Jump to content
Condi's HACKMODE v2.2 - AUTOINSTALL! working also with F40BT, X940BT etc! [updated: 27.09.2012]
  • Please log in to reply
1177 replies to this topic
#1171 Renou
Renou
  • Members
  • 1 posts
Posted 18 March 2017 - 06:27 PM
Hello i have a problem the first extraction code works, but there is no second to decompress the zip condo's can you help me please ?
#1172 kcinayc
kcinayc
  • Members
  • 1 posts
Posted 15 April 2017 - 02:27 PM
Hello,
I am a new member and I read with great interrest the topic.
I have an AVIC-F930BT.
I would like to just get the testmode function.
How can I do to enter in the TestMode Menu ?
Do I have to push on different buttons on the F930BT,  or do I have to download a file ? If yes how can I download the necessary file ?
Thanks a lot for your help.
Regards
#1173 piotrexd
piotrexd
  • Members
  • 1 posts
Posted 15 April 2017 - 11:11 PM
Hi you speak Polish because I have Pioneer AVIC x940bt and I have some questions to check if you are active and can you help me? So how do you reply to us about Pioneer AVIC HACKMODE by Condi
piotr.netpol@gmail.com
tel: 795 XXX XXX
#1174 yodaisurmother
yodaisurmother
  • Members
  • 1 posts
Posted 18 May 2017 - 09:52 PM
What is the hack mode password?
#1175 taylrhllbro
taylrhllbro
  • Members
  • 1 posts
Posted 18 May 2017 - 11:51 PM
I managed to run some apps, TCPMP player, iGO8, Mireo Cardinale, and other gps software works too. New mortscript is not working, like some other software also, i think because of lack of some libraries/dlls. Windows in this units is very 'handicaped', there is no explorer.exe, control panel cpl's are not running etc.
I will make some scripts which will run some custom software/menu if proper files will appear on sd/usb.
For now I must get rid of av going front after ~30s.
When everything will work as I want to, then of course I will release full solution smile.gif
Hey im trying to use the v1.4 on my z110bt, i downloaded the file and drug it onto my sd card but idk what else to do from there? when i double click and open the test mode it says registered to: and registration/activation mode: im super confused on what im supposed to do i just need to reset my password because the guy i bought my truck from never told me about any password
#1176 BlakeStone
BlakeStone
    Member
  • Members
  • 87 posts
Posted 19 May 2017 - 11:53 AM
Stop using this hackmode and delete it.  Search for the password reset thread instead.
Hopefully you haven't ruined your unit with hackmode as it does hack your system.  There is no need to do any hacking.
#1177 genbtc
genbtc
  • Members
  • 1 posts
Posted 19 May 2017 - 05:42 PM
Wow. I think i just ruined my system. I have Avic-X930BT also, (was on latest firmware i believe 6.0) I tried to autoinstall condi Hackmode 2.21, it copied the hacked files, rebooted and said something like "Can not find valid application". I need to know how to Undo this now. To get my system working. All i need is to reset password.
EDIT:
I was able to fix it manually by running a SD card with this and only this in the ScriptExec.ini :
COPY -rc SD\UPDATE\USER\PRG\APL USER\PRG0\APL
where SD\UPDATE would be the update folder on your SD card, the one containing the latest Map update, in my case 2015 USA CANADA MAP UPDATE.zip
Now how Do i Get into Testmode, the 10 item menu ?
#1178 BlakeStone
BlakeStone
    Member
  • Members
  • 87 posts
Posted 20 May 2017 - 04:02 PM
SUPERTESTMODE.ZIP
Recent blog entries on this topic
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
