JeroenG Posted June 12, 2015 Report Share Posted June 12, 2015 Geen originele, gekocht via ebay... Win ce geupdatet alvorens de kaart te installeren... Quote Link to post Share on other sites
proppie Posted June 12, 2015 Report Share Posted June 12, 2015 Dus wince geupdate en daarna reboot in testmode en via total commander alles in de juiste directory gekopierd? Unit zit nu in bootloop? Quote Link to post Share on other sites
JeroenG Posted June 12, 2015 Report Share Posted June 12, 2015 Wince geupdatet en instructies gevolgd, en blijft rebooten... Quote Link to post Share on other sites
proppie Posted June 13, 2015 Report Share Posted June 13, 2015 Hmmz gaat iets niet helemaal goed... Heb je backup gemaskt voor upgrade? Die dan maar terug zetten. Zo niet, dan moet je even op zoek naar hybrid 4.0. Die werkt hier prima Quote Link to post Share on other sites
JeroenB Posted June 15, 2015 Report Share Posted June 15, 2015 Hi all, I recently bought a 2010 car and following the various topics I successfully flashed the built in AVIC-F910BT using the hybrid 4.0 update. The unit is marginally quicker now but the best improvement is the removal of the disclaimer screen; also a nice touch is the ability to go into the WinCE tools straight via the Debug tools that are on the page that used to show the version numbers.These 2014 maps are running beautifully and are again completely up to date, a very welcome update from the 2009 maps that were in. Since I had to choose the languages again, I decided to opt for the TTS voice now, which gives very detailed instructions. All in all very pleased with it! Quote Link to post Share on other sites
buki Posted July 5, 2015 Report Share Posted July 5, 2015 any help for beginers ??? i have f 920 are this maps compatible for it ? Quote Link to post Share on other sites
hc97mg2000 Posted July 15, 2015 Report Share Posted July 15, 2015 new link for only european map,poi,buildings enjoy https://drive.google.com/file/d/0B4MAukIOceEXY3JyQUplZ0FIcXM/view?usp=sharing Hi the link to ezrider patched and licence https://drive.google.com/file/d/0B4MAukIOceEXTnlMb3ZpOWwwRVU/view?usp=sharing https://drive.google.com/file/d/0B4MAukIOceEXN1hSTENLUlRfSkE/view?usp=sharing Hi All Im looking to update my maps on my F700BT. I have downloaded the files from the above posts. I believe I need to just overwrite the Folders to right place (APL2>IGO>CONTENT... then MAPS, POIs BUILDINGS. Then I need to overwrite the EZRIDER file with the one from the above post and overwrite the LICENCE with the one on the above post. Could someone please tell me if thats correct and im not missing anything. Some people from post said it did not work? Also does the UK Post code work on these maps? Quote Link to post Share on other sites
seneka1 Posted July 16, 2015 Report Share Posted July 16, 2015 Hi all,Is there a way to get access to the WIN CE on my F70DAB european model? I want to update my maps and speedcam, but it has not been possible to get access to the system for me till now. Quote Link to post Share on other sites
Neodark84 Posted July 18, 2015 Report Share Posted July 18, 2015 Hi.. its files named wince.. total commander.. work inserting in CD or DVD??? i've not SD slot.. in my pioneer.. (Avic hrz009g) Thanks!! Quote Link to post Share on other sites
pacomasi Posted July 26, 2015 Report Share Posted July 26, 2015 hi some firmwre AVIC F910BT Bluetooth to run on Samsung S5 thanks Quote Link to post Share on other sites
adelhaid_13 Posted August 2, 2015 Report Share Posted August 2, 2015 Hi all , sry. but my english is very bad.will it works on my F920BT ? and with GPS ??? THX Quote Link to post Share on other sites
Lez78 Posted August 3, 2015 Report Share Posted August 3, 2015 Hi! After spending 2 days in my car the Navigation is now working! I have tried everything possible but after installing a newer firmware v.3.021 and installing the "My Flashdisk" files from Guizmo my F900BT was back to life. But i don't like the red customized layout (sorry Guizmo) so i put the original directories back to the flashdisk (APL, APL2, APL3, USER, DATA, etc. After this i copied the new MAP, POI, BUILDÃNG and ezrider to the flashdisk and voilá my system is working with the new 2014 maps! Thanks for helping me Guizmo. Hi! do you have a copy of yours , what you can share? Thanks! Quote Link to post Share on other sites
dark_angel_tgv Posted August 3, 2015 Report Share Posted August 3, 2015 just updated my maps tanks to you,Guizmo!tank you so much!!! Quote Link to post Share on other sites
khris_leon Posted August 8, 2015 Report Share Posted August 8, 2015 it 's work with your version so your avic be slow to use upgrade him in version 3 first don't buy any cnsd fm version it's losing money for nothing do this upgrade before https://drive.google.com/file/d/0B4MAukIOceEXbTFCZURPRWR1ZFU/view?usp=sharing take this folder decompress him take inside the folder nammed plt and do this 1)put the 2 winces inside a sd card do this after you put sd card inside your avic with your fingers press 3 touch (menu,map,eject) in the same time and with stylet press reset you 'll have a black screen retire stylet of reset you'll have a blue screen take off your fingers 2)avic try a code do this with joystick (up,up,down,press menu,left,right) and press in center of joystick to valid 3) you'll be in menu of wince select 0 and upgrade with sd card (no format) the avic read your sd card and you'll be upgrade your avic 4) in the folder nammed lpue080 you have a files (4) lpue080apl , lpue080apl.ver , lpue080data ,lpue080data.ver copy them inside your flash disk replace your older files and the folder nammed apl replace your older apl all things with total commander and upgrade your map,and all Hi, I'm from Spain, I tried this on my f900bt v.2009000. But when I update wince, at system startup the message"System startup, please wait" appears and then restart at 5minutes aproximalty. Then I tried copy all files to all folder APL, ezrider, license, and the system does not boot, always restarts (bootloop) What happened? I put my backup and f900 it's ok. Thanks Quote Link to post Share on other sites
x882001 Posted August 15, 2015 Report Share Posted August 15, 2015 Just downloaded 2015 Q3 IGO 83 maps europe. How do I get these working on my cracked F900BT with 2014.Q3 maps ? I tried to put the Dutch map alongside the old one but I cannot select the new map. Do I have to rename them ? Quote Link to post Share on other sites
Join the conversation
