JOEYOGC Posted January 9, 2013 Report Share Posted January 9, 2013 everyone who uses a mac use unrarx to decompress the far file and it will work just follow step by step and in a half hour you will have your upgrade here's a link to free download of unRarX http://www.unrarx.com Quote Link to post Share on other sites
Boricua415 Posted January 10, 2013 Report Share Posted January 10, 2013 Nice thread but I am lost. I have the Z120BT and downloaded the torrent, copied dat and other file mentioned on a 8GB SD Card, turn on the car and inserted the sd card but nothing popped up prompting me for an update, didnt even see the card. I formated the card to fat32. Do I need to be in test mode? I am sure this has been mentioned but I see instructions for the other models. Quote Link to post Share on other sites
MikeKelso Posted January 10, 2013 Report Share Posted January 10, 2013 Nice thread but I am lost. I have the Z120BT and downloaded the torrent, copied dat and other file mentioned on a 8GB SD Card, turn on the car and inserted the sd card but nothing popped up prompting me for an update, didnt even see the card. I formated the card to fat32. Do I need to be in test mode? I am sure this has been mentioned but I see instructions for the other models. Â I have to ask only because I did this by mistake myself, did you unzip the torrent or just place it onto the card immediatly after downloading? I was in a hurry and threw it on at first which gets you no where. Quote Link to post Share on other sites
Alexei Navalny Posted January 10, 2013 Report Share Posted January 10, 2013 Nice thread but I am lost. I have the Z120BT and downloaded the torrent, copied dat and other file mentioned on a 8GB SD Card, turn on the car and inserted the sd card but nothing popped up prompting me for an update, didnt even see the card. I formated the card to fat32. Do I need to be in test mode? I am sure this has been mentioned but I see instructions for the other models. I have to ask only because I did this by mistake myself, did you unzip the torrent or just place it onto the card immediatly after downloading? I was in a hurry and threw it on at first which gets you no where. Â Assuming that you didn't make the mistake Mike is talking about, did you follow step #3 in post #1?? To be slightly clearer: If you have an un-updated Z120 (that is - never installed Z130 CNSD-210-FM upgrade), then you need to replace CardInfo.cif (don't forget to uncompress the zip file). I am fairly certain if your Z120 has been updated with CNSD-210-FM (which effectively makes it a Z130), you should use the CardInfo.cif that was included in the torrent. Â One problem with pionara's instructions is he can't be sure which CardInfo.cif came with the torrent. Basically, how you acquired these files is not his concern. His instructions are for the original/legitimate CNSD-310-FM upgrade that was sold for the Z130. There is another CNSD-310-FM upgrgade that was sold for the older models. However, the only important difference between these two upgrades is the CardInfo.cif file. So if you still have this problem, try using alternate CardInfo files. Quote Link to post Share on other sites
Boricua415 Posted January 10, 2013 Report Share Posted January 10, 2013 Actually I have the AVIC-Z110BT. Not sure why I thought I have the Z120BT. Does this apply to the Z110BT? Sorry for the confusion. Quote Link to post Share on other sites
MikeKelso Posted January 10, 2013 Report Share Posted January 10, 2013 yes it does. I have the 110 as well. Quote Link to post Share on other sites
Boricua415 Posted January 11, 2013 Report Share Posted January 11, 2013 Thanks for everyones help on this, I finally got it. I just re-added the dat file than popped the sd card in to the stereo and booya lol I don't really see anything special with the 2012 maps. I was thinking I would have 3D street view. Quote Link to post Share on other sites
nsx93 Posted January 14, 2013 Report Share Posted January 14, 2013 Would it be best to make a back up before updating? Im learning bout the testmode thing from research, so far not positive on how to achieve that on my x920bt. Some say use the condihack method. One say, hold Home butoon, press revrs, frwd, rvers, frwd, revers, frwd. That will take to ur testmode screen. But im a lil hesitant because I dont want to brick the head unit. Â Suggestion? Quote Link to post Share on other sites
Alexei Navalny Posted January 14, 2013 Report Share Posted January 14, 2013 Would it be best to make a back up before updating? Im learning bout the testmode thing from research, so far not positive on how to achieve that on my x920bt. Some say use the condihack method. One say, hold Home butoon, press revrs, frwd, rvers, frwd, revers, frwd. That will take to ur testmode screen. But im a lil hesitant because I dont want to brick the head unit. Â Suggestion? Use the instructions in post #1`. It does not mention Hackmode or Testmode, so I don't know why you are asking this question in this thread. Don't make it harder than necessary. Quote Link to post Share on other sites
nsx93 Posted January 14, 2013 Report Share Posted January 14, 2013 Use the instructions in post #1`. It does not mention Hackmode or Testmode, so I don't know why you are asking this question in this thread. Don't make it harder than necessary. Â Will do. Thanks. Quote Link to post Share on other sites
xrevolutionx Posted January 16, 2013 Report Share Posted January 16, 2013 If you want to use BT for Pandora/Aha on your iPhone (or any smartphone), you have to set Settings/AV System Settings/App Connection to BlueTooth. Otherwise it assumes you are using a wired iPhone connection. hey mine does the same thing but if you pull up pandora on your phone and then hit play under the box on the pioneer touch screen, it will start to play pandora..if you want to skip next just hit the fwd button. you can pause and play. no pictures of album art or anything though. plus make sure its in the wireless bluetooth setting in app mode like stated before. Anyone get album art or aha radio to work? Quote Link to post Share on other sites
Alexei Navalny Posted January 16, 2013 Report Share Posted January 16, 2013 hey mine does the same thing but if you pull up pandora on your phone and then hit play under the box on the pioneer touch screen, it will start to play pandora..if you want to skip next just hit the fwd button. you can pause and play. no pictures of album art or anything though. plus make sure its in the wireless bluetooth setting in app mode like stated before. Anyone get album art or aha radio to work? Sounds like you are just using the BT audio source. Yes - that works - as any audio would coming from your phone over BT. When << and >> (prev & next) makes sense in context of the phone's app, those buttons on the HU will work. But what we are talking about is the Aha and Pandora dedicated screens on the AVIC (Z140). Switch to that source and your BT connected smartphone will start the Pandora app on the phone, display all the info - including album art, and even allow thumbs up/down. You can also change from among your previously configured Pandora favorite stations. Â I don't use Aha so I can't describe the features supported by the HU. Quote Link to post Share on other sites
xrevolutionx Posted January 16, 2013 Report Share Posted January 16, 2013 Sounds like you are just using the BT audio source. Yes - that works - as any audio would coming from your phone over BT. When << and >> (prev & next) makes sense in context of the phone's app, those buttons on the HU will work. But what we are talking about is the Aha and Pandora dedicated screens on the AVIC (Z140). Switch to that source and your BT connected smartphone will start the Pandora app on the phone, display all the info - including album art, and even allow thumbs up/down. You can also change from among your previously configured Pandora favorite stations. Â I don't use Aha so I can't describe the features supported by the HU. Â thanks for claryifing, Yeah i cannot get pandora or aha to work with my iphone 5 on ios6. when i hit connect it connects, but says its disconnected. even though it is definately connected. Quote Link to post Share on other sites
Alexei Navalny Posted January 16, 2013 Report Share Posted January 16, 2013 thanks for claryifing, Yeah i cannot get pandora or aha to work with my iphone 5 on ios6. when i hit connect it connects, but says its disconnected. even though it is definately connected. According to the Z140 Operation Manual (p133-134), you should use the wired connection for iPhones. Other (Androiod and Blackberry) smart phones only can do Pandora over BT. Quote Link to post Share on other sites
xrevolutionx Posted January 16, 2013 Report Share Posted January 16, 2013 According to the Z140 Operation Manual (p133-134), you should use the wired connection for iPhones. Other (Androiod and Blackberry) smart phones only can do Pandora over BT. ah thanks, Man the iphone 5 sucks at integrating my iphone 4s on ios5, could play youtube, amazon, netflix. It was great for the rear tv monitors and long rides. Quote Link to post Share on other sites
