reinkarnation Posted December 1, 2012 Report Share Posted December 1, 2012 after the update... when im using directions the Mute doesnt work for music or radio.,,,, i set it to mute All and everything still no luck any help would be nice Quote Link to post Share on other sites
Alexei Navalny Posted December 2, 2012 Report Share Posted December 2, 2012 If you are referring to the souce (music) volume attenuation for driving instructions and voice commands, try disconnecting and reconnecting your car battery. That fixed it for me. Quote Link to post Share on other sites
tekpro Posted December 13, 2012 Report Share Posted December 13, 2012 What update are you referring to for the Z-140 as I don't see any firmware updates? Quote Link to post Share on other sites
MPTonyT Posted December 18, 2012 Report Share Posted December 18, 2012 Also in the AV menu ensure that the mute is set for Guide and Tel and it is set to all or 10/20 if that's what you prefer. Quote Link to post Share on other sites
rzylstra Posted January 14, 2013 Report Share Posted January 14, 2013 I have kind of same problem, radio doesn't mute. In AV settings I can't select all/10/20 Mute is set for guide and tel. This used to work fine. Any suggestions ? Quote Link to post Share on other sites
Alexei Navalny Posted January 14, 2013 Report Share Posted January 14, 2013 I have kind of same problem, radio doesn't mute. In AV settings I can't select all/10/20 Mute is set for guide and tel. This used to work fine. Any suggestions ? Disconnect the battery for a few minutes. Was this after the Z140 upgrade? Quote Link to post Share on other sites
