seiskneko Posted February 15, 2014 Report Share Posted February 15, 2014 I have a Pioneer AVIC-X920bt and I´m getting problems while I try navigate in GPS... It does not connect to satelliteIf I enter in System to verify the sinal I get: GPS antenna problem detected. Contact dealer or service Center.If I enter in 3D calibration I get: sensor initializing...I had read some posts and they said to do a hard reset and maybe the problem would resolve.But, how to do it?I removed the baterry cables for 15 minuts and it appears that did not reseted, because the colors of the device did not change.So, how to reset the device? How to be sure the device was reseted?Thank´s Quote Link to post Share on other sites
oldracer Posted February 15, 2014 Report Share Posted February 15, 2014 Did the problem just start or have you had it the whole time? If it just started, what has changed with the head unit? Did you just put the unit in and if so is it a new unit and everything came out of the box? If it just started and nothing has changed, the sensor antenna may have failed? Quote Link to post Share on other sites
Jayson73 Posted May 30, 2018 Report Share Posted May 30, 2018 I' having the same problem did you find out how to fix this problem Quote Link to post Share on other sites
