tbrown5175 Posted May 7, 2014 Report Share Posted May 7, 2014 So I've tried to update my X910BT with the above and I replaced the cardinfo file with both the above (seperately of course). My system only recognizes the media files and does not update. I am on version 3.020100. Is there a way I can use this update, or am I just SOL? I tried formatting my SD Disk and that didn't help either. Thanks. Quote Link to post Share on other sites
rgarjr Posted May 8, 2014 Report Share Posted May 8, 2014 Not certain if this update is for the X910BT, maybe only X920BT and up. Quote Link to post Share on other sites
itsme337 Posted May 8, 2014 Report Share Posted May 8, 2014 can I install this on a usb flash or does it have to be a sd card Quote Link to post Share on other sites
rgarjr Posted May 8, 2014 Report Share Posted May 8, 2014 its always SD. Quote Link to post Share on other sites
anttid Posted May 10, 2014 Report Share Posted May 10, 2014 So I've tried to update my X910BT with the above and I replaced the cardinfo file with both the above (seperately of course). My system only recognizes the media files and does not update. I am on version 3.020100. Is there a way I can use this update, or am I just SOL? I tried formatting my SD Disk and that didn't help either. Thanks. This update isn't for your radio. Quote Link to post Share on other sites
tbrown5175 Posted May 13, 2014 Report Share Posted May 13, 2014 rgarjr and anttid, Thank you for your responses. Quote Link to post Share on other sites
sgtvoltron Posted May 16, 2014 Report Share Posted May 16, 2014 Worked like a charm on my z130BT. Showed my gratitude via PayPal. Quote Link to post Share on other sites
mistermarc Posted May 18, 2014 Report Share Posted May 18, 2014 I have z110bt with the cnsd-11fm update, I used the card that came with that and it says wrong card and will not move from that screen? I tried a hard reset still nothing. Quote Link to post Share on other sites
mistermarc Posted May 20, 2014 Report Share Posted May 20, 2014 Ok fixed problem, had to use the 2012 file. Quote Link to post Share on other sites
jeffro312 Posted May 22, 2014 Report Share Posted May 22, 2014 is anyone having problems downloading this... mine will get most of the way through then just tell me download failed 4 times now takes like 3 hours each time quite agrivating any ideas? Quote Link to post Share on other sites
jeffro312 Posted May 22, 2014 Report Share Posted May 22, 2014 well i finally succesfully downloaded files unzipped to sd card copied other file over and when inserted into z140bh nothing happens doesnt pop up with update as instructions tell me do i need testmodekey? Quote Link to post Share on other sites
misterwoofwoof Posted May 24, 2014 Author Report Share Posted May 24, 2014 All you have to do is unzip the files and put them in the root of your SD card, then place the CARDINFO.cif from here CARDINFO.zip into your SD card. Quote Link to post Share on other sites
dos0711 Posted May 29, 2014 Report Share Posted May 29, 2014 Worked like a champ on my x920bt. VR still works for music on iPod. Quote Link to post Share on other sites
pcguy760 Posted May 29, 2014 Report Share Posted May 29, 2014 I have a z130bt updated to z140bh (software update) so do I use the z140bh instructions and file or z130? Also, is there a way to install this update in testmode? I have another unit that has corrupt files and will only go to testmode... Quote Link to post Share on other sites
anttid Posted May 30, 2014 Report Share Posted May 30, 2014 I have a z130bt updated to z140bh (software update) so do I use the z140bh instructions and file or z130? Also, is there a way to install this update in testmode? I have another unit that has corrupt files and will only go to testmode... Z130 and Z140 updates are the same! You can always manually install files, but you have to know what files to load! My advise to everyone is to stop trying to do something you have no knowledge about! You either deleted needed files or installed Condi hack, which in turn crippled your system! Send it to Pioneer to fix and stop trying shit you don't have any knowledge about. Quote Link to post Share on other sites
