JackTheRipper Posted July 1, 2012 Report Share Posted July 1, 2012 I got used f310, updated to 320bt (by soft), every time I find a radio station and I make it remember (by holding station no on display) then I detach the panel or simply leave the car (with panel attached) start again and the stations are missing. I have to find them again etc. Before updating there was the same situation so I thought the update will solve it. Quote Link to post Share on other sites
NorthTron Posted July 1, 2012 Report Share Posted July 1, 2012 Do any of your settings save? Or only radio presets Sounds like the CMOS battery is defective or your EEProm the settings are stored in is malfunctioning. Quote Link to post Share on other sites
JackTheRipper Posted July 1, 2012 Author Report Share Posted July 1, 2012 All the setting seems fine. When I do the pull up for a short time it's ok, when for longer ~hour time it's gone. The battery from the front panel is ok (at least when I check it's full or almost full, the panel is set to 'off' position). Or maybe it's not the front panel case or just a time of leaving the radio turned off (without ignition), how to check CMOS battery or second thing? Quote Link to post Share on other sites
JackTheRipper Posted July 2, 2012 Author Report Share Posted July 2, 2012 OK, solved. As I have VW I had to swap red and yellow cables between ISO and Avic. Quote Link to post Share on other sites
