kisiel Posted September 27, 2012 Report Share Posted September 27, 2012 Hi, Thank you Guys for so hard work on cracking the 310 unit. Great job and I improved my F310BT and made it more friendly. Best regards Kisiel Quote Link to post Share on other sites
fra1110 Posted October 17, 2012 Report Share Posted October 17, 2012 Hi! I have the 320BT and everything works correctly, igo included. i set up modded applib and now i can play video with tcmp and use ttom or i go as i prefer. just a question: igo say me gps module not found, why? is this module inside the radio or is inside the PDA? if is inside the PDA what i have to change in order to recognize the gps hardware of my PDA320bt? sorry for my english if anyone need a SD backup just tell me Quote Link to post Share on other sites
fra1110 Posted October 18, 2012 Report Share Posted October 18, 2012 how i can create another icon for the pioneer nav menu? i want to start tom tom and games etc Quote Link to post Share on other sites
fra1110 Posted October 26, 2012 Report Share Posted October 26, 2012 http://www.facebook.com/groups/F320BT/ i have made a group on fb for the AVIC F320BT and his hack, if someone what to join... Quote Link to post Share on other sites
jazapata Posted October 27, 2012 Report Share Posted October 27, 2012 This proceess wok on AVIC-Z140BH ???? Pls Help. Quote Link to post Share on other sites
kisiel Posted November 6, 2012 Report Share Posted November 6, 2012 Hi, Did someone find the solution for rebooting back to regular stock nav mode after switching off the power? (sleep mode). It's really annoying, to run the Igo again and again by app mode and unit reboot. Do you think, it's possible to set some *.bat or *.exe file, with mortscript killing the stock nav and launching Igo just after power on? I'm to weak in programming, but looking for the opportunities or way, how to do it. BTW, after all changes I can use Igo via app mode, but the stock nav is stucking in place, where I've launched Igo. It's frozen until the unit hard reset, but then I loose all the audio and other settings, what is another irritating bug. Best regards Kisiel Quote Link to post Share on other sites
Angeloamd1985 Posted November 9, 2012 Report Share Posted November 9, 2012 Hi, I have Avic-f310bt and i updated to ver.2(thanks to Pionara).Everything work fine except stock Navi it's too slow.The solution is to remove one pole of battery for 10sec and the stock Navi works fine again.When i run Igo then stock Navi is slow again. In the past i ran Igo (vesrion 1.0.0.4 firmware stock navi) with testmode and i has the same problem stock Navi too slow. My conclusion is that firmware update is not the problem but something goes wrong with wince registry or gps port(Igo uses port=4 baud=57600) and the stock Navi uses different i think so To use Mode button on unit to manage fm presents,usb songs etc when you run Igo you must press Menu on Igo and then Mode Button. Now for Igo Primo 2 i succeeded run it with this sys.txt but the problem it is crash after 4-5 minutes and when i use simulation mode i don't know why.Sorry for my bad english. -------------------------------------- [folders] has_secondary_root=0 [interface] show_exit=1 extra_settings=1 show_tmc_config=1 show_tmc_eventlist=1 show_programs=1 show_minimize=1 mapfontscale=120 laneinfo_signpost_enabled=1 show_statustext=1 shutdown_time=0 recalc_voice=0 start_navigation_time=5 max_flag_distance_3d=3000 resolution_dir="480_272" vga=0 [rawdisplay] class="landscape" highres=0 screen_x=480 screen_y=272 [loading] show_statustext=1 [power] powermgm_state=0 [other] demo_enabled=0 [debug] skip_eula=1 experimental_features=1 show_battery_percent=1 hnr=1 show_hnr=1 reserve_memory=1500000 cache=262144 [naviextras] boot_service_address="http://zippy.naviextras.com/services/index/1" [tmc-http] servers.size=1 servers[0].url="http://zippy.naviextras.com/services/tmclite/data/nng-igo-tmc-iphone/0/" enabled=1 start=1 [sound] csv_voice_enabled=1 ding_muted=1 maneuver_chimes=0 [volume_channels] volumefade=500 [poi] use_poi_mapping=5 use_multi_poi_mapping=0 [route] correctness=100 guidance_at_highway_entry=1 auto_enable_permit_needed=0 guidance_at_highway_exit=1 [network] available=1 [timezone] patch_dst=1 sync_time=1 use_auto=1 sync_os_timezone=0 reset_os_timezone=0 [timezones] use_timezone_setting_fix=1 use_new_timezone_ini=1 timezone_key="Time Zones" [map] 3d_scale_carmodel=1 3dcarsizemin=9000 3dcarsizemax=15000 3dcarsizemul=80000 3d_max_tiltlevel=9000 3d_min_zoomlevel=20 poi_distant_distance=200 multi_poi_distant_distance=0 multi_poi_icon_distant_distance=0 poi_mapping=5 use_poi_mapping=5 max_poi_mapping=5 max_pois_on_horizont=5 show_pois=0 use_multi_poi_icon=0 [3d] planned_route_contour_width=4 use_all_building_textures=1 fade_distance_for_car=0 fade_distance_for_guidance_arrow=0 fade_overlap_tolerance=0 fade_around_cursor=1 max_pois_on_horizont=5 max_poi_mapping=5 poi_mapping=5 multi_poi_distant_distance=0 multi_poi_icon_distant_distance=0 [route.histspeed] enabled=1 show=1 use_timeslice=1 [route.histspeed.timeslice] day=1 hour=8 minute=1 [route] correctness=100 guidance_at_highway_entry=1 auto_enable_permit_needed=0 guidance_at_highway_exit=1 [gps] port=4 baud=57600 protocol=NMEA set_messages=0 [tts] tts_buffer=131072 announce_exit_directions=1 tts_logics=3 priority="HIGH" always_say_road_names=3 announce_street_name=1 skip_exit_numbers=0 [dynamiccompressor] compressor=1 ratio=9 gain=9 [warning] speedlimit_warning_visual=1 speedcam_warning=1 is_spoken=1 speedcam_max_lookahead=2000 speedcam_maxdistance_from_road=10 [speedcam_category:0] activated_spoken_type=speech activated_speech="Caution speed camera ahead" approach_beep_spoken_type=0 approach_beep_speech=0 approach_beep_sound=0 overspeed_spoken_type=0 overspeed_speech=0 overspeed_sound=0 warn_distances="150:2000,140:1800,130:1500,120:1400,110:1300,100:1200,90:1100,80:1000,60:700,50:600,40:500" [speedcam_category:1] activated_spoken_type=speech activated_speech="Caution mobile speed camera ahead" approach_beep_spoken_type=0 approach_beep_speech=0 approach_beep_sound=0 overspeed_spoken_type=0 overspeed_speech=0 overspeed_sound=0 warn_distances="150:2000,140:1800,130:1500,120:1400,110:1300,100:1200,90:1100,80:1000,60:700,50:600,40:500" [speedcam_category:2] activated_spoken_type=speech activated_speech="Caution traffic light camera" approach_beep_spoken_type=0 approach_beep_speech=0 approach_beep_sound=0 overspeed_spoken_type=0 overspeed_speech=0 overspeed_sound=0 warn_distances="110:1000,90:900,60:700,50:500,40:200,20:100" [speedcam_category:3] activated_spoken_type=speech activated_speech="Caution average speed camera ahead" approach_beep_spoken_type=0 approach_beep_speech=0 approach_beep_sound=0 overspeed_spoken_type=0 overspeed_speech=0 overspeed_sound=0 warn_distances="150:2000,140:1800,130:1500,120:1400,110:1300,100:1200,90:1100,80:1000,60:700,50:600,40:500" [speedcam_category:4] activated_spoken_type=speech activated_speech="Caution traffic light ahead" approach_beep_spoken_type=0 approach_beep_speech=0 approach_beep_sound=0 overspeed_spoken_type=0 overspeed_speech=0 overspeed_sound=0 warn_distances="110:1000,90:900,60:700,20:500" [speedcam_category:6] activated_spoken_type=speech activated_speech="Caution dangerous railway crossing" approach_beep_spoken_type=0 approach_beep_speech=0 approach_beep_sound=0 overspeed_spoken_type=0 overspeed_speech=0 overspeed_sound=0 warn_distances="0:500" [speedcam_category:7] activated_spoken_type=speech activated_speech="Caution bus lane camera ahead" approach_beep_spoken_type=0 approach_beep_speech=0 approach_beep_sound=0 overspeed_spoken_type=0 overspeed_speech=0 overspeed_sound=0 warn_distances="110:1000,90:900,60:700,20:500" [speedcam_category:8] activated_spoken_type=speech activated_speech="Caution dangerous crossing" approach_beep_spoken_type=0 approach_beep_speech=0 approach_beep_sound=0 overspeed_spoken_type=0 overspeed_speech=0 overspeed_sound=0 warn_distances="0:300" [speedcam_category:9] activated_spoken_type=speech activated_speech="Caution scholl zone ahead" approach_beep_spoken_type=0 approach_beep_speech=0 approach_beep_sound=0 overspeed_spoken_type=0 overspeed_speech=0 overspeed_sound=0 warn_distances="0:500" [speedcam_category:10] activated_spoken_type=speech activated_speech="Caution town entry point" approach_beep_spoken_type=0 approach_beep_speech=0 approach_beep_sound=0 overspeed_spoken_type=0 overspeed_speech=0 overspeed_sound=0 warn_distances="0:2000" [speedcam_category:11] activated_spoken_type=speech activated_speech="Intimidation radar" approach_beep_spoken_type=0 approach_beep_speech=0 approach_beep_sound=0 overspeed_spoken_type=0 overspeed_speech=0 overspeed_sound=0 [speedcam_category:12] activated_spoken_type=speech activated_speech="Caution toll ahead" approach_beep_spoken_type=0 approach_beep_speech=0 approach_beep_sound=0 overspeed_spoken_type=0 overspeed_speech=0 overspeed_sound=0 warn_distances="0:1000" [speedcam_category:13] activated_spoken_type=speech activated_speech="Caution hospital" approach_beep_spoken_type=0 approach_beep_speech=0 approach_beep_sound=0 overspeed_spoken_type=0 overspeed_speech=0 overspeed_sound=0 warn_distances="0:300" [speedcam_category:14] activated_spoken_type=speech activated_speech="Caution fire Station ahead" approach_beep_spoken_type=0 approach_beep_speech=0 approach_beep_sound=0 overspeed_spoken_type=0 overspeed_speech=0 overspeed_sound=0 [speedcam_category:15] activated_spoken_type=speech activated_speech="Change taxi zone" approach_beep_spoken_type=0 approach_beep_speech=0 approach_beep_sound=0 overspeed_spoken_type=0 overspeed_speech=0 overspeed_sound=0 [speedcam_category:16] activated_spoken_type=speech activated_speech="Caution give way" approach_beep_spoken_type=0 approach_beep_speech=0 approach_beep_sound=0 overspeed_spoken_type=0 overspeed_speech=0 overspeed_sound=0 warn_distances="0:200" [speedcam_category:18] activated_spoken_type=speech activated_speech="Caution speed breaker" approach_beep_spoken_type=0 approach_beep_speech=0 approach_beep_sound=0 overspeed_spoken_type=0 overspeed_speech=0 overspeed_sound=0 warn_distances="0:500" [speedcam_category:19] activated_spoken_type=speech activated_speech="Caution Children ahead" approach_beep_spoken_type=0 approach_beep_speech=0 approach_beep_sound=0 overspeed_spoken_type=0 overspeed_speech=0 overspeed_sound=0 warn_distances="0:100" [speedcam_category:20] activated_spoken_type=speech activated_speech="Caution dangerous Turn" approach_beep_spoken_type=0 approach_beep_speech=0 approach_beep_sound=0 overspeed_spoken_type=0 overspeed_speech=0 overspeed_sound=0 warn_distances="0:500" [speedcam_category:21] activated_spoken_type=speech activated_speech="Caution tunnel ahead open your lights" approach_beep_spoken_type=0 approach_beep_speech=0 approach_beep_sound=0 overspeed_spoken_type=0 overspeed_speech=0 overspeed_sound=0 warn_distances="0:500" [speedcam_category:22] activated_spoken_type=speech activated_speech="POI" approach_beep_spoken_type=0 approach_beep_speech=0 approach_beep_sound=0 overspeed_spoken_type=0 overspeed_speech=0 overspeed_sound=0 warn_distances="0:1000" [speedcam_category:23] activated_spoken_type=speech activated_speech="Police department" approach_beep_spoken_type=0 approach_beep_speech=0 approach_beep_sound=0 overspeed_spoken_type=0 overspeed_speech=0 overspeed_sound=0 [speedcam_category:31] activated_spoken_type=speech activated_speech="Caution dangerous point" approach_beep_spoken_type=0 approach_beep_speech=0 approach_beep_sound=0 overspeed_spoken_type=0 overspeed_speech=0 overspeed_sound=0 warn_distances="0:500" [camera1] maxdistance=500 minzoom2d=50 maxzoom2d=200 defaultzoom2d=300 minzoom=25 maxzoom=60 minangle=70 maxangle=82 defaultzoom3d=45 defaultangle=80 angleoffset=65 speedzoom=1 speedangle=1 overview_enabled=1 overview_distance=500 overview_zoom3d=50 overview_angle=80 [camera11] maxdistance=500 minzoom2d=50 maxzoom2d=300 defaultzoom2d=400 minzoom=25 maxzoom=60 minangle=70 maxangle=82 defaultzoom3d=50 defaultangle=80 angleoffset=43 speedzoom=1 speedangle=1 overview_enabled=1 overview_distance=500 overview_zoom3d=50 overview_angle=80 [vr] disabled=0 ---------------------------------- Quote Link to post Share on other sites
P4ND4 Posted November 27, 2012 Report Share Posted November 27, 2012 I was able to successfully install the mod, but was wondering if there was any way to revert back to stock if I ever needed to do so. I did the necessary backups, so I assume it is possible? Quote Link to post Share on other sites
Moff25 Posted December 10, 2012 Report Share Posted December 10, 2012 Are all the source files for this mod still available somewhere? Quote Link to post Share on other sites
P4ND4 Posted December 10, 2012 Report Share Posted December 10, 2012 Are all the source files for this mod still available somewhere? Sources/downloads are available on the first page from the OP. Quote Link to post Share on other sites
P4ND4 Posted December 10, 2012 Report Share Posted December 10, 2012 Here's a pic for reference of the mod that it actually works if done correctly. Quote Link to post Share on other sites
saman Posted December 15, 2012 Report Share Posted December 15, 2012 Pionara is possible to downgrade from 2.001 to 1.004 stock firmware? Quote Link to post Share on other sites
vicos.zt Posted March 17, 2013 Report Share Posted March 17, 2013 Whether anybody has WINCEIMG.bin and WINCEIMG.CKS for AVIC F320bt? Quote Link to post Share on other sites
gavin corrin Posted April 12, 2013 Report Share Posted April 12, 2013 Dear pionara, do you have any minds about this issue: I'm so tired to launch IGO again and again after any restart of my car same here Quote Link to post Share on other sites
BoB_Xygene Posted April 25, 2013 Report Share Posted April 25, 2013 Hi guys, I have a F320BT on wich i run IGO Primo 2.3 and tcpmp. I have stumbled on the same problem of the software crashing after any hibernation of the navigation module. I've made some experiments and what i can tel for certain : - If i run into testmode : I have no blue tooth, the sound is very low, the backlight is is very low, the device resume from hibernation without crashing (desktop or igo or tcpmp) - if i run into HMIManager mode (direct execution or via app.dat in applib) : I have blue tooth, the sound is correct, the backlight is correct, the device crash anytime it gets out of hibernation (desktop or igo or tcpmp) Furthermode running in HMIMode causes problems to IGO and most notably it prevents the use of TTS voices (in Testmode the TTS voices runs ok). My conclusion : Having the HMIManager to run in background is required but its so shitcoded that it prevents other applications to run well. Things i tried and kind of like : Start the desktop in HMIMode, then i have all the unit fonctionnality set and run anything i want, and for IGO i removed all maps and pois of other countrys and it start alot faster. I read in this thread that some different version of AppsLib.dll may fix the resume from hibernation crash, i know i have 2 versions of it gonna try each. Reminder to myself : never ever again buy pioneer... Quote Link to post Share on other sites
Join the conversation
