thohidulk Posted February 7, 2017 Report Share Posted February 7, 2017 Dear DZO Which one we should try for Drz99? latest or previous one? Regards Karim Quote Link to post Share on other sites
krasi11 Posted February 7, 2017 Report Share Posted February 7, 2017 thanks the japanese strings changed to english but another problem is created. when you are in the navigation screen and press the menu hardware key to go to settings, the screen is distorted.... please see attached image Say what (file)you need and I'll send to you from my backup mrz77 Quote Link to post Share on other sites
fanourio Posted February 7, 2017 Report Share Posted February 7, 2017 Dear Krasi do you have maps or navigation backed up? Quote Link to post Share on other sites
maximumg Posted February 7, 2017 Report Share Posted February 7, 2017 Say what (file)you need and I'll send to you from my backup mrz77 thanks krasi, i had a backup of my mrz77 and i changed image.img. now i am back to stock images but at least they are not distorted. some japanese characters still show up on the images. maybe dzo can help with this? thanks Quote Link to post Share on other sites
dzo Posted February 7, 2017 Report Share Posted February 7, 2017 thanks krasi, i had a backup of my mrz77 and i changed image.img. now i am back to stock images but at least they are not distorted. some japanese characters still show up on the images. maybe dzo can help with this? thanks If you post a link to your backup Image.img, I'll take a look at it and see what the problem is. Quote Link to post Share on other sites
maximumg Posted February 7, 2017 Report Share Posted February 7, 2017 Hello dzo. I attach a copy of my mrz77 image.img https://www.dropbox.com/s/ckf0nkxrrnr1p4m/Image.img?dl=0 Quote Link to post Share on other sites
dzo Posted February 7, 2017 Report Share Posted February 7, 2017 Hello dzo. I attach a copy of my mrz77 image.img https://www.dropbox.com/s/ckf0nkxrrnr1p4m/Image.img?dl=0 OK, I made a quick update with your image, let me know if this works. https://www.dropbox.com/s/7oztdfghmen60il/Image_mrz77.img?dl=0 Don't use this on anything but mrz77 Quote Link to post Share on other sites
maximumg Posted February 8, 2017 Report Share Posted February 8, 2017 OK, I made a quick update with your image, let me know if this works. https://www.dropbox.com/s/7oztdfghmen60il/Image_mrz77.img?dl=0 Don't use this on anything but mrz77 thanks. it works now. see attached. i dont know if it was supposed to show text instead of dots though Quote Link to post Share on other sites
slavjn Posted February 8, 2017 Report Share Posted February 8, 2017 Hi DZO, you can make the background auto. instead of the blue.thank you Quote Link to post Share on other sites
dzo Posted February 8, 2017 Report Share Posted February 8, 2017 Hi DZO, you can make the background auto. instead of the blue.thank you I don't have time to make custom backgrounds for people but you can always compile the code yourself and add you own. The new bitmaps are here: https://github.com/dzo/mrz99/tree/master/updated They need to be 16 bit old style windows bmps, Gimp can make these but it produces an incompatible bmp header so you need to run fixbmpheader on them. Easiest way to compile and run the code is on a Linux box. Quote Link to post Share on other sites
dzo Posted February 8, 2017 Report Share Posted February 8, 2017 thanks. it works now. see attached. i dont know if it was supposed to show text instead of dots though2017-02-08 13.24.30.jpg That should be the only screen which is wrong, mrz77 has a few extra strings. Quote Link to post Share on other sites
thohidulk Posted February 9, 2017 Report Share Posted February 9, 2017 Hi Dzo Today i tried mrz99 one, after installation it has shown done but unfortunately nothing has changed. Could u plz tell what is the reason? i have used #52 file. Waiting for you update. Quote Link to post Share on other sites
dzo Posted February 9, 2017 Report Share Posted February 9, 2017 Hi Dzo Today i tried mrz99 one, after installation it has shown done but unfortunately nothing has changed. Could u plz tell what is the reason? i have used #52 file. Waiting for you update. Use the zip from post 59. The latest zip will always be here: https://github.com/dzo/mrz99/releases Quote Link to post Share on other sites
slavjn Posted February 9, 2017 Report Share Posted February 9, 2017 I don't have time to make custom backgrounds for people but you can always compile the code yourself and add you own. The new bitmaps are here: https://github.com/dzo/mrz99/tree/master/updated They need to be 16 bit old style windows bmps, Gimp can make these but it produces an incompatible bmp header so you need to run fixbmpheader on them. Easiest way to compile and run the code is on a Linux box. thanks DZO but I'm not good with computer programs does not work Quote Link to post Share on other sites
slavjn Posted February 9, 2017 Report Share Posted February 9, 2017 ÑпаÑибо DZO, но Ñ Ð½Ðµ очень хорошо Ñ ÐºÐ¾Ð¼Ð¿ÑŒÑŽÑ‚ÐµÑ€Ð½Ñ‹Ð¼Ð¸ программами не работает please can make Quote Link to post Share on other sites
