Posted May 2, 2015 Report Share Posted May 2, 2015 Hi the password for the zip files are not working. I used avic411 but it still ask for password Quote Link to post Share on other sites
kelty Posted May 12, 2015 Report Share Posted May 12, 2015 hello condiczek i have a avic 9310bt unit and have the folders prg0,prg1 can i set a version of igo8 on sd card en copy the exe file from igo8 to the unit to start the igo nav running on sd card? what file do i have to delete to start the igo8 ? so i tought rename the igo8 exe file to the pioneer exe nav file name so i can start the igo8 navigation on sd card greetz simon Quote Link to post Share on other sites
SweetElite Posted May 22, 2015 Report Share Posted May 22, 2015 When I run the test mode it fails will not load up.. Can anyone give some update on this plz... Quote Link to post Share on other sites
Canada17 Posted July 5, 2015 Report Share Posted July 5, 2015 Thanks very much for the hack! it worked and its awesome to have my stereo back! Quote Link to post Share on other sites
ccope616 Posted July 25, 2015 Report Share Posted July 25, 2015 I cannot unzip the file. after entering the password avi411, it asks me to enter the password for HACKMODE.KEY which I do not have. avic411 does not work. Quote Link to post Share on other sites
nickpruit Posted August 29, 2015 Report Share Posted August 29, 2015 So, I'm very new to this whole deal I have absolutely zero programming experience, I bought a new car and it is equipped with the x930bt, worked beautifully day 1, well then yhe dealer did some work on my car, and now... stereo wants a password, I tried putting this hackmode on my SD card and inserting it in the stereo but it won't go past the password screen, what do I do? Quote Link to post Share on other sites
BlakeStone Posted September 1, 2015 Report Share Posted September 1, 2015 Please don't use condi's hackmode stuff. It can go bad real fast with its use. You don't need it. You only need the supertestmode here: http://avic411.com/index.php?/topic/35253-advanced-puzzles-testmodekey-scriptexecini/&do=findComment&comment=255788 Boot with just the testmode file on the sd card. You need to make sure there is no power to the unit first... put the sd card in and then turn on the ignition for power. It should boot to the developer menu. It should be easy to navigate to the password file and determine what the password is. a. Grab the test mode files and load it up on the sd card and head over to the head unit..b. Insert card and load up test mode.. Go to the file manager -> User -> system -> security -> password and do a Text dump of this file.. (thanks to user: odskaggs2 for the hint!)c. write down the what is on the screen.. This is the password!!! =DThat's it!​ The password does not include spaces and periods usually. If you can't figure it out that way, then I think just deleting the file is enough to get in. Quote Link to post Share on other sites
rogerf159 Posted September 13, 2015 Report Share Posted September 13, 2015 Tried using your program and it locked up my AVIC-Z120BT. On the screen it says: 'There is no applicable program'. And there we have it. The screen stays stuck in this screen and I've tried to get out of it but no luck. Is there a fix for this? Or is my unit now garbage? Thanks Quote Link to post Share on other sites
BlakeStone Posted September 14, 2015 Report Share Posted September 14, 2015 /sigh Quote Link to post Share on other sites
nataliabea9 Posted October 29, 2015 Report Share Posted October 29, 2015 Password "avic411" is not working. Any hints? I bought a used Honda Civic from a certified dealership and 2 weeks ago the battery died. Now the system is asking for a password. Went to the dealership and "they have no idea what the password is". So I have a useless radio and I'm DEFINITELY not paying $80. Quote Link to post Share on other sites
BlakeStone Posted October 29, 2015 Report Share Posted October 29, 2015 nataliabea9 do not use this tool for recovering your password or doing anything with it... ever. for password recovery you only need the testmode on an empty sd card here: http://avic411.com/index.php?/topic/32929-x930bt-password-recovery/?p=335762 then continue with the password recovery instructions. Quote Link to post Share on other sites
cam_klar Posted October 30, 2015 Report Share Posted October 30, 2015 im locked out of my avic x940bt and i used this, but i can do anything but use hackmode. is there anyway i can use hackmode to ulock my unit so i can use it Quote Link to post Share on other sites
Join the conversation
