Problem with Testmode with Avic F220/iGo on F220 (Tutorial)
  • Please log in to reply
12 replies to this topic
#1 Daniel2504
Daniel2504
  • Members
  • 4 posts
Posted 13 August 2011 - 04:05 PM
Hi,
my name is Daniel and i am from germany and i need your help.
I own a F220, Firmware Ver. 2.0 in combinatinon with the AVH-6300BT.
I really tried a lot to get in the Testmode to install mods, but the F220 won't get in the testmode.
I did all like the manuals here to get in the testmode but i failed.
Can anyone help me how i can get in the Testmode on my Avic F220?
Greets
Daniel
#2 VBLUE42
VBLUE42
    Established Member
  • Moderators
  • 7,909 posts
  • LocationMS
Posted 13 August 2011 - 07:59 PM
There are no mods for the F220 anyway.
2010 SCION TC, iPhone 5, SPH-DA100 APPRADIO 2, APPRADIO EXTENSIONS, ROCKFORD FOSGATE 3SIXTY.2 PROCESSOR, POLK DXI 6500 COMPONENTS IN FRONT, JL AUDIO SEALED POWER WEDGE 12" SUB, SMITH & WESSON.
#3 condiczek
condiczek
    Member
  • Members
  • 160 posts
Posted 13 August 2011 - 08:15 PM
Hi,
Greets
Daniel
Use this one.
#4 Daniel2504
Daniel2504
  • Members
  • 4 posts
Posted 14 August 2011 - 11:00 AM
Hi,
I tried this Testmode form your link but it didn't work. Nohing happens when I put the SD-Card with the testmode in.
Can anyone help me?
By the way. Its the european Version of the F220 I think.
edit: I tried it again and i got into the Testmode. :)
Only problem now is: When I try to start ezrider.exe it says, that the ezrider.exe cant be found or any files from the appliation.
What can I do that iGo runs?
edit2: I got Igo8 at the F220 running. It's running without failures. A Howto will follow. ;)
Dear Greets
Daniel
#5 user5444
user5444
  • Members
  • 2 posts
Posted 18 August 2011 - 04:20 PM
Daniel,
Can you please provide the howto so others can use it as well?. Thank you.
#6 jipeey
jipeey
  • Members
  • 1 posts
Posted 12 February 2012 - 07:14 PM
I'm interested to by the how-to!
Thank you
#7 CVille
CVille
  • Members
  • 6 posts
Posted 21 February 2012 - 08:45 PM
Thank you
x2
#8 Daniel2504
Daniel2504
  • Members
  • 4 posts
Posted 07 June 2012 - 10:24 PM
Hello,
iam sorry that i haven't answerd earlier. But the Time at the last Weeks didn't allow it.
So here ist the requestet Tutorial. At least its really easy. The biggest Problem was, to find a runnig iGo for the F220. The most versions of it and the most other Nav-Programs aren't compatible with the F220.
But i found a working version and had sucess.
At first you have to download this iGo and Testmode. I packed it in a .zip. Pass is avic411
Then copy the folder in the .zip to the root of your SD-Card. Please change nothing at the folderstructure or the files if you don't know what you do. In this case you risk, that iGo oder TestMode won't work correctly.
Next step are the maps. There are a lot oft Websites you cand download them. Copy the map-file(s) to "iGo->content->map". For this time you are finished an your iGo is "F220-ready"
Then switch your F220 on and put the SD-Card in the slot, while F220 is running. Now press the reset button of your F220. Normally appears now the Windows-Desktop and Testmode is started. Press the "Start"-button of Windows and start the explorer. Then navigate to Storagecard->iGo and now double click on the iGo.exe.
If you are done all steps correctly, iGo starts now.
Next step is to get a GPS-Connection. The standart port and baud rate for GPS which is set in iGo is wrong. So you have to change it manually. On my F220 the correct.port is 2 and the correct baud rate is 57600. If that don't work there are tow possibillitis: Your GPS-Port is not unlocked or at your device are other options correct. At this case you have to test alle possibillities you can set at port and baud rate. If this fail too, your GPS-Port is locked surely. How you can unlock the port on the F220 i don't know. Maybe another meber does know it.
Now you have to set the TMC-Port. Thats easy. Only start the auto search and iGo will find it automatically.
Only thing which works not at the F220 is TTS and the sound at all. The output noise is too low and all my try's to make it louder are failed at this time.
Maby someone know how to make the iGo sounds or the sound of the WinCE on F220 louder?!
And the automatic noise regulation of the Radio Device won't work anymore by using iGo.
At least iam sorry for by bad english. I tried to make it readable. Sorry if that failed at some places of the Tutorial.
Dear Greets from Germany
Daniel
#9 nosni1
nosni1
  • Members
  • 3 posts
Posted 17 July 2012 - 01:07 AM
Perfect I have it running I only have one big problem how do i edit the resolution because is too big in my radio so i can't get pass language when i open Igo. Im trying it with the U220 in the avh-1400 resolution 480x240
#10 noki_72
noki_72
  • Members
  • 2 posts
Posted 18 July 2012 - 01:51 PM
Hi nosni1,
ammend the sys.txt under the igo folder.
br,noki_72
#11 nosni1
nosni1
  • Members
  • 3 posts
Posted 18 July 2012 - 09:53 PM
Hey I have the U220 running with Garmin XT 5.0 will be posting a how to in a few
#12 noki_72
noki_72
  • Members
  • 2 posts
Posted 19 July 2012 - 07:10 PM
i will wait for a how to..... in germany :-P
#13 robin haba
robin haba
  • Members
  • 1 posts
Posted 05 October 2012 - 07:42 PM
I have the same "to little screen" problem.
I changed the resolution in 480x240 and this results in a failure.
What is there to change in the sys file ??
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
