2013 EU UPDATE F30 F930 F9310 F40 F940 F840 F8430
  • Replies 444
Posted Images
Success on Avic-F40BT  :!:
First I tried to backup my German languages files wit Condis Hack 2.21...
No good idea, stuck on Bootscreen.
Deleting PRGx.flg doesnt help.
Flashed Pioneer version update 4.01 and unit works again.
Made a SD card with 2013 EU update and Voice directory with the needed voice file inside.
Flashed.... All ok, no Voice Files lost  :-P
Thank you, small donation on the way ...
The german files are avilable in the new update and no need to backup.
Where did you but them, are you sure that the files you but on the SD have been flashed, or only the original within the update were copied over?
the 2013 update from the first post of this thread comes with only 7 TTS voices : CZC, ENG, FIF, GRG, HUH, PLP and TRT.
the german voice present in the update is the recorded one (which can't spell streets name), not the TTS one so, yes it needs a backup... unless you don't care loosing this fonctionality ;)
Wow... I did not even know that this device can spell street names, my F9310BT never did that.
Can anybody share these extended TTS voices? I am especially interested in the German one.
I'm trying to update with a 32GB SD card, and does not work on my avic F40BT
Is it formated as FAT32? Please reformat an try again, complete format will be better, it takes longer but will be the best way. If it doesn't work, try with another 8GB SD or a Micro-SD with adapter. I had the same issue with 16GB, 8GB and 4GB SD, succeed only with 8GB Micro-SD (Sandisk).
Regards
