F700BT F710BT F900BT F70BT F90BT 2014 Q1 EU Maps
  • Replies 167
Posted Images
Ok after another day in the car  :-P  I'm nearly there and it's looking good.
But after a few min's the system startup came on and it went back to the blue screen switching on and off between the two  I thought this was just updating so I left it for an hour and a half and still no change, I had to turn off the car then as I was getting low on fuel :?  should I leave it run longer tomorrow or is this a problem. Thanks again hopefully I can leave you alone soon.
hi take this link  is 2  different voices in uk  put them in a sd card with testmode and copy them inside your flash disk open apl2 and igo content and the folder voices and copy inside
after this take this link and copy them inside your avic with testmode  open apl2 and after igo and content and lang and copy inside
i use only french voice it's the reason for the avic don't have the files
