F310 Posted May 4, 2011 Report Share Posted May 4, 2011 http://vimeo.com/21381234 Seems like the test mode exists. Quote Link to post Share on other sites
Schumi Posted May 4, 2011 Report Share Posted May 4, 2011 Procedure:---------- • Insert CARD1 into the PND and press Reset Ok, but were can i get the CARD1??? Is anybody knows, where to download it? Quote Link to post Share on other sites
F310 Posted May 5, 2011 Author Report Share Posted May 5, 2011 I'm looking for it Quote Link to post Share on other sites
F310 Posted May 5, 2011 Author Report Share Posted May 5, 2011 Does anyone have service manual for F310BT/ U310BT ? Quote Link to post Share on other sites
F310 Posted May 5, 2011 Author Report Share Posted May 5, 2011 Can anyone get it from here? http://www.smpcshop.com/AVIC-F310BT-AVIC-U310BT-AVIC-F320BT-p-9192.html Quote Link to post Share on other sites
JasonH Posted May 5, 2011 Report Share Posted May 5, 2011 Uh, I think you guys mean the new Condi Hack. http://avic411.com/index.php?/topic/31534-condis-hackmode-v01/ Quote Link to post Share on other sites
F310 Posted May 5, 2011 Author Report Share Posted May 5, 2011 I tried it with no success. I unpack the files to my SD card and then insert it into F310BT.....and nothing happens. Any ideas? Quote Link to post Share on other sites
F310 Posted May 5, 2011 Author Report Share Posted May 5, 2011 Look what I've found in service manual for F310 U310: How to Use TestMode Jig No: GGV1345 Startup procedures 1. Store the TestMode folder that can be found inside the TestMode folder on GGV1345 to directly below the SD card. Note : “ Test Mode †folder must be on the SD card root. 2. Download a ID file from the Service Site and copy the file to the “ Test Mode†folder on the SD card. 3. Attach the PND into which the SD card containing the program has been inserted to the main unit. 4. Turn ON the BUP and ACC of the main unit. 5. Press the Reset button. 6. TestMode will start up automatically. I have the GGV1345 files but the problem is ID file. How to get or generate it? Quote Link to post Share on other sites
condiczek Posted May 5, 2011 Report Share Posted May 5, 2011 Look what I've found in service manual for F310 U310: How to Use TestMode Jig No: GGV1345 Startup procedures 1. Store the TestMode folder that can be found inside the TestMode folder on GGV1345 to directly below the SD card. Note : “ Test Mode †folder must be on the SD card root. 2. Download a ID file from the Service Site and copy the file to the “ Test Mode†folder on the SD card. 3. Attach the PND into which the SD card containing the program has been inserted to the main unit. 4. Turn ON the BUP and ACC of the main unit. 5. Press the Reset button. 6. TestMode will start up automatically. I have the GGV1345 files but the problem is ID file. How to get or generate it? Have you tried standard TestMode 2.3? GGV1345 has got TestMode directory with NNTestMode.exe, like in TestMode 2.3. Try it Quote Link to post Share on other sites
F310 Posted May 5, 2011 Author Report Share Posted May 5, 2011 Ok, I'll try Quote Link to post Share on other sites
F310 Posted May 5, 2011 Author Report Share Posted May 5, 2011 Tried testmode 2.3.... no success again. Quote Link to post Share on other sites
F310 Posted May 6, 2011 Author Report Share Posted May 6, 2011 Any ideas how to get the ID file? Quote Link to post Share on other sites
condiczek Posted May 6, 2011 Report Share Posted May 6, 2011 Any ideas how to get the ID file? I think that you need special-named empty file to get into TestMode? There are some key files in TestMode 2.3 like: 63D21BEFE088433dBE3CF942347464C7, 164C549550B84211BA8C4B84AC5C0081, etc. You need the correct file to get access to TestMode. There is available firmware for F310BT, you can search for someone who maybe took off the key from fws? Another option is to modify firmware update with my prepared files, to get hackmode, but its risky without having access to standard pioneers testmode! br condi Quote Link to post Share on other sites
navalion Posted July 6, 2011 Report Share Posted July 6, 2011 yes is real to start test mode on 310bt if anyone can do anything with a files from internal memory i can put here a test mode files to start them and is run with this files in test mode. put the test mode file from archive on sd card put this card in f310bt and push reset. and is done is test mode TestMode_by_charlie.rar Quote Link to post Share on other sites
F310 Posted July 6, 2011 Author Report Share Posted July 6, 2011 I will try it Quote Link to post Share on other sites
