beej Posted March 7, 2015 Report Share Posted March 7, 2015 Alright, I tried it. Absolutely nothing happened. I hooked up my USB drive to the App Radio 2 (SPH-DA100) and tried to follow the AppRadio+ instructions below. The first time I started at Step 3 to attempt and install AppRadio+ right over the AppRadio 2 firmware. Nothing happened. Second, I started at step 1 and attempted to install the AppRadio 1 (SPH-DA02) firmware and again nothing happened. I welcome any tips on installation. When I tried, the AppRadio started up as it normally does and asked to connect my smart phone; paid no attention to the USB drive. 1. update to the latest sph-da02 firmware 4.17. 2. download the sph-da01 firmware 2.64 3. extract the files from AppRadio_plus_26_264.rar, but not the appradio directory. 4. extract the CE66 folder from the sph-da01 firmware. 5. boot up the deck with the sd card. This will boot the deck to the desktop. 6. click start, programs, windows explorer. select the SD card directory. double click on the "UpgradeMPU.exe" this will install the sph-da01 firmware on the deck. when prompted, remove the SD Card before rebooting. 7. reboot the deck, check to make sure everything is working, you can check the firmware version on the settings page. 8. now extract all the files and folders from the AppRadio_plus_26_264.rar to the CD card. 9. reboot the deck again with the SD card in and start the install of the appradio plus. 10 remove the SD card after the install. 11 reboot and verify, you should see the new background on the screen. Quote Link to post Share on other sites
Dejan Posted March 22, 2015 Author Report Share Posted March 22, 2015 have you warning message when you start your appradio ? Quote Link to post Share on other sites
beej Posted March 23, 2015 Report Share Posted March 23, 2015 have you warning message when you start your appradio ? Yes, I have the warning message when I start my AppRadio (SPH-DA100). Do I need to wait for the warning message before plugging in the USB? I tried inserting the USB at different times (car off, car on/radio starting, car on/radio fully booted up) with no results. Quote Link to post Share on other sites
Dejan Posted March 30, 2015 Author Report Share Posted March 30, 2015 for install, plug SD CARD before turn on your appradio. Installation only with sd card no usb stick.... Quote Link to post Share on other sites
aranloutbac Posted September 22, 2015 Report Share Posted September 22, 2015 Bonjour, J'ai un SPH-DA02 en 4.17 Lorsque je lance l'installation un message s'affiche : "Version Installee0- Copie des fichiers non effectuée. Le pack va s'interrompre 264" Avez vous une idée du problème ? D'avance merci Quote Link to post Share on other sites
tokar2222 Posted June 4, 2016 Report Share Posted June 4, 2016 There any news about the sound driver? Quote Link to post Share on other sites
Join the conversation
