ccbadd Posted November 23, 2012 Report Share Posted November 23, 2012 I have looked and looked and can not find where people are change the appmode from wired to BT, any help? Quote Link to post Share on other sites
Alfa147x Posted November 24, 2012 Report Share Posted November 24, 2012 This what the files look like. Should I put the content of SD1 on the root of the SD card? Or both SD1 and SD2 at the root? Thanks! Edit: I'm an idiot. I was using the wrong file. Quote Link to post Share on other sites
anttid Posted November 26, 2012 Report Share Posted November 26, 2012 I'm doing the mod shortly. Can I use a 1GB card for card 1? Quote Link to post Share on other sites
pionara Posted November 26, 2012 Author Report Share Posted November 26, 2012 no, you need one 4gb card only. anttid, are you in New Jersey? Quote Link to post Share on other sites
TTalma Posted November 26, 2012 Report Share Posted November 26, 2012 Thanks for the great post. I just upgraded my x920BT from the original software shipped with the radio using the super easy method at the beginning of this post. The upgrade worked flawlessly. After installing though I went to install the pioneer app on my phone only to find out the app doesn't work on the Samsung Galaxy S3 yet. So I haven't been able to test that but everything else is working great! Quote Link to post Share on other sites
Alfa147x Posted November 26, 2012 Report Share Posted November 26, 2012 I messed up my Bluetooth during this. The firmware shows up as blank. Does anyone know where I can get the update file? Thanks! Quote Link to post Share on other sites
757CC Posted November 27, 2012 Report Share Posted November 27, 2012 Many thanks! The supereasymethod is great! Works like a charm on my X920bt. Quote Link to post Share on other sites
pionara Posted November 27, 2012 Author Report Share Posted November 27, 2012 I messed up my Bluetooth during this. The firmware shows up as blank. Does anyone know where I can get the update file? Thanks! the new bt firmware is part of this update in the FIRMWARE folder. Just do a cold-reset of your unit. Remove all power, i.e., pull radio fuse and/or disconnect BUP (yellow) and ACC (red) power for at least 30 seconds. Quote Link to post Share on other sites
Alfa147x Posted November 27, 2012 Report Share Posted November 27, 2012 Say I've already finished this how do I get the updater to try again? I somehow managed to do this: Platform version: 4.000Application version: 4.010 Version: 4.000 ..... Bluetooth firmware version: _____ I'm hoping if I can get the updater to run I'll be able to fix my bluetooth problem. Thanks, Alfa Quote Link to post Share on other sites
pionara Posted November 27, 2012 Author Report Share Posted November 27, 2012 I'm hoping if I can get the updater to run I'll be able to fix my bluetooth problem. no - you dont run the updater again. You upgrade the bluetooth from settings, bluetooth settings, firmware menu. But if you don't see current firmware version, do cold-reset like i mentioned earlier Quote Link to post Share on other sites
Alfa147x Posted November 27, 2012 Report Share Posted November 27, 2012 no - you dont run the updater again. You upgrade the bluetooth from settings, bluetooth settings, firmware menu. But if you don't see current firmware version, do cold-reset like i mentioned earlier I don't know how I missed your post! I'll try that in the morning and report back. I don;t really know how I got 4.0 on this thing. I installed HACKMODE and it messed my av.exe up. I read somewhere to copy a all the of files from the "AVICZ110" folder into the PRG0 folder. So I think that "updated" half of my nav and the other half was not updated. Just ran the updater now. Everything looks good. Should I still do the cold reset? One question: What's the difference between PRG0 and PRG1? I noticed somewhere someone said (for another tutorial) to delete PRG1. Is that just where the new update is installed? Thanks! Quote Link to post Share on other sites
shiveringmonkey Posted November 27, 2012 Report Share Posted November 27, 2012 Worked perfectly for my X920-BT --> X940-BT! Many thanks!! Quote Link to post Share on other sites
reinkarnation Posted November 27, 2012 Report Share Posted November 27, 2012 worked perfectly for me aswell, z110 updated to -z120-z130-z140 Thanks alot!! Also the whole removing the voice navigation control .. dumb idea Quote Link to post Share on other sites
gregbj33 Posted November 28, 2012 Report Share Posted November 28, 2012 Ok, Just updated, everything went as smooth as ever. Only thing is Blutooth version showing 3.1.1 and the Firmware Update button not lit up to press and update. Is there another step to do. I left SD card in when it reboot it said begin update, I said no and went into blutooth settings. Any advice Quote Link to post Share on other sites
pionara Posted November 28, 2012 Author Report Share Posted November 28, 2012 Only thing is Blutooth version showing 3.1.1 and the Firmware Update button not lit up to press and update. make sure bluetooth is set to ON in previous menu. This one stumped me for a while too. Quote Link to post Share on other sites
