garabatak Posted July 28, 2013 Report Share Posted July 28, 2013 radio does not work you want to sd card (((((((( Quote Link to post Share on other sites
radeonorama Posted July 28, 2013 Author Report Share Posted July 28, 2013 I'm sorry, I'm not sure what that means. Have you read this entire thread as pretty much every issue found has been resolved. And have you tried the sd card I recommended? Quote Link to post Share on other sites
garabatak Posted July 28, 2013 Report Share Posted July 28, 2013 I'm sorry, I'm not sure what that means. Have you read this entire thread as pretty much every issue found has been resolved. And have you tried the sd card I recommended? I've tried 4 different sd card Quote Link to post Share on other sites
radeonorama Posted July 28, 2013 Author Report Share Posted July 28, 2013 I've tried 4 different sd card  And have you tried the sd card I recommended?  And make sure you're FAT32 Formatting your SD Card using the windows utility and make sure its a Complete format Quote Link to post Share on other sites
garabatak Posted July 28, 2013 Report Share Posted July 28, 2013 And have you tried the sd card I recommended? Â And make sure you're FAT32 Formatting your SD Card using the windows utility and make sure its a Complete format try to take 8 gb kingston Quote Link to post Share on other sites
garabatak Posted July 28, 2013 Report Share Posted July 28, 2013 (edited) Hello all, I have access to the CNSD-310FM EU 2012 update and have the CARDINFO.cif and VERINFO.DAT files for us EU users!!  I have now added a download for the CNSD-310FM US 2012 Pioneer Update too.    Just PM me and ill send you the link for a donation of £10 and ill invite you to download the update.  This will also give you access to the TSData backup for those who lost them when updating and the CNSD-310FM US 2012 Pioneer Update too.  I have the following languages available: CZC, DUN, ENG, FIF, FRF, GED, GRG, HUH, ITI, PLP, ROR, SPE, TRT  The link for the full update and files is here  http://goo.gl/P0LG6  FEEDBACK:  "Hi all Perfect working on French F930BT :-P" "I have upgraded my F930BT using the information in this thread, thanks! It's working great" "F9220BT Upgraded fine to version 4 and 2012 maps.With out this web site it would of not been possible. A big thanks to all" "It works on F930BT Thanks a lot, radeonorama" "hi all, worked for me on my f930bt :-P" "Just updated my 930BT yesterday. Worked flawlessly without any issues. Thanks a lot!"  INSTRUCTIONS  To do the update on an F930BT you just have to:  01) Download the rar from the link above above. 02) Extract it to a safe place. 03) Open the extracted folders and go into the Update folder 04) Replace the VERINFO.DAT with the one in pionara's second post on this thread. 05) Copy everything you extracted onto a clean 4GB+ SD Card which has been FAT32 Complete Formated (make sure that the files and folders on the route of the SD card are: FIRMWARE (folder) Update (folder) CARDINFO.cif (file)) 06) Put it in your Car (with the engine running or on a charger etc) 07) The Pioneer should reboot and start the update. 08) Follow the on screen prompts 09) Once completed, it may ask you to update again, if so, select no. 10) Enter Bluetooth settings and update the bluetooth firmware. (This seemed to take longer than i expected but dont worry, it does eventually get there!  The above files are not a hack to do the upgrade, they are the official Pioneer Update Files. The only hack is with the VERINFO.DAT which I believe all it does is bypass the passcode request when the update starts. There shouldnt really be any reason for this to fail.  As always, with anything like this, I would always advise you backup first!  Cheers, Radeonorama cards, even though I tried once again, not too wore photos   http://resimyukle.net/0] Edited July 28, 2013 by garabatak Quote Link to post Share on other sites
garabatak Posted July 28, 2013 Report Share Posted July 28, 2013 1. 4 gb sandisk class4 error 2. 4 gb trasdata class3 error 3. 8 gb sandsk ultra class10 error  I've tried this 3-card into the correct error is 99% remains sd card Quote Link to post Share on other sites
radeonorama Posted July 28, 2013 Author Report Share Posted July 28, 2013 1. 4 gb sandisk class4 error 2. 4 gb trasdata class3 error 3. 8 gb sandsk ultra class10 error  I've tried this 3-card into the correct error is 99% remains sd card As I said, Others with that problem have succeeded with the update using a Kingston MicroSDHC 8GB class 4 memory card. I have not had any problems doing the update with a SanDisk and a Nokia but the most frequently used with success is the Kingston above. Failing that, perhaps your download was corrupt. And did you perform a full format to fat 32 Quote Link to post Share on other sites
garabatak Posted July 29, 2013 Report Share Posted July 29, 2013 As I said, Others with that problem have succeeded with the update using a Kingston MicroSDHC 8GB class 4 memory card. I have not had any problems doing the update with a SanDisk and a Nokia but the most frequently used with success is the Kingston above. Failing that, perhaps your download was corrupt. And did you perform a full format to fat 32 8gb sd card kingston take today to try it. If you would like to donate thee again, whether the files again Quote Link to post Share on other sites
garabatak Posted July 29, 2013 Report Share Posted July 29, 2013 8gb sd card kingston take today to try it. If you would like to donate thee again, whether the files again Quote Link to post Share on other sites
garabatak Posted July 29, 2013 Report Share Posted July 29, 2013 The total size of the files are downloadedDo you have a file that is missing? Â Quote Link to post Share on other sites
garabatak Posted July 29, 2013 Report Share Posted July 29, 2013 kigston sd card worked flawlessly thanks pionara's thanks Quote Link to post Share on other sites
ovidiu1967 Posted August 2, 2013 Report Share Posted August 2, 2013 how can download firmware for avic f930bt. I destroy this device and need to repair (reflash). Any opinion and help is good. Thanx! Quote Link to post Share on other sites
husus1 Posted August 9, 2013 Report Share Posted August 9, 2013 follow general instructions here: http://avic411.com/i...asymethod-beta/ Â looks like verinfo.dat is same as us update so you can use this one which is same as on that thread: Â Â The existing cardinfo.cif should work with EU versions of F930 & F30, but if you have F10, F20, or F920, you can do this mod to cardinfo.cif - just open in text editor, search and replace exactly: KMQ1S8PF5CUQE7LKUX with X07EURX27EURX30EUR for the model f 9310bt is valid? thanks Quote Link to post Share on other sites
radeonorama Posted August 9, 2013 Author Report Share Posted August 9, 2013 for the model f 9310bt is valid? thanks yep, its exactly the same hardware at the f930bt with just a different plastic surround Quote Link to post Share on other sites
Join the conversation
