Jump to content
AVIC411.com
2013 EU UPDATE F30 F930 F9310 F40 F940 F840 F8430
  • Replies 444
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
  • 3 weeks later...
I've patched the navi.exe for v 5.00 (update 2013). This is for an AVIC-F940BT
Instructions on how to patch it yourself:
applicable to:
Z110-140, X920-940, X9310, X9220, F920, F940, F940BT, F10-40
what it does:
gets rid of the caution nag screen at startup
assumes you understand hex editing and can navigate testmode file manager. If not, use youtube search for "avic testmode"
    determine your application version. go to settings, service info, and hold very top left corner down.
    use testmode "file maintenance" to grab a copy of your existing navi.exe at USER\PRGx\APL\Navi.exe (where PRGx = PRG1 if USER\PRG.FLG file exists, or PRG0 if USER\PRG.FLG file does NOT exist)
    make sure to keep a backup of your original navi.exe somewhere safe
    with hex editor (like HxD) change the bytes at the offset for your application version (see below) from 05 00 00 0a to 00 00 a0 e1
    replace original navi.exe on your unit with your edited one
3.001 @ offset be4bc
4.000 @ offset bede4 (z140/x940 original version)
4.010 @ offset bee20 (this is older units upgraded to 2012 software)
5.000 @ offset BEBFC
I've attached the already patched Navi.exe
If someones interested in the full 2013 update (including this patch and patched verinfo.dat) let me know.
It's ready to put on a SD card and simple to install on your F940BT
Navi.zip
Link to post
Share on other sites
hello, i tried to update my avic f10 bt, i put the sd card it started and then at 92 % it tells me rong sd introduce the corect sd card and it does this over and over no mather what i do, how can i make it work with or without the update, please help all it does now it shows the message insert the sd card to continue
Link to post
  • 2 weeks later...
  • 2 weeks later...
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
