jovanny Posted November 11, 2014 Report Share Posted November 11, 2014 Having the same issue also. Quote Link to post Share on other sites
garychios Posted November 14, 2014 Report Share Posted November 14, 2014 Does the Firmware of the unit affect this update? For example, can I update the firmware to support a Iphone 5+ after I installed the Map Update first? Map Update + Hot Fix Firmware from Pioneer V5.100 Quote Link to post Share on other sites
jlblazin00 Posted November 16, 2014 Report Share Posted November 16, 2014 So I did this update and the firmware and maps installed flawlessly I updated the bluetooth and the version updated but now the unit will no longer connect to my phone. When selecting the unit via my phone it says unavailable! And second off I'm gonna get the new iphone 6 so do I just need a lightning adapter? It's a x930bt that's been upgraded to a x940bt with the current software any help appreciated thx Quote Link to post Share on other sites
Remha Posted November 29, 2014 Report Share Posted November 29, 2014 Have an x930bt upgraded to x940bt. Curious will Iphone EVER play Pandora through Bluetooth such as my current Galaxy Nexus (without a direct connection) I would like to be able to see the Pandora app on my deck and not just play audio through the Bluetooth Audio app. Quote Link to post Share on other sites
Remha Posted November 29, 2014 Report Share Posted November 29, 2014 I am actually debating about picking up an iphone 6 as Verizon (IDIOTS) have no released the info on the Nexus 6. Quote Link to post Share on other sites
Remha Posted November 29, 2014 Report Share Posted November 29, 2014 Ok so update. With this update, I was able to play any audio (ie pandora, youtube on my unit and see the artist song and track, HOWEVER, no thumbs up/down functions available on IPHONE as I had it connected through bluetooth AUDIO APP! However, with android, NO PROBLEMS with Pandora even thumbs up and down functions are present on the pandora APPLICATION! Quote Link to post Share on other sites
Remha Posted November 29, 2014 Report Share Posted November 29, 2014 Anyone know if the Pandora application works via bluetooth in our cars with the iphone??? Quote Link to post Share on other sites
Remha Posted November 29, 2014 Report Share Posted November 29, 2014 FYI I did this with x930BT and Iphone 6 connects fine with the 3.34 updated BT software. However I cannot get the Pandora app to connect. The only way you can connect BT audio with the iPHONE (Iphone 6 in my case) is via the Bluetooth Audio appication. Quote Link to post Share on other sites
Remha Posted November 29, 2014 Report Share Posted November 29, 2014 Was anyone able to add Appdata via the 5.1 update to get the BT audio to work with thumbs up/down through a Pandora app? Quote Link to post Share on other sites
techlogik Posted December 6, 2014 Report Share Posted December 6, 2014 I would like to thank everyone that helped me on this. I guess the 5th time is the charm. Steps I did for the X920BT: 1. Downloaded the file using Firefox version 29. 2. Did a reg. format to FAT32. (Not quick format) 3. Extract the zip file using 7-zip file program (freeware). I got no errors this time, even tested the file. Extracted right into the microSD card. (SanDisk Ultra 32GB Class 10) 4. Inserted the microSD card into unit, Update menu appeared. Whoa!!! Yup!! 5. Ran all updates time duration was like 30 mins. Plus the Bluetooth upgrade firmware also. Tip: Make sure your car battery is in good condition, my car battery was weak last night running it. Ran 4 times trying to update the 2013 map. Everyone have a wonderful weekend!!! Peace! Followed this for a 930BT, worked flawless. 1) Format 4GB SD card 16K block fast format FAT32 2) Extracted to desktop with 7zip 3) Copied Firmware, then Update then Cardinfo in that order individually 4) Put SDCard in car, ignition on, asked for update, then rebooted and did the update. 5) Did BT update afterwards Great stuff...donation coming. Quote Link to post Share on other sites
Alanluong Posted December 10, 2014 Report Share Posted December 10, 2014 The download link for the maps seems to be broken. Can someone please fix the link. Thank you in advance! Quote Link to post Share on other sites
Alexei Navalny Posted December 10, 2014 Report Share Posted December 10, 2014 The download link for the maps seems to be broken. Can someone please fix the link. Thank you in advance! Nothing wrong with the link. Just click "download" and ignore the errors/warnings, Or try this one directly to Google Drive. https://drive.google.com/file/d/0B3ckB07Umie-UVM4bnRVdUpJbjQ/edit Quote Link to post Share on other sites
Alanluong Posted December 11, 2014 Report Share Posted December 11, 2014 Thank you RonS! Quote Link to post Share on other sites
piranha Posted December 16, 2014 Report Share Posted December 16, 2014 I think I was able to soft hack for the Safe-Mode toggle, just by changing the following: Around offset 15aef0, change the value from 02 00 56 E3 to 09 00 56 E3. However, I'm not sure why it was recommended to change the following value as well (because I didn't, and I still got the toggle): offset 15aee0, change the value from 01 10 A0 E3 to 00 10 A0 E3. Quote Link to post Share on other sites
ckkris Posted December 22, 2014 Report Share Posted December 22, 2014 Hi Piranha , I am using firmware version 5.0 . I couldn't find the value '02 00 56 E3' for the offset 15aef0 in navi.exe located in USERS/PRG1. But I was able to find it navi.exe located in USERS/PRG0.But I am suppose to modify navi.exe in PRG1 as I have the PRG.FLG . Please let me know which navi.exe did you modify. Quote Link to post Share on other sites
Join the conversation
