Therion Posted January 4, 2013 Report Share Posted January 4, 2013 Hello people! I just registered due to a problem with my Avic F900BT. Generally pleased with the unit and havent had any major problems with it. Until i decided to install a rear-view camera. I got a simple wired camera and had it installed. Seemed to work for a day, but then it wouldnt switch to the camera view when i put it in reverse. Turns out the reverse gear valve/switch of the car had issues. So i changed it. Now what happens is that the unit always stays with the black screen with the notice about rear view images could be reversed. It works when i go to reverse, but i cant get into any menu of the unit at all. Sometimes i have managed to press "menu" or "map" and it shows the start up disclaimer, i can press "ok" and go into the menu. But 99% of the time its just stuck on that screen. Today i pressed "Map" for a few seconds and it got me into my map and menu, but i obviously something is wrong, i shouldnt have to do this all the time. Any ideas? I cant say much about the wiring cause the car electrician did the connection, but we checked it a second time in case there was some mistake. Also i think that if it was some wire, it wouldnt work at all, not only sometimes. Is there a camera compatibility issue with this unit? My firmware and unit version is : Map Version : 02.000600 Version : 3.021000 Its a UK unit. Thanks for any help ! Quote Link to post Share on other sites
