petergun Posted June 24, 2013 Report Share Posted June 24, 2013 Copying is no problem in supertestmode. Normally you can add voices by installing them in the setup menu, however this fails on a "file not found" error. Quote Link to post Share on other sites
radeonorama Posted June 24, 2013 Author Report Share Posted June 24, 2013 Copying is no problem in supertestmode. Normally you can add voices by installing them in the setup menu, however this fails on a "file not found" error. Ah, right, i see! so you have basically tried both ways, installing via the ui and copying them manuually and neither worked right? let me see what my friend has available and ill hopefully be able to get the whole tsdata to you Quote Link to post Share on other sites
petergun Posted June 24, 2013 Report Share Posted June 24, 2013 Thanks Quote Link to post Share on other sites
radeonorama Posted June 24, 2013 Author Report Share Posted June 24, 2013 ThanksPeter, try the new file on the drive now. Its called TSData_2.rar. That is from another hu and is the entire tsdata folder and includes the dun dir's. I checked it against the other dun folder you have just tried and its file size is different so fingers crossed! Let me know how you get on. Quote Link to post Share on other sites
petergun Posted June 24, 2013 Report Share Posted June 24, 2013 Downloading now, I will install it tomorrow. Let you now the result Thanks again Quote Link to post Share on other sites
radeonorama Posted June 24, 2013 Author Report Share Posted June 24, 2013 Downloading now, I will install it tomorrow. Let you now the result Thanks again I would suggest you put the entire TTSData folder in place rather than picking bits out of it. Obviously take a copy of your existing one first! Quote Link to post Share on other sites
petergun Posted June 25, 2013 Report Share Posted June 25, 2013 I would suggest you put the entire TTSData folder in place rather than picking bits out of it. Obviously take a copy of your existing one first! Just finished copying the complete TTSData folder to my unit and TTS Dutch is working again. Thanks Radeonorama for your help. Quote Link to post Share on other sites
radeonorama Posted June 25, 2013 Author Report Share Posted June 25, 2013 Just finished copying the complete TTSData folder to my unit and TTS Dutch is working again. Thanks Radeonorama for your help. Sweet! Glad to hear it worked! Quote Link to post Share on other sites
nitram2012 Posted June 29, 2013 Report Share Posted June 29, 2013 Pioneer T1000-20494 The new Update Europa 2013 for Pioneer AVIC-F10BT, F20BT, F920BT, F9210BT, F9220BT Is there anything in use? Greetings Nitram Info: (Update Europa 2013 for Pioneer AVIC-F30BT, F930BT, F9310BT, F40BT, F940BT, F840BT, F8430BT is this one T1000-20496) Quote Link to post Share on other sites
Zagor1971 Posted June 29, 2013 Report Share Posted June 29, 2013 thx pionara !!! is a bad request , but i try for one time and f20 don't recognize the sd, is just show me 3 music files Ciao, aggiornato oggi F930BT Italiano.....nessun problema se segui attentamente le istruzioni del post originario...ti mantiene pure le impostazioni bluetooth... Quote Link to post Share on other sites
radeonorama Posted June 29, 2013 Author Report Share Posted June 29, 2013 Ciao, aggiornato oggi F930BT Italiano.....nessun problema se segui attentamente le istruzioni del post originario...ti mantiene pure le impostazioni bluetooth... Google translation: Hello, today updated F930BT Italian ..... no problem if you follow the instructions of the original post ... keeps you well bluetooth settings ... However, this is an English thread so please post in english. Thanks! Quote Link to post Share on other sites
20cils Posted July 16, 2013 Report Share Posted July 16, 2013 Hi all Perfect working on French F930BT tested without handbrake and also while driving. You can turn off your engine but not turn on it during the update Under is an "How to do" for French people : (Pour les français qui ont du mal avec l'anglais, vous demandez l'accès aux fichiers sur le 1er post, vous faites un don de 5/6€ via paypal pour y accéder, vous charger le fichier "CNSD-310FM EU 2012 Pioneer Update" que vous décompressez sur une carte micro SD. Vous chargez le fichier sur le 2nd poste(verinfo.dat) et vous remplacez celui qui est dans votre carte dans le répertoire "Update". Vous avez donc sur votre carte SD 2 répertoires et le fichier cardinfo.cif. Mettez la carte dans le poste, mettez le contact et attendez le message de mise à jour. La mise à jour dure environ 30 minutes. Vous pouvez me contacter en cas de problèmes. Quote Link to post Share on other sites
garabatak Posted July 27, 2013 Report Share Posted July 27, 2013 sd card %99 eror Quote Link to post Share on other sites
radeonorama Posted July 27, 2013 Author Report Share Posted July 27, 2013 sd card %99 eror Others with that problem have succeeded with the update using a Kingston MicroSDHC 8GB class 4 memory card. http://avic411.com/index.php?/topic/35601-cnsd-310fm-eu-2012-update/page-4&do=findComment&comment=259364 Quote Link to post Share on other sites
garabatak Posted July 28, 2013 Report Share Posted July 28, 2013 Others with that problem have succeeded with the update using a Kingston MicroSDHC 8GB class 4 memory card. http://avic411.com/index.php?/topic/35601-cnsd-310fm-eu-2012-update/page-4&do=findComment&comment=259364 What if I did not help Quote Link to post Share on other sites
