rabidgeek Posted February 26, 2014 Report Share Posted February 26, 2014 Hey - I used the service test disc, as I don't care much for the music that's already on my Z1's hard drive. Did everything right, pulled the drive out, borrowed my roommate's 3 in 1 drive adapter. Plugged the Z1's hdd right in and... time-out I have a hackintosh, a pc running Mac OS X Mavericks. I've got this 3-in-1 ide to usb adapter plugged in usb 2.0 port (tried 3.0 no luck either) i plugged in another hard drive, and it shows up in both Mac and Windows XP (running XP on virtual box) BUT the Z1 hard drive does not show up AT ALL. what's going on? edit - forgot to add, i've got Oracle VM Virtual Box all set up. it recognizes the ide to usb bridge, everything works just fine, other stuff shows up as it should... EXCEPT the z1 hard drive. Quote Link to post Share on other sites
garrettoomey Posted February 26, 2014 Report Share Posted February 26, 2014 Once it's unlocked correctly with the test disc, you can access it just like any other hard drive. Sounds like it's not unlocked, drive failed, or you connected the 3-1 incorrectly and fried the drive. Quote Link to post Share on other sites
rabidgeek Posted February 26, 2014 Author Report Share Posted February 26, 2014 I just put the drive back in my car. it boots up just fine. I re-ran the service test disc (pretty quick) and the area where it says "9 hdd flag set" has an * next to it. i'm guessing that means the drive IS unlocked? I plugged it in my computer again and it still doesnt show up. (I'm guessing it should show up in my mac os as it's the OS i first boot into) Quote Link to post Share on other sites
rabidgeek Posted February 26, 2014 Author Report Share Posted February 26, 2014 "Power off your PC and connect your AVIC Z1/Z2/Z3 hard drive as the master drive on your secondary IDE channel using the IDE Hard Drive Adapter. Make sure there are no other devices on this channel. Power on your PC." I didn't do this step... my hackintosh has three hard drives. One primary, SSD, two SATA. When I plugged my extra SATA hard drive in to this ide to usb adapter, it shows up right away, so I figure the same should apply to this Z1 hard drive? Quote Link to post Share on other sites
rabidgeek Posted February 26, 2014 Author Report Share Posted February 26, 2014 installed hdd unlock wizard on windows xp running in virtualbox. it doesn't detect the hard drive, and says that it wont recognize hard drives through USB. this usb to ide converter is my only option right now... is there any other way? Quote Link to post Share on other sites
garrettoomey Posted February 27, 2014 Report Share Posted February 27, 2014 Does your USB adapter have a separate power supply? The drive will NOT power with USB power. If the drive is working in the AVIC, but not spinning up connected to the PC, confirm the power source... Quote Link to post Share on other sites
cprestes00 Posted March 24, 2014 Report Share Posted March 24, 2014 hey everyone I have the z2 and is doing the same thing hdd not found, I got one hard drive from ebay with the update but still doing the same thing can anyone help me with the whole procedureto fix thx Quote Link to post Share on other sites
Neodark84 Posted June 17, 2015 Report Share Posted June 17, 2015 Hola... Alguien por aca... Estoy en ese mismo brickeo... eso si que yo estoy con bloqueo del hdd, ya que eh cambiado carpeta PRG 0 y al volver a colocar el hdd en el vehiculo sale ERROR.... Por favor... alguna idea de desbloquear el HDD por convertidor ide usb... GRACIAS Quote Link to post Share on other sites
