Jet1337x Posted October 8, 2022 Report Share Posted October 8, 2022 GUYS I HAVE FIGURED OUT PIONEER RZ09 TESTMODE.KEY, I HAVE MANAGED TO UNLOCK TECHNICAL MODE ON THIS DEVICE. HERE IS LINK TO THE KEY!!!!! this may work for rz05 I think!! https://mega.nz/folder/Fv5FAAxQ#myf0v8DsHwmo_ZHWNkW65A LET ME KNOW IF THIS WORKS FOR YOU!! Quote Link to post Share on other sites
Jet1337x Posted October 8, 2022 Report Share Posted October 8, 2022 Just now, Jet1337x said: GUYS I HAVE FIGURED OUT PIONEER RZ09 TESTMODE.KEY, I HAVE MANAGED TO UNLOCK TECHNICAL MODE ON THIS DEVICE. HERE IS LINK TO THE KEY!!!!! this may work for rz05 I think!! https://mega.nz/folder/Fv5FAAxQ#myf0v8DsHwmo_ZHWNkW65A LET ME KNOW IF THIS WORKS FOR YOU!! @crash_rider Quote Link to post Share on other sites
Long Wire Posted October 11, 2022 Report Share Posted October 11, 2022 Thank's. TESTMODE.KEY working with RZ99. Quote Link to post Share on other sites
Jet1337x Posted October 17, 2022 Report Share Posted October 17, 2022 Hi everyone, in the link below is a folder will all the different testmode modes. FOR THE MODELS RZ09 AND SIMILAR CCUNITTEST - from what i remember this mode only has two test options. SERVICE - normal without copy and paste function. TECHNICAL - allows copy and paste function along with a bunch of different tests PRODUCT AUTO PRODUCT MANUAL FLEXIBLE - allows you to have your own testmode tests in a file called TESTMENU.ini - i'm not sure on how to actually get the tests into the menu. but maybe i might be able to unlock the internal sd card. im not sure yet. SCRIPT - runs in parallel with ScriptExec.ini. still trying to figure out what the DIRECT mode is. but here is the link below. have fun and report any discoveries with any one of these keys. **EDIT SCRIPT MODE DOES NOT WORK! https://mega.nz/folder/M6InCDqB#4EC_3QArPVqx4m9UPPJxLQ Quote Link to post Share on other sites
Victo r Posted November 14, 2022 Report Share Posted November 14, 2022 On 5/26/2022 at 5:05 PM, Mikehy55 said: HI ,just joined and very impressed with the quality of questions and answers . Well I'm about to lower the quality . Just purchased a japanese import car which has a Carrozzeria AVIC-HRZ099 head unit . I've tried to understand the protocol , as it is all in japanese ,using Google translate on my smart phone but cannot see how to access the HDD.Any help their will be very much appreciated. Also ,I've downloaded the manuals for this and managed to translate some of the pdf files using Google translate again ,but the main files are greater than 10Mb and google doesn't want to know .tried to split the files (unsuccesful) ,again any suggestion or help will be appreciated . Hope I've posted this in the correct subject , Cheers Hi, any luck with the HRZ 099 one? Can you share translated file? Thanks. Quote Link to post Share on other sites
crash_rider Posted February 3, 2023 Report Share Posted February 3, 2023 2 Jet1337x Thanks bro! I'll check today! it's bad of course that scripts don't work Quote Link to post Share on other sites
crash_rider Posted February 3, 2023 Report Share Posted February 3, 2023 Everything works except scripts copy paste available! thnks! Quote Link to post Share on other sites
amgpuma Posted February 14, 2023 Report Share Posted February 14, 2023 On 2/3/2023 at 12:51 PM, crash_rider said: Everything works except scripts copy paste available! thnks! Nor my SD neitehr my USB are recognized although formatted in FAT32 under windows, any suggestions? Thanks Quote Link to post Share on other sites
Ersh_v Posted February 21, 2023 Report Share Posted February 21, 2023 Скрипт работает Pioneer Carrozzeria RL09 Quote Link to post Share on other sites
Ersh_v Posted February 21, 2023 Report Share Posted February 21, 2023 On 08.10.2022 at 22:44, Jet1337x said: РЕБЯТА Я РАЗБИЛ PIONEER RZ09 TESTMODE.KEY, МНЕ УДАЛОСЬ РАЗБЛОКИРОВАТЬ ТЕХНИЧЕСКИЙ РЕЖИМ НА ЭТОМ УСТРОЙСТВЕ. ВОТ ССЫЛКА НА КЛЮЧ!!!!! это может работать для rz05, я думаю!! https://mega.nz/folder/Fv5FAAxQ#myf0v8DsHwmo_ZHWNkW65A ДАЙТЕ МНЕ ЗНАТЬ, ЕСЛИ ЭТО РАБОТАЕТ ДЛЯ ВАС!! Работает RL09 Quote Link to post Share on other sites
Ersh_v Posted February 21, 2023 Report Share Posted February 21, 2023 On 08.10.2022 at 22:44, Jet1337x said: РЕБЯТА Я РАЗБИЛ PIONEER RZ09 TESTMODE.KEY, МНЕ УДАЛОСЬ РАЗБЛОКИРОВАТЬ ТЕХНИЧЕСКИЙ РЕЖИМ НА ЭТОМ УСТРОЙСТВЕ. ВОТ ССЫЛКА НА КЛЮЧ!!!!! это может работать для rz05, я думаю!! https://mega.nz/folder/Fv5FAAxQ#myf0v8DsHwmo_ZHWNkW65A ДАЙТЕ МНЕ ЗНАТЬ, ЕСЛИ ЭТО РАБОТАЕТ ДЛЯ ВАС!! Works RL09 tell me what files to replace in the firmware to get english Quote Link to post Share on other sites
crash_rider Posted February 22, 2023 Report Share Posted February 22, 2023 2 Ersh_v How did you check? which script was running? Как проверил? какой запускал script? Quote Link to post Share on other sites
crash_rider Posted February 22, 2023 Report Share Posted February 22, 2023 2 amgpuma Try sdcard! Quote Link to post Share on other sites
Ersh_v Posted February 22, 2023 Report Share Posted February 22, 2023 1 hour ago, crash_rider said: 2 Ерш_в Как вы проверяли? какой скрипт работал? Как заразился? какой запускал скрипт? I probably didn’t say correctly))) the copy and paste buttons work Quote Link to post Share on other sites
crash_rider Posted March 6, 2023 Report Share Posted March 6, 2023 del Quote Link to post Share on other sites
