Long Wire Posted February 9, 2017 Report Share Posted February 9, 2017 Hello, dzo. May be can try to use Condi's Hakmode ? http://avic411.com/index.php?/topic/31534-condis-hackmode-v22-autoinstall-working-also-with-f40bt-x940bt-etc-updated-27092012/&do=findComment&comment=231184 Idea - change PLT files to Europe and convert MRZ to Z-series. In the standard trestmode, change PLT is impossible. Quote Link to post Share on other sites
camzely Posted February 9, 2017 Report Share Posted February 9, 2017 Hey Dzo,  What if I accidentally deleted the LANGDATA file  for the MRZ99? Can the zip that you gave me still work?   Camz Quote Link to post Share on other sites
dzo Posted February 10, 2017 Report Share Posted February 10, 2017 Hey Dzo,  What if I accidentally deleted the LANGDATA file  for the MRZ99? Can the zip that you gave me still work?   Camz  Yes, if you just deleted  PF090JPJPN.LNG the zip will fix it. If you deleted more than that you will need a backup or you can copy the files from the other tree (/USER/PRG0 or /USER/PRG1 depending on the presence of  /USER/PRG.FLG) Quote Link to post Share on other sites
krasi11 Posted February 10, 2017 Report Share Posted February 10, 2017 Hallo, this is my original files from MRZ77 ,only NDB folder missing becouse is very big,and receives an error copying. Â Â https://drive.google.com/file/d/0Bx83DtU5ozo4cEhoSWpZRGtIZDQ/view?usp=sharing Quote Link to post Share on other sites
thohidulk Posted February 11, 2017 Report Share Posted February 11, 2017 Hi Dzo I have installed your language installer, now it is working perfectly and easy to operate & navigate my Avic Drz99. Â Btw i have one more query that is how can change or install local GPRS map in my Drz99. Because every now and then Japanese version Map activate automatically and shows some directions. Though i am driving this SUV at Bangladesh not in Japan. Â Will be appreciate your further help to mitigate or resolve this issue. Â Thanks in advance and very grateful for previous help. Â Regards Karim Quote Link to post Share on other sites
dzo Posted February 12, 2017 Report Share Posted February 12, 2017 There must be a setting in maps that's giving you directions, try disabling all the map options in the settings menu. While it may be possible to install non JP maps, I'm not sure how easy it would be and they aren't available for my region (NZ). The Z110BT/F30BT use the same platform but there may be a hardware check somewhere in the boot sequence that means installing firmware from these models would brick your device. I wouldn't do it without being able to boot from other media or JTAG access. Quote Link to post Share on other sites
roohollah Posted February 16, 2017 Report Share Posted February 16, 2017 Hi dzo  Thanks for the great job you've done. I have a Japanese mrz99 and I've tried all versions of your code. The language has changed to English, but not correctly. I mean the words are not in places they has to be. The link is my LNG file and I appreciate it if you could take a look. https://drive.google.com/file/d/0B3DGaykBnhm6N09vcEgyV19nQlE/view?usp=sharing  Cheers Quote Link to post Share on other sites
dzo Posted February 16, 2017 Report Share Posted February 16, 2017 There were are few extra strings in your LNG file. Here's a quick translation that might work.  test.zip  Can you post the version numbers for your mrz99 firmware so others will know if they need this.  Do the images work ok? Quote Link to post Share on other sites
roohollah Posted February 18, 2017 Report Share Posted February 18, 2017 Thanks very much dzo. The test.zip works well. Images are also working. I couldn't find the firmware but the model is 2010. Thanks again for your help Quote Link to post Share on other sites
dlitchmore Posted February 18, 2017 Report Share Posted February 18, 2017 Hi good day everyone, I am unable to paste the new PF090JPJPN.LNG into LANGDATA folder where the old one was. The paste option has been greyed out. Can anyone assist? Thanks! Quote Link to post Share on other sites
dzo Posted February 18, 2017 Report Share Posted February 18, 2017 Thanks very much dzo. The test.zip works well. Images are also working. I couldn't find the firmware but the model is 2010. Thanks again for your help The firware version info is in:   /PRG0/PF090APL.HTM or  /PRG1/PF090APL.HTM  This is mine:  [2009 Navigation Application Release Record]  20140327  17:40:19  Product         : AVICMRZ90  Release File    : APL  Release Version : 3.070200  Release Machine : BUILDL25  Quote Link to post Share on other sites
dzo Posted February 18, 2017 Report Share Posted February 18, 2017 Â Hi good day everyone, I am unable to paste the new PF090JPJPN.LNG into LANGDATA folder where the old one was. The paste option has been greyed out. Can anyone assist? Thanks! Â Â You need to delete the old file then copy and paste. If you have a mrz99 you can just use the installer though (after doing a backup with the file manager). Quote Link to post Share on other sites
Konstant22 Posted February 21, 2017 Report Share Posted February 21, 2017 Hi, everyone. I need some help with repairing the mrz-99. Can anyone make an images of both of boot and program area? Quote Link to post Share on other sites
rob39 Posted February 25, 2017 Report Share Posted February 25, 2017 I am unable to enter testmode. I have an avic-mrz099w. I put the testmode.key file on an sd card and the unit started on the screen it says  CAUTION!  TEST MODE FAILED STARTING  [Turn Off ACC]  I've attached a photo of the screen.  The unit is on my bench and I only have the power cables connected. I don't know what the other connectors are for. I have red & yellow connected to 12v and black to -ve.  Can anyone help me with what I have to do.  Thanks  Robyn Quote Link to post Share on other sites
dzo Posted February 25, 2017 Report Share Posted February 25, 2017 Here is a generic testmode key, it should work on all models.  generic_testmode.zip  The 099 is quite different to the 99 though. It's from 2013 and the fact that the mrz99 testmode key doesn't work means it's probably a different platform version so the translations are unlikely to work.  Before you do anything make sure you make a backup.  If you post a zip of the LANGDATA and MENU folders here I can take a look and see how easy it would be to translate.   Quote Link to post Share on other sites
