susana Posted January 25, 2014 Report Share Posted January 25, 2014 Hl to tod@s have a preblema with one avic900bt 1. My unit has just hung on the pioneer splash screen and does not import what button i pushed it did not spend not 2 at all. Or it would be a sample of DESTINATION, contacts and buttons source AV, but the message " The system is starting, please wait " it would not disappear and if the button of menu is touched would be only me to accede to the adjustment, I do not have a safety copy and the mariner never gets up-to-date, already and well-read mens in the matter and the problem is k the links of unload estan fallen and in addition I need a copy of original and not updated safety .. thank you in advance and now already they are 2 my problems ... I write this post and it edits it with words k I do not write ... ufffffff Quote Link to post Share on other sites
bwl Posted February 7, 2014 Report Share Posted February 7, 2014 My AVIC-F900BT started having reboot problems after I took my vehicle in to have the check engine light fixed. It would go into the start up mode with the Pioneer logo start up and then it would shut off completely and go dark. I looked on here for links for update software but all of the links seem to be dead. So, I went to the pioneer website and used the update. However, now all I get is it starts up and stays in the pioneer logo screen and I am able to push menu and get into the menu, but nothing else works. It says I lost all my maps and it has the latest version from Pioneer on it. Can anyone please help me here? Thank you. Quote Link to post Share on other sites
guizmo Posted February 7, 2014 Report Share Posted February 7, 2014 Salut prendre les dossiers dans mon disque flash et à résoudre votre problème new 25/10/2014 HI ce est mon disque flash de télécharger Lui et Mettre Dans Votre Unité https://drive.google.com/file/d/0B4MAukIOceEXY1FYUEtOeUdtN1k/view?usp=sharing le Fichier is testmode https://drive.google.com/file/d/0B4MAukIOceEXS0l5MC1IQ28tLVE/view?usp=sharing Vous inquiétez pas ne If you Avez message de l'ONU d'Erreur sur le Fichier when Vous Ouvrez click en bas à droite ouverte et l'après Avoir vu le dossier à télécharger Les fichiers Quote Link to post Share on other sites
bwl Posted February 8, 2014 Report Share Posted February 8, 2014 Thank you guizmo....however....the file is too large and won't download through google which is where it is wanting to download from. Is there any way you can send me the files individually to make it take less memory to download?? Thanks. Quote Link to post Share on other sites
guizmo Posted February 8, 2014 Report Share Posted February 8, 2014 Hi don't worry just say ok for download and the download start and after the folder is ready to decompress and after only install him Quote Link to post Share on other sites
mohorney Posted February 9, 2014 Author Report Share Posted February 9, 2014 On this subject I've gotten many private messages asking to be pointed in the right direction and I reply to every one with the following message copied and pasted.......: A member on this forum contacted me back when I was having issues with my F900BT, his username is "anttid" he sells a reliable and perfect update and reboot Fix on eBay for around $24. it comes with the latest versions of maps and a hack installed that allows you to watch TV while you're driving in the front seat (i don't condone this practice)...... I would definitely suggest you go on eBay and search for his listing. And feel free to contact him in this forum.... good luck.... Quote Link to post Share on other sites
bwl Posted February 16, 2014 Report Share Posted February 16, 2014 Thank you guizmo for some reason it won't let me download the information but I took mohorney advice and bought the information on eBay which was great because in three days I got the information and the SD card with all the downloads and a screen by screen description of what to do it was very easy and I highly recommend it to anybody who needs this information it has the 4.0 update and all the 2013 maps and my unit is running great highly recommend. It was around $30 and like six dollar shipping.. it took like 30 minutes to install and everything is up and running great Quote Link to post Share on other sites
cshoresands Posted September 3, 2014 Report Share Posted September 3, 2014 Hi My F900BT - Canadian unit - suddenly stopped working. So I downloaded and started to install the firmware update from Pioneer.ca, but it gets stuck at about 7 minutes used time, 5 min remaining time. It says Copying Error: /Storage Card\LPUE080\APL2\iGo\ScanSoft\RealSpeakSolo\SPEECH\components\vf_madalena_r40_83swf11_1t Now the splash screen shows, and the unit reboots every 5 - 10 minutes back to the splash screen. Does anyone have the files to fix a Canadian unit ? Please let me know .. driving in silence is driving me MAD !! Thanks Quote Link to post Share on other sites
sb57 Posted October 24, 2014 Report Share Posted October 24, 2014 Same problem with a European AVIC F910BT following installation of firmware update- which had appeared to be error-free. Cycles through reboots. Can play music but restarts after around 3 minutes. No Nav available. Have downloaded Test Mode and have no idea what to do with it! Help with fixing this would be enormously appreciated. 4 hours a day in the car in silence? No thanks! Quote Link to post Share on other sites
josevt1986 Posted December 22, 2014 Report Share Posted December 22, 2014 hola tengo un f900bt y mi problema es que actualize el firmware oficial de pioner y ahora cada 4 minutos se reinicia me podrian ayudar gracias . Quote Link to post Share on other sites
standaman2 Posted December 23, 2014 Report Share Posted December 23, 2014 No problem. Hope I can help others as well I have just come across same problem, I live in australia though do you know if your fix will work here? Quote Link to post Share on other sites
