Raggi73 Posted October 7, 2011 Report Share Posted October 7, 2011 Hi. My F900 started, as many others to reboot but I have tried to delete the GPS files with no luck. I have looked around on the disk and found that on APL2/iGO there are several files called C...something. When I got the unit 2 years ago I did a full backup and I can't see these files on this backup. Also I can not delete these files. When I try to delete the disk it fails on these files, and when I try to copy my back onto the disk, if says there are not enough space. My thoughts would be that my disc has become corrupt and I need to format. Can anyone guide me to this? Quote Link to post Share on other sites
mrvictory1999 Posted October 11, 2011 Report Share Posted October 11, 2011 I am having the same problem. I can't delete these files or change them, and I suspect this is related to the constant rebooting which I am also experiencing. Quote Link to post Share on other sites
Raggi73 Posted October 11, 2011 Author Report Share Posted October 11, 2011 I manage to solve the problem. When I update to the 2010 software/map last year, I did a copy of the content onto a USB stick Started in Testmode and went into control panel. Removed all SD, usb cards etc. There was a utility where I could format the drive. I had first to unmount it. Can't remember the name of it, but it was one of the last icons there. After format, I connected the usb stick and copied that content back onto "My flashdrive" and restarted. Knock on wood: It has worked for a couple of days now, including 2011 software update. Strange thing: I also have a backup from the unit when I bought it in 2009 and first I tried to copy this back to the unit and it worked. Then I proceeeded to update the software to the 2010 with maps etc (original update) and then it failed again. No corrupt data, just saying "system startup - ......." and reboot. Also what caused the files to become corrupt? Quote Link to post Share on other sites
bitman Posted October 12, 2011 Report Share Posted October 12, 2011 most likely disk full Quote Link to post Share on other sites
mrvictory1999 Posted October 12, 2011 Report Share Posted October 12, 2011 I tried every application I could find in test mode but couldn't find any way to format my flash disk. (I have a F700BT.) My disk is definitely full and that is probably what is causing the boot looping. Could you tell me what you used to format the disk? Quote Link to post Share on other sites
Raggi73 Posted October 12, 2011 Author Report Share Posted October 12, 2011 mrvictory1999: In controll Panel there is a program called Storage Manager and from there I could format the drive. Fist rememer to remove any SD or memory sticks from the unit. http://www.google.no/imgres?q=WinCE+storage+manager&um=1&hl=no&biw=1280&bih=946&tbm=isch&tbnid=IOjQbIY_9EmD8M:&imgrefurl=http://community.psion.com/discussions/f/160/t/4238.aspx&docid=7aEF_Rtqkelj3M&w=240&h=320&ei=R-aVToPCGMPFswaQxsn7BQ&zoom=1&iact=hc&vpx=944&vpy=166&dur=4471&hovh=256&hovw=192&tx=102&ty=178&page=1&tbnh=129&tbnw=97&start=0&ndsp=36&ved=1t:429,r:34,s:0 I dismounted the drive and then I could format it. After format then Mount the device again. Quote Link to post Share on other sites
