A FIX for Euro F900BT that hangs on splash screen with all Euro files needed
  • Replies 52
Помогите еÑли знаете
при загрузки прошивки поÑвлÑетÑÑ Ð¾ÐºÐ½Ð¾
the application failed to start last time. do you want to reset to factory defaults and lose all your POTs,tacks and settings?
и обновление оÑтанавливаетÑÑ
Что Ñ Ñтим делать?
Добрый день!
Помогите еÑли знаете как решить проблему прошивки AVIC F900BT
ПоÑле загрузки прошивки перегрузки
Ð’Ñплавает Ñообщение
Тhe application failed to start last time. do you want to reset to factory defaults and lose all your POTs,tacks and settings?
  • 2 months later...
I have the same problem as borys had - when trying to upgrade to 3.021 it does not boot into the "white screen mode" any suggestions ?
Regards
Frank
Hi lumax,
I've got the same error as you. So I copied Pioneer Update firmware V3.021 files with it's WINCE files to SD card, and tried "Upgrade from SD/USB (formated)" in service mode. So, it says - "Image Read 100%, then Write Image 100% - Restart your machine". When I turn it off and on again - it does not start white screen with update procedure.
Could you please describe what you've done exactly to fix this problem? Or maybe someone else know?
Thank You!
  • 3 weeks later...
  • 1 year later...
  • 4 years later...
Hi,
i trie to use this old thread, becaus i have here an old f900, which stucks on the splash screen. the test mode is going to work, but i could not find the old fw 2.009.
Is here still someone who can help me to get this thing working ?
Edit: it is working now, but i only found russian files...does anyone have the euro backup for me ?
Edited by b7turbo
See in the text
