  • Replies 973
Posted Images
On 18/11/2017 at 10:21 PM, EnoKt said:
I have Pioneer Carrozzeria AVIC MRZ 09. I simply used the automatic updater by DZO which changed most of the stuff  from Japanese to English. See post # 59 by DZO. Download the zip file unzip into a flash disk (say 4 GB) , plug in the unit and the rest is installed automatically. Restart to see changes.
 I wonder if there is anyone who has managed to set local time in this unit. It always sets itself to Japanese time zone.
I have corrozeria AVIC-MRZ77 is it compatible with aAVIC MRZ 09.
  • 2 weeks later...
MRZ05
I have problem with time as there is no display. I have done the same thing with the video posted but end up with gps problem.
I have problem with bluetooth. Does mrz05 has a built in bluetooth?
I have problem with image. Automatic updater corrects the language but not the image..
Please help..
Here is the pictures of screen..
2 hours ago, Rick Keisi said:
The text in the engineering menu does not change! In my MRZ 05 there is no Bluetooth!
The text in the engineering menu does not change because we only change the lng file which not affect the engineering menu. bluetooth is not standard, it is sold separately. So some cars come with bluetooth, some not. you can check if the bluetooth is physically there?
15 hours ago, CarrozzeriaMRZ05 said:
MRZ05
Please help..
bluetooth, DTV and IPOD are not standard, they are sold separately. So some cars come with bluetooth, some not. you can check if the bluetooth is physically there?
14 hours ago, CarrozzeriaMRZ05 said:
I can not check from behind because i dont know how to remove it. At AV screen there is no bluetooth sign. I have a cable from behind for usb.. Do connecting bluetooth dongle to USB port allow me use phone calls through radio?
Any help about setting time on mrz05?
Mr Ilnur has managed to change time. you can see his posts on page 26. there is also a video from which you can get help. Some others have installed IGO which corrects time but maps do not work, you can try the two methods and report your experience so that others can benefit.
12 hours ago, CarrozzeriaMRZ05 said:
Another experience... Image.img file is not just an image file.. I croped an image to 480 x 272 and converted it to .img format. From test menu I put it in PRG0/APL/MENU.. As a result i get black background and all of the buttons are gone.. I revert back.. So do not try...
Any knowledge to make proper image.img??
If you want to change image, read page 2 to 5 very carefully. Here DZO has changed the image successfully. Some information is also given there on how to do this. You will have to do some hard work to implement your image, but do it and also guide others so that all can benefit from it.
