Jump to content
AVIC411.com
crankz
AVIC-MRZ99 Custom Firmware / Testmode
thank you for the quick answer but i thought that it did the zip downloaded from the page made available by Dzo. I will try to manually change those files to see what is happening. thanks
Share this post
Link to post
Share on other sites
Best of luck.
Share this post
Link to post
Pe 02.10.2018 la ora 14:40, Dan45 a spus:
Bună ziua, am introdus manual fișierele puse la dispoziție de Dzo, dar limba nu sa schimbat. Am încercat și cu cele care se actualizează automat, dar tot ce a rămas în limba japoneză a schimbat doar imaginea de fundal. Te rog puțin ajutor, dacă este posibil. Mentionez ca am un mrz avic 06 cred. Manualul meu scrie mrz 02/04 / 06.Thank's.
Share this post
Link to post
If you have changed the files in both prg0 and prg1 folders then language will change. if it does not change, try selecting Japanese from the navigation menu. If it does not help, confirm if the files have actually been replaced, by looking at the date of the files. Best of luck.
Share this post
Link to post
vă mulțumesc pentru răspunsul rapid, dar m-am gândit că a făcut zipul descărcat de pe pagina pusă la dispoziție de Dzo. Voi încercați să schimbați manual aceste fișiere pentru a vedea ce se întâmplă. Multumiri
How to change the language from the navigaton menu
Share this post
Link to post
So, people is it possible to install IGO on any MRZ model? I heard some stories, but id anybody actually ,managed that or any other method to change the map of Japan into any European map?
Share this post
Link to post
Does anyone do me to understand why nothing changes in my avic even if I have replaced the two files? If the original ones are wiped off why is everything in Japanese? How to change the language from the navigation menu if there are only two "DESTINATION" and "LITE" items available there, and the Japanese do not know. Please help a little if you can. Thank you.
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
