ArtemKomsa Posted April 26, 2020 Report Share Posted April 26, 2020 Hello everybody! I have a Nissan Leaf 2015 S With radio AVIC-EVZ05 (NOT MRZ) I can’t delete, copy files in Explorer without the correct TESTMODE file Please, if someone has them Please send them to me along with the translation files Also, I could not find the translation files in the radio itself Maybe they can not be seen without a test mode file I do not know Quote Link to post Share on other sites
mihatmev Posted May 5, 2020 Report Share Posted May 5, 2020 (edited) dzo. Hello my dear friend. How did you make the Image.img file on the blue background of the AV menu? I made a starting background using a makever.c, But I don’t know how to make a background. I ask for help. Edited May 5, 2020 by mihatmev Mistake Quote Link to post Share on other sites
EnoKt Posted May 6, 2020 Report Share Posted May 6, 2020 On 3/26/2020 at 6:16 AM, shadrack said: i was able to fix this error thanks alot. On 3/23/2020 at 2:44 PM, shadrack said: Hi DZO you've been of great help feel blessed, was able to translate mrz 09 to English after reading your post, today i have mrz 90 made in Thailand displays NO PROGRAM 7 in Japanese hi can you help on this. Hi, Shadrack I have had the same problem "NO PROGRAM 7" with AVIC MRZ09 for quite long without plausible solution. I would appreciate if you are able to share the way you did fix the error. Quote Link to post Share on other sites
dzo Posted May 8, 2020 Report Share Posted May 8, 2020 On 5/5/2020 at 7:38 PM, mihatmev said: dzo. Hello my dear friend. How did you make the Image.img file on the blue background of the AV menu? I made a starting background using a makever.c, But I don’t know how to make a background. I ask for help. It's not makever you need but extractbmp, run it with "encode" as a parameter and the gzipped bitmaps in a directory named bmp1 along with the uncompressed versions. There's a script in "updated" to zip all the bitmaps. This will all be easiest on a Linux box. I know it's not the easiest to use but I really only made this for myself. Quote Link to post Share on other sites
alxxndr Posted May 10, 2020 Report Share Posted May 10, 2020 On 06.05.2020 at 10:04 PM, EnoKt said: Hi, Shadrack I have had the same problem "NO PROGRAM 7" with AVIC MRZ09 for quite long without plausible solution. I would appreciate if you are able to share the way you did fix the error. Присоединяюсь к запросу. Adding to this request. Will be waiting for news, thanks Quote Link to post Share on other sites
shadrack Posted May 14, 2020 Report Share Posted May 14, 2020 On 27/03/2020 at 7:09 AM, alxxndr said: Good Day. Have a classic problem with an error "NO PROGRAMM 7" on AVIC-MRZ07. Already found out there are no files in USER/. Please help with backup files. Thanks! Hi, here is the link to mrz 07 back up files https://yadi.sk/d/hGnQktfNFBcchw best regards Quote Link to post Share on other sites
shadrack Posted May 14, 2020 Report Share Posted May 14, 2020 On 06/05/2020 at 3:04 PM, EnoKt said: Hi, Shadrack I have had the same problem "NO PROGRAM 7" with AVIC MRZ09 for quite long without plausible solution. I would appreciate if you are able to share the way you did fix the error. https://mega.nz/folder/Wo0mSI6Y#_BiyEnd0RAiGE8eNbKthuQ Quote Link to post Share on other sites
shadrack Posted May 14, 2020 Report Share Posted May 14, 2020 Hi guys, i wanted to know wether i can change mp310 radio from Japanese to English using the mrz 99 update files will appreciate for your response. Quote Link to post Share on other sites
EnoKt Posted May 14, 2020 Report Share Posted May 14, 2020 6 hours ago, shadrack said: https://mega.nz/folder/Wo0mSI6Y#_BiyEnd0RAiGE8eNbKthuQ Many thanks Shadrack for the link to download the backup, which I have done. My real problem with this unit MRZ09 as described in detail(with image ) on Page 47 and 49 is that the unit does not paste any file to USER folder including the backup. Do you or any one here has an idea what to do to enable this backup wake up the unit.? Quote Link to post Share on other sites
EnoKt Posted May 30, 2020 Report Share Posted May 30, 2020 Hi all in this useful forum, I have another unit, Carrozzeria AVIC-HRZ099, that needs translation of menu from Japanese to English. Does anyone here has any idea how to do it? Is there any similarities with MRZ99? Attached is the unit's card. Please help and thanks in advance. Quote Link to post Share on other sites
thepunisher718 Posted June 10, 2020 Report Share Posted June 10, 2020 On 04/01/2020 at 8:57 PM, Kikumu said: Greetings, I have my avic mrz09 displaying the above screen of not loading programs and number 6 at the bottom any help on how to fix it. Regards did you solve the problem please? Quote Link to post Share on other sites
thepunisher718 Posted July 3, 2020 Report Share Posted July 3, 2020 On 26/03/2020 at 7:16 AM, shadrack said: i was able to fix this error thanks alot. how did you fix it please?? i would really appreciate your help. Quote Link to post Share on other sites
fry740 Posted July 7, 2020 Report Share Posted July 7, 2020 All hi. I have AVIC MRZ09 does not display the image on the screen from the reverse camera. The camera is on correctly and serviceable. I found information that for normal operation you need to train a 3D sensor, without this it does not work. Is it possible to replace a file that is responsible for training with a file from another tape backup? Which file is responsible for this? Quote Link to post Share on other sites
Valik_nsk Posted July 7, 2020 Report Share Posted July 7, 2020 On 19.04.2020 at 2:16 AM, Jhony said: hello I have this problem in my avic-mrz09 and I want to copy the backup files and when copying nothing happens, the same thing happens when I try to delete any file from USER it does not delete them .... I would be very grateful for your help Hello! I have the same problem on mrz-06, but the number on bottom "7" Привет всем, аналогичная проблема при запуске. Кто-нибудь нашел решение проблемы? Quote Link to post Share on other sites
Denis22 Posted July 8, 2020 Report Share Posted July 8, 2020 14.05.2020 в 08:48 Шедрак сказал: Привет, вот ссылка на файлы резервных копий mrz 07 https://yadi.sk/d/hGnQktfNFBcchw с наилучшими пожеланиями 21.11.2016 в 10:54 air22 сказал: Hello, is there any recent files for translation from Japanese to English on MRZ-09. The link that you previously threw does not work. Thanks Quote Link to post Share on other sites
