jaytrey Posted March 7, 2007 Report Share Posted March 7, 2007 do you think you guys could give me a step by step on how to do it...i know there's a pic, but i ate paint chips when i was younger.... Quote Link to post Share on other sites
JasonH Posted March 7, 2007 Report Share Posted March 7, 2007 Step 1: Move Mute Wire to empty slot as shown above. Step 2: Ground the newly moved Mute Wire Step 3: Ground Parking Brake Wire Done Quote Link to post Share on other sites
07FX4SD Posted March 7, 2007 Report Share Posted March 7, 2007 Okay the bypass works for me too. Only thing is, now my car disables the controls if the car is in motion. After driving about a 1/4 mile I got a screen from the unit saying it detected that the parking brake wire was improperly disconnected. Then I noticed the navi search controls were disabled. The second I stopped at a traffic light they came back and then as soon as I started moving again they went away again. Hi, I'm having the same issue. What was your ultimate fix to get it working? Thank you in advance, Elliott Quote Link to post Share on other sites
MisFit Posted March 7, 2007 Report Share Posted March 7, 2007 he doesnt know what he's doing, i've done it three times in the last five days. works fine when you ground both wires. make sure you move mute wire to the right pin Quote Link to post Share on other sites
JasonH Posted March 8, 2007 Report Share Posted March 8, 2007 I cleaned this up. For the record: MisFit was referring to jaytrey's post about his installer. He wasn't personally attacking anyone. Grow up guys. Quote Link to post Share on other sites
jaytrey Posted March 8, 2007 Report Share Posted March 8, 2007 thank you for that Quote Link to post Share on other sites
PDSchweitzer Posted March 9, 2007 Report Share Posted March 9, 2007 I did the D3 bypass steps, but what exactly should I do as a test to verify the bypass is working ? Quote Link to post Share on other sites
coocho Posted March 9, 2007 Report Share Posted March 9, 2007 I did the D3 bypass steps, but what exactly should I do as a test to verify the bypass is working ? Drive it past 15mph and see if it will play video. See if you have the ability to enter new distinations using address search. Also, you should never get a warning about your parking brake beind connected incorrectly. Quote Link to post Share on other sites
zulustypes Posted March 11, 2007 Report Share Posted March 11, 2007 thanks! very helpfull! Quote Link to post Share on other sites
mcowger Posted March 11, 2007 Report Share Posted March 11, 2007 Okay the bypass works for me too. Only thing is, now my car disables the controls if the car is in motion. After driving about a 1/4 mile I got a screen from the unit saying it detected that the parking brake wire was improperly disconnected. Then I noticed the navi search controls were disabled. The second I stopped at a traffic light they came back and then as soon as I started moving again they went away again. Hi, I'm having the same issue. What was your ultimate fix to get it working? Thank you in advance, Elliott I got the same issue as well. I am 100% sure that the mute wire was moved to the right location and that it as well as the PB wire are grounded properly (confirmed using my multimeter). I did everything for the bypass (moved the mute wire, and grounded the parking brake) and it worked for the first 2 hours of my drive up to Santa Rosa. However, on the way back it reported that the Parking Brake is connected wrong and started disabling the functions it doesnt want me to have in motion. Ideas? http://gallery.cowger.us/main.php?g2_view=core.DownloadItem&g2_itemId=3926&g2_serialNumber=2 Quote Link to post Share on other sites
whtcrxghst Posted March 11, 2007 Report Share Posted March 11, 2007 Double check your connections. You need the pin to be firmly set into the new hole in the harness and you need a good ground for that wire and the parking brake wire Quote Link to post Share on other sites
Phanon_TC Posted March 12, 2007 Report Share Posted March 12, 2007 Here are some clear pictures I took close up of it incase you guys wanna use these also RCA cable for the bypass Picked out wire with eyeglass screwdriver Bypass finished Quote Link to post Share on other sites
coocho Posted March 12, 2007 Report Share Posted March 12, 2007 copied me with the eye glasses screw driver! Quote Link to post Share on other sites
jaytrey Posted March 12, 2007 Report Share Posted March 12, 2007 man...sorry guys, i know i have already brought it up once, but i just called two more installers in my area and they both said that they cannot bypass the unit because it is all firmware related. it can not be done manually by grounding and moving the wire into the empty slot. he was like yea i'm apart of avic411 too and it does not work. every one on this site said that it does. so is this guy just retarded or wtf is going on. Quote Link to post Share on other sites
mcowger Posted March 12, 2007 Report Share Posted March 12, 2007 Double check your connections. You need the pin to be firmly set into the new hole in the harness and you need a good ground for that wire and the parking brake wire I am very experienced with soldering and moving pins around connections. I am 100% sure that I connected them properly, and that they remain connected properly, as my multimeter shows basically no resistance through those pins. Quote Link to post Share on other sites
