fr1s Posted March 10, 2020 Report Share Posted March 10, 2020 Hello Shtirlitz and DZO or more like Privet I bought car from Japan with AVIC-HRZ09 and I managed to pull original files from it. Can you translate it for me? Thank you. I'll try to put Z3 system on it in a mean time. STOCK USER, TFAT and SDATA files, I've reset the unit before pulling the files. https://www.mediafire.com/file/zcuhoxj1qjykyqt/TFAT.rar/file https://www.mediafire.com/file/cirh4u0t0yvankw/USER.rar/file https://www.mediafire.com/file/vniawufnxnq942n/SDATA.rar/file No LDATA rar due to its size Thank guys Quote Link to post Share on other sites
MadLord Posted March 16, 2020 Report Share Posted March 16, 2020 I wrote a program here for convenient (I hope ) editing * .LNG files... - open file from "File - Open *.LNG"- if the text is not clear, then maybe the wrong encoding. Then re-read it in the necessary encoding through "File - Reopen with encoding"- translation can be done in 3 ways:1. manually - just enter the text in the Translate column2. through some thread translators - right-click on a line, there Copy - the original text is copied to the clipboard3. through right-click - "Google Translate 1" and "Google Translate 2". The second method has not tested yet, the first method has a limit on the number of requests - an error may appear after the translation of several lines (they say it’s solved if you wait 10 seconds between requests). Translation languages are selected in the menu (where "ja => en").- you can search for the desired line (even in japanese characters)- you can change the length of the translated text (like everything correctly saves)- can donate (in About)Thank you for helping Long Wire and bellic...based on the developments of DZO (https://github.com/dzo/mrz99)...download here... Quote Link to post Share on other sites
shadrack Posted March 23, 2020 Report Share Posted March 23, 2020 Hi DZO you've been of great help feel blessed, was able to translate mrz 09 to English after reading your post, today i have mrz 90 made in Thailand displays NO PROGRAM 7 in Japanese hi can you help on this. Quote Link to post Share on other sites
zaxaoxa Posted March 24, 2020 Report Share Posted March 24, 2020 Добрый день! Очень интересно заменить логотим заставки при загрузке mrz 05 и задний фон в плеере ! Quote Link to post Share on other sites
zaxaoxa Posted March 24, 2020 Report Share Posted March 24, 2020 знаю что при замене файла Image.img поменялся фон в плеере на этот но как его поменять не знаю b1853.bmp Quote Link to post Share on other sites
DriveNSK Posted March 24, 2020 Report Share Posted March 24, 2020 18 minutes ago, zaxaoxa said: Добрый день! Очень интересно заменить логотим заставки при загрузке mrz 05 и задний фон в плеере ! Попробуй эту инструкцию. У меня получилось (у меня RZ-05). Картинку делай 800х480 (под размер дисплея), название ЗАГЛАВНЫМИ буквами обязательно!! Quote Link to post Share on other sites
zaxaoxa Posted March 24, 2020 Report Share Posted March 24, 2020 4 minutes ago, DriveNSK said: Попробуй эту инструкцию. У меня получилось (у меня RZ-05). Картинку делай 800х480 (под размер дисплея), название ЗАГЛАВНЫМИ буквами обязательно!! спасибо большое но нет этот вариант мне не подходит совсем другое меню на mrz 05 такого нет!!! помню что когда менял язык в папке с переведенными файлами был файл Image.img и после его замены обычный синий фон поменялся на этот b1853.bmp Quote Link to post Share on other sites
dzo Posted March 25, 2020 Report Share Posted March 25, 2020 9 hours ago, zaxaoxa said: thank you very much but no this option does not suit me completely different menu on mrz 05 there is no such !!! I remember that when I changed the language in the folder with the translated files there was a file Image.img and after replacing it, the usual blue background has changed to this This post shows you how to change the splash screen, I've done it on mrz99 and it works fine but you have to know what you are doing and experiment a bit. Quote Link to post Share on other sites
shadrack Posted March 26, 2020 Report Share Posted March 26, 2020 On 23/03/2020 at 2:44 PM, shadrack said: Hi DZO you've been of great help feel blessed, was able to translate mrz 09 to English after reading your post, today i have mrz 90 made in Thailand displays NO PROGRAM 7 in Japanese hi can you help on this. i was able to fix this error thanks alot. Quote Link to post Share on other sites
alxxndr Posted March 27, 2020 Report Share Posted March 27, 2020 Good Day. Have a classic problem with an error "NO PROGRAMM 7" on AVIC-MRZ07. Already found out there are no files in USER/. Please help with backup files. Thanks! Quote Link to post Share on other sites
fr1s Posted March 29, 2020 Report Share Posted March 29, 2020 On 2020-03-15 at 9:53 PM, MadLord said: I wrote a program here for convenient (I hope ) editing * .LNG files... - open file from "File - Open *.LNG"- if the text is not clear, then maybe the wrong encoding. Then re-read it in the necessary encoding through "File - Reopen with encoding"- translation can be done in 3 ways:1. manually - just enter the text in the Translate column2. through some thread translators - right-click on a line, there Copy - the original text is copied to the clipboard3. through right-click - "Google Translate 1" and "Google Translate 2". The second method has not tested yet, the first method has a limit on the number of requests - an error may appear after the translation of several lines (they say it’s solved if you wait 10 seconds between requests). Translation languages are selected in the menu (where "ja => en").- you can search for the desired line (even in japanese characters)- you can change the length of the translated text (like everything correctly saves)- can donate (in About)Thank you for helping Long Wire and bellic...based on the developments of DZO (https://github.com/dzo/mrz99)...download here... Hello, I've tried this.. but i cant seem to locate the translation files. or they're different format. Help Please Quote Link to post Share on other sites
Rova Posted April 2, 2020 Report Share Posted April 2, 2020 On 03.09.2019 at 19:54, DriveNSK said: Само меню выглядит так: У кого-нибудь есть информация? Может, у кого-то есть свалка RZ-33? On 03.09.2019 at 19:52, DriveNSK said: Здравствуйте! Была куплена Carrozerria AVIC RZ-77 Я зашел в инженерное меню (спасибо за информацию на форуме), но ничего не могу сделать - «Копировать» и остальные не активны. (нет TESTMODE.KEY) У кого-нибудь есть? Пожалуйста, поделитесь Сайт пишет, что есть еще похожие модели (AVIC-RZ06-2, AVIC-RZ55, AVIC-RW33, AVIC-RZ33, AVIC-RZ22) Кто-нибудь смог перевести на английский? (Насколько мне известно, RZ-33 переключается из стандартного меню) Кто-нибудь знает, какой у нас европейский аналог этого устройства? Я нашел эту опцию: Переключиться на UC (??) Прикладная инициализация пользовательской области ... После перезагрузки устройства язык не изменился. Я перепробовал все варианты. После применения он сбрасывается до заводских настроек и снова язык японский. Hello! Could you change the language to RZ77? Quote Link to post Share on other sites
Rova Posted April 3, 2020 Report Share Posted April 3, 2020 On 06.09.2019 at 2:43 PM, Shtirlitz said: Hi All! FW backup instruction for AVIC-RZ09 (and similar devices - AVIC-RL09, AVIC-RW09, AVIC-RZ09, AVIC-RZ07, AVIC-RZ06, AVIC-RL05, AVIC-RZ05, AVIC-RW03, AVIC-RZ03): 1. Get SD card, FAT32-formatted. Probably the USB disk will work too, but I didn't check back up on USB. 2. Make the empty folder named "NAVIVUP" on SD card. 3. Power on the AVIC and place the SD card into AVIC device slot. 4. Go to in the Testmode (press and hold "NAVI" button, press each once right-left-right-left-right-left, release "NAVI" button - device restarted in test mode). 5. On the first screen - select menu "10. Program forced write", go to the next screen of this submenu (2 of 3) and select "3. Take out program". 6. Select destination "SD" or "USB" and press "MENU" for start downloading. 7. Wait for about minute while FW downloaded to SD/USD disk - with full-screen messages "!!NOW COPYING!!", while "HIT ANY KEY" message didn't appear. Profit) You can see the full-FW files on your SD/USB disk in the NAVIVUP folder. P.S.: Sorry guys but I cannot upload the screen-shots here, I see just "There was a problem uploading the file." message displayed. Alex Приветствую Штирлиц! имею Avic-rz33.как понял из твоих иснтрукций он похож на твой англофицированный аппарат.хотел по твоему совету вынуть из testmode прошивку,но кнопки КОПИРОВАТЬ ВСТАВИТЬ отсутствуют.SMARTLOOP на мафоне не активен.как быть подскажи пожалуйста!хочу иероглифы переделать,но никак не могу резервную копию снять. Quote Link to post Share on other sites
DriveNSK Posted April 5, 2020 Report Share Posted April 5, 2020 On 03.04.2020 at 3:23 AM, Rova said: Hello! Could you change the language to RZ77? Привет У нас не все так просто, как оказалось. Посмотри этот пост. Исходники можно найти тут.Автор метода есть на этом форуме. Quote Link to post Share on other sites
DriveNSK Posted April 5, 2020 Report Share Posted April 5, 2020 On 03.04.2020 at 2:10 PM, Rova said: Приветствую Штирлиц! имею Avic-rz33.как понял из твоих иснтрукций он похож на твой англофицированный аппарат.хотел по твоему совету вынуть из testmode прошивку,но кнопки КОПИРОВАТЬ ВСТАВИТЬ отсутствуют.SMARTLOOP на мафоне не активен.как быть подскажи пожалуйста!хочу иероглифы переделать,но никак не могу резервную копию снять. У меня тоже SMARTLOOP не работает (у меня RZ77), это, видимо, чисто японская фишка) Она то ли по подписке, то ли по каким то другим условиям, сильно не вникал. Чтобы заработали все кнопки в TESTMODE-режиме, нужен файл TESTMODE.key Копию можно снять без него (но это не точно! (с) ) Посмотри сообщение выше, там есть пост, где Shtitritz расписал мануал по англофикации. Но там нужны навыки программера) Quote Link to post Share on other sites
Join the conversation
