Citka4 Posted May 13, 2011 Report Share Posted May 13, 2011 I have a Z110BT that has been flashed to a Z120BT. I recently purchased the Sirius modules for it (Sirius to Pioneer interface and the Sirius receiver). I hooked up everything up and can see the channel I am on as well as what song is playing, but there is no audio. I thought it may have been the Sirius equipments, so I replaced both of them but same problem. This leads me to believe that it's the Headunit. Any ideas? Quote Link to post Share on other sites
rgarjr Posted May 14, 2011 Report Share Posted May 14, 2011 which Sirius receiver are u using? Quote Link to post Share on other sites
Citka4 Posted May 14, 2011 Author Report Share Posted May 14, 2011 The receiver is the SCC1 and the interface to the HU is CD-SB10 Are those the correct part numbers? Quote Link to post Share on other sites
Richiec Posted October 31, 2011 Report Share Posted October 31, 2011 I had the same issue, I had to disconnect the power to both the sirius and head unit, for about an hour, tried 15 minutes and still didn't work. I thought the unit was broke, but after having battery disconnected for over an hour, It worked again. I have also called both companies about this issue, and they had told me the Sirius unit was bad.. But I guess they where wrong. But a month later I decided to go with the XM unit, due to its better interface.. Quote Link to post Share on other sites
krome Posted November 24, 2011 Report Share Posted November 24, 2011 I had the same thing and ended up finding the cable was in the wrong slot on the cd-sp10. It needed to be in the output slot instead of the input. Quote Link to post Share on other sites
