photousa Posted July 28, 2014 Report Share Posted July 28, 2014 Has anyone been able to get the Appmode screen up and running, (visible) on an Avic Z110BT, upgraded to 5.1? I'm using the stock, CD-1U51v 30 pin cable with an iPhone 5. Have the Appmode App installed on my iPhone, but have not been able to get the Appmode screen to show up, (I get the vertical icons on the right side of the screen, but I don't get the large horizontal icons in the center of the screen that are supposed to scroll, left and right). Perhaps it's not possible with a Z110BT. When I go into settings > AV settings, the system does not give me an iPhone option, I only have an iPod option. Anyone else have a similar frustration? Quote Link to post Share on other sites
photousa Posted July 31, 2014 Report Share Posted July 31, 2014 Has anyone been able to get the Appmode screen up and running, (visible) on an Avic Z110BT, upgraded to 5.1? I'm using the stock, CD-1U51v 30 pin cable with an iPhone 5. Have the Appmode App installed on my iPhone, but have not been able to get the Appmode screen to show up, (I get the vertical icons on the right side of the screen, but I don't get the large horizontal icons in the center of the screen that are supposed to scroll, left and right). Perhaps it's not possible with a Z110BT. When I go into settings > AV settings, the system does not give me an iPhone option, I only have an iPod option. Anyone else have a similar frustration? Anyone out there? Quote Link to post Share on other sites
tmedic Posted July 31, 2014 Report Share Posted July 31, 2014 I updated my x930bt to x940bt firmware. now I am wondering which CARDINFO.zip I use for the map update in misterwoofwoof's post. Do I use the one for the 930bt or 940bt. Thanks in advance! Quote Link to post Share on other sites
Alexei Navalny Posted July 31, 2014 Report Share Posted July 31, 2014 Anyone out there?Sorry - I can't help - don't have an iPhone and never use Appmode. Quote Link to post Share on other sites
BlakeStone Posted July 31, 2014 Report Share Posted July 31, 2014 I updated my x930bt to x940bt firmware. now I am wondering which CARDINFO.zip I use for the map update in misterwoofwoof's post. Do I use the one for the 930bt or 940bt. Thanks in advance! It doesn't hurt or damage anything to try one and then the other if one doesn't work, but it may overwrite the x940bt update... not positive on that. Quote Link to post Share on other sites
funks Posted August 1, 2014 Report Share Posted August 1, 2014 Was able to update my X920BT to the 2013 maps (5.0 firmware, and 3.32 BT firmware) but has anybody been able to update the X920BT to firmware 5.1? I wrote the contents of the file AVIC-X940BT_FW-Update-v5.100.zip to the a FAT32 formatted Micro SD card and the unit reboots to the UCOM screen just fine. When I select and chose "System uCom Write", i'm unable to continue because the next screen just shows [ --------- ] on the SD card instead of 8.05 (the uCom has 8.01). Seems as if the updater is checking to see if I have a X940 (and looking at a different folder). Hmmm, wasn't able to to the System uCom write but the APP VERSION is 5.1 on my setup. So I guess the first part of it did work before the uCom screen came up. Quote Link to post Share on other sites
photousa Posted August 2, 2014 Report Share Posted August 2, 2014 Sorry - I can't help - don't have an iPhone and never use Appmode. Thanks all the same Ron, I appreciate all of your help ! Quote Link to post Share on other sites
Shane H Posted August 3, 2014 Report Share Posted August 3, 2014 Just wanted to say Thank You ! ! ! Quote Link to post Share on other sites
murphdawg Posted August 5, 2014 Report Share Posted August 5, 2014 Just so I understand completely.... I have a Z110BT that is upgraded to the Z130BT. Are these 2013 maps equivalent to the Z140BT where the map VR is lost. Service Info Screen shows version is currently 3.000 and the bluetooth firmware is currently 3.22. I read in another post that the bluetooth fw update, even to just version 3.24 provides some added options and am wondering if it was just possible to update the bluetooth only assuming that does not affect the VR. Quote Link to post Share on other sites
Alexei Navalny Posted August 5, 2014 Report Share Posted August 5, 2014 murphdawg, on 05 Aug 2014 - 5:32 PM, said: Just so I understand completely.... I have a Z110BT that is upgraded to the Z130BT. Are these 2013 maps equivalent to the Z140BT where the map VR is lost. Service Info Screen shows version is currently 3.000 and the bluetooth firmware is currently 3.22. I read in another post that the bluetooth fw update, even to just version 3.24 provides some added options and am wondering if it was just possible to update the bluetooth only assuming that does not affect the VR. Yes, you'll loose NAV VR. You can try just the BT firmware. If you don't like, it is easy to back out (if you have your old v3.0 upgrade SD). The BT update function will let you install older versions. I doubt you'll see any new functionality - just bug fixes and maybe broader phone support. To just D/L new BT, get the 5.1 update and copy only the /Firmware folder to the SD. You probably know the rest. Quote Link to post Share on other sites
rip1212 Posted August 13, 2014 Report Share Posted August 13, 2014 If anyone can help or point me in the right direction is really appreciate if. I updated my x920BT, and also updated the BT firmware and everything went perfect. These past few days I've noticed that my GPS is way off, sometimes even assuming I'm on entirely different road. I've tried searching oh how to calibrate the gps location, I've tried to troubleshoot the antenna, but have had no luck. Kind of defeats the purpose of having navigation when it doesn't work. 😢 I've read through a couple threads and it seems no one has faced this issue. Thanks in advance. Quote Link to post Share on other sites
mansonss Posted August 13, 2014 Report Share Posted August 13, 2014 Edit: NVM. Thank you uploader!! Quote Link to post Share on other sites
Sabot1812 Posted August 17, 2014 Report Share Posted August 17, 2014 Thank you so much for the update, you have solved all of my issues... Quote Link to post Share on other sites
kuture Posted August 18, 2014 Report Share Posted August 18, 2014 Just wanted to say thanks to misterwoofwoof for the update. Works flawlessly on my z120bt. Small donation sent. Keep us up with future updates. Quote Link to post Share on other sites
filebug Posted October 1, 2014 Report Share Posted October 1, 2014 i was wondering how i get new maps for my avic-x850bt. i can't seem to find much about this radio here. Also where can i find out what year maps i have on my radio? thanks for any help you guys can provide. Quote Link to post Share on other sites
