Jump to content
AVIC411.com
2013 EU UPDATE F30 F930 F9310 F40 F940 F840 F8430
  • Replies 444
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
  • 2 weeks later...
  • 2 weeks later...
@PUG
here are the instructions, you can put them in the first post.
INSTRUCTIONS
To do the update on an F930BT you just have to:
01) Download the files from the links above.
02) Extract them to a safe place.
03) Open the extracted folders and go into the Update folder
04) Replace the  VERINFO.DAT with this one.
05) Copy everything you extracted onto a clean 4GB+ SD Card which has been FAT32 Complete Formated
(make sure that the files and folders on the route of the SD card are:
FIRMWARE (folder)
Update (folder)
CARDINFO.cif
06) Put it in your Car (with the engine running or on a charger etc)
07) The Pioneer will ask you if you want to run the update choose ((yes)) the device will reboot and start the update.
08) Wait untill the update is completed
09) Once completed, it may ask you to update again, if so, select ((No)).
10) If you want to update your Bluetooth firmware then, enter Bluetooth settings and update the bluetooth firmware.
Please be sure that you did everything as mentioned above. It's better to make a backup of your system before updating.
For those with Avic F10BT,  F20BT or F920Bt
Download this  CARDINFO.CIF
Open the original CARDINF.CIF in text editor, search and replace this:
KJJARRH8R51UX72EUR
With
X07EURX27EURX30EUR
If you did everything correctly, you will have your AVIC updated to version 5.0 with the newest Europe Maps.
Regards
Hi! To update the F940BT its all the same like F930BT? No need to change CARDINFO.cif, only change the VERYINFO.dat right?
Best regards!!
Link to post
Share on other sites
BACKUP MODE
  • download the TESTMODE for your device and put to the root of your SD-CARD
  • instert SD to your AVIC, Pioneer Service Mode will appear,
  • move down and enter FILE MAINTENANCE,
  • go to USER, select COPY on the menu,
  • move up, and go to SD,
  • select PASTE on the menu,
  • once it finish - BACKUP IS DONE.
  • now hold EJECT button for 5s to get to sd card, take it and connect to pc,
  • copy USER directory somewhere safe on your computer and delete it from SD.
Link to post
perfect and easy instructions...but where can I download testmode for F940bt?
BACKUP MODE
Link to post
I've been keeping an eye for 2014 updates.
Not confident they will be released.
The 2014 maps are out for the F50BT, F950DAB etc but not the models here.
I've just purchased the F50BT updates so will be interesting to see if the maps can be transferred over to a hacked F930BT update file or not....
Link to post
Hello Pug,
I have an Avic F9310BT and asking myself exactly the same questions as you about the latest 2014 update. If anyone has any answers, he is welcome.
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
