Biaz0ne Posted March 12, 2014 Report Share Posted March 12, 2014 (edited) Hi There,i am a jung student from Germany and i bought one of these AppRadio last year. I couldn't wait until the new AppEx is coming out, so i decided to modify some of my AppRadio Apps.Let's have a quick look what i have done so far:Let me explain what's behind the Apps:Navi: Navgate Drive EuropeMusik: CarMediaPlayerInternet: CarBrowserPlaces: Beej!Parken: ParkopediaI also edited the "recently used Apps" icon.In Addition, i changed the images on my iPhone when there is a Connection with the Appradio. (In my Case i have a "GT" Logo from Ford on my Screen)Remember: Your iPhone must have a Jailbreak!TUTORIAL How-to change App Names & Icons in Appradio (3):(I’m using the Mac Version in this TUT)What you need:iPhone with Jailbreak (mine is on iOS 7.0.4)Appradio App installediFunBox @an Editor which reads XML (from xCode or the native TextEdit from Mac OS)Let’s start:Introduction:First of all, everything will happen inside the App of Pioneer. No other Applications will be modified. This is my first tutorial so if there are any Questions left -> Ask!Step 1:Close the AppRadio App on your iPhone!Open iFunBox and navigate to „User Applications“ —> „AppRadio“.I would suggest to switch to the list view, because there are a lot of files showing up later on.Step 2:Copy all of the Files (Appradio.app, Documents, Library …) to your computer.Step 3:Let’s begin with changing the App Names at your Appradios Screen:Go to: „Library“ - „Caches“ - „Recommended Apps“.In my Case there are 113 items.A lot of png files and one xml file which is important.If there is a file named „Apps_info_temp.xml“ just delete it.Now open the file „Apps_info.xml“.Step 4: Search for the App Name. For Example i want to change the „CarMediaPlay“ into „Music“.Then Search for the Name „CarMediaPlay“.You will see something like this:…<Strings><String><ISOLaungageCode>default</ISOLaungageCode><DisplayAppName>CarMediaPlay</DisplayAppName><StoreName>CarMediaPlayer</StoreName><Description></Description></String>…You only have to change the Text inside „DisplayAppName“.Change it to „Music“ then it looks like this…<Strings><String><ISOLaungageCode>default</ISOLaungageCode><DisplayAppName>Music</DisplayAppName><StoreName>CarMediaPlayer</StoreName><Description></Description></String>…Step 6:Safe the File! and Copy it to your iPhone. Remember to delete „Apps_info_temp.xml“ on your iPhone otherwise it will not work.Step 7:To Edit icons on your Screen you have to browse through the PNG’s inside the „Recommened Apps“ directory and search for your App.We want to Change the CarMediaPlayer icon to a good looking music icon.The „AppCode“ for this App is 511262089.Search this File.Now you have 2 Files. One is „511262089_launcher.png“ and one „511262089_recommended.png“As you can see you just have to edit the „511262089_launcher.png“. The other one is just for the Recommended Apps inside the AppRadio App.Just edit the png with an Image Editor like Fireworks, Photoshop….You can also use my music icon i added at the bottom of this post.Step 8:Replace the modified files on your iPhone and open the AppRadio App.Now you see your AppRadio in another way! (Step 9:) Save your "Apps_Info.xml" on your Computer. You have to replace it again when Pioneer updates their "Recommended Apps" section.Bonus:If you want to edit the icons „Contacts“ , „Maps“ , „Pictures“ which are native provided by Pioneer your have to Navigate to „AppRadio.app“ - „PGW_ICON_*.png“Here is a List of Filenames which you have to replace to have a new icon:PGW_ICON_CONTACTS.png - ContactsPGW_ICON_MAPS.png - MapsPGW_ICON_PHOTOS.png - PhotosPGW_ICON_RECOMMEDATION.png - Recommended Apps AppRadio_appicons.zip Edited March 17, 2014 by Biaz0ne Quote Link to post Share on other sites
fruitbat04 Posted March 12, 2014 Report Share Posted March 12, 2014 Neat! Definitely do a tutorial. Feel free to make it technical Quote Link to post Share on other sites
Biaz0ne Posted March 12, 2014 Author Report Share Posted March 12, 2014 Hi fruitbat04, i just updated my post above. If there are any questions feel free to ask! Quote Link to post Share on other sites
Teq Posted March 14, 2014 Report Share Posted March 14, 2014 This is awesome, I've been pondering this myself. Thanks for the write up. Quote Link to post Share on other sites
jlinnell98 Posted April 8, 2014 Report Share Posted April 8, 2014 This works using ifile as well, so far I've just replaced my phone screen when in appmode but everything works the same, here's how I did it 1. save the photo/icon you'd like to use to your photo library on your phone 2. open ifile - navigate to /var/mobile/media/DCIM/100APPLE (or similar) 3. select the photo you'd like to use, hit edit at the top right then select your photo, hit the clipboard at the bottom right 4. navigate to the appradio app, it's kind of hard to find so you'll have to look but it was under /var/mobile/applications/517f8d64-96b6-4fc8-a1cb-ce3790007299/appradio.app 5. I would recommend adding a bookmark to these folders (appradio & photos) so you can have quick access in the future 6. paste the photo into the appradio folder 7. find the photo/icon you are replacing. For the phone display on mine it was NX120_L_IP_001_iPhone5 8. copy the name of that photo then change it (can't have 2 photos named the same thing), I add a 1 to the end of the photo so I can change it back later and know where it is 9. find the photo you pasted in there (probably under IMG_ or something similar), change the name of that to the one you copied 10. Respring and see if it worked. Worked for me so now this displays instead of the appradio icon Quote Link to post Share on other sites
