akewt Posted September 7, 2012 Report Share Posted September 7, 2012 hi guys like the forum i'm having great difficulty connecting my htc one x running 4.0.3 on vodafone. appradio is running on the phone and its connected via the mhl lead but the apps button is greyed out. i can connect via bluetooth every now and then but its very sporadic. do i need a later/earlier android os? struggling here and begining to think i made a mistake! Cheers for any help. Kev Quote Link to post Share on other sites
Nerds 2 You Posted September 22, 2012 Report Share Posted September 22, 2012 I have a band aid solution to your issue which is annoying but it gets you up and running. I recently bought a One X and have the same issues as you but I have been getting by using the following technique. FYI my Galaxy S2 had the same issues when running the original ROM. Follow these instructions carefully and your phone will get hooked up to the AppRadio, unfortunately you will have to follow these steps every time you turn your car on until there is a permanent fix. The following assumes you have already paired your phone with the AppRadio and have had a successful connection at least once, if you haven't following these steps will get you hooked up the first time as well. Go to settings and go to the bluetooth settings, stay on that screen the entire time you are connecting the phone to the AppRadio Connect the phone to the AppRadio and start your car. The AppRadio should automatically start to try connecting to your phone, keep a close eye on your phone's screen and wait for the pairing request to pop up in the middle of the screen and quickly press "pair" , you only have about 1 second or less to press pair or the connection will fail. You might see the pairing request come up twice, just hit pair quickly again and you will be connected and stay connected until you turn the car off. The reason I say to go to the bluetooth settings first is because while you are on that screen the pairing request comes up in the middle of the screen, otherwise you have to pull down the task menu, press on the pairing request, wait for the popup the click pair and most of the time it takes too long and the connection completely fails. Hope this helps, it's annoying but it lets you use your One X with your AppRadio. Quote Link to post Share on other sites
bigstu Posted September 24, 2012 Report Share Posted September 24, 2012 I have installed tasker on my one x, is there any way it can be set to accept the pairing request automatically? Quote Link to post Share on other sites
scotty94 Posted January 28, 2013 Report Share Posted January 28, 2013 Hi Guys I was wondering if anyone could help me, I am having problems connecting my Htc One x to the app radio 2 I can succesfully connect the bluetooth using the pair method which is a litttle bit annoying but does work. However i cannot get any other communication with the unit when connected via a mhl adapter with the app running etc. My htc is running on 4.1.1 and the appradio app is up to date as is the actual head unit. Would rooting the phone and using arliberator fix this issue? Any help is appreciated thanks Scott Quote Link to post Share on other sites
400ixl Posted January 29, 2013 Report Share Posted January 29, 2013 If the pioneer app isn't connecting with the HU then ARL won't either. What MHL adapter have you got? There are a lot of fake ones out there. Also, when connecting the icon for appmode on the HU changes, if you press on it you will see the percentage go up and maybe get a fail message. What do you see? Quote Link to post Share on other sites
