Jump to content
AVIC411.com
F700BT F710BT F900BT F70BT F90BT 2014 Q1 EU Maps
@guizmo
Thank you very very much!
At post #23 you are saying:
 "4) in the folder nammed lpue080 you have a files (4) lpue080apl , lpue080apl.ver , lpue080data ,lpue080data.ver "
...but in the folder lpue080 from your link I have LPUE080APL.HTM , LPUE080APL.VER , LPUE080PLT.HTM, LPUE080PLT.VER.
Last two files (in red) have different names.
I didn't checked the files inside the AVIC until now...but I feel something is wrong here.
Can you make this more clear?
Thanks again!
Link to post
Share on other sites
  • Replies 167
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Renamed maps didn't work. My device is hanging on start up.
Things i already tried:
 * new ezrider + license
 * renamed maps
 * just 1 map
So finally i had to put back Guizmo backup ;  Now it seems to be working. Just not my language :(
So now i still need dutch language files ...
Link to post
https://drive.google.com/file/d/0B4MAukIOceEXT2NoZmJWSEhoN2M/view?usp=sharing
folder of lang decompress him and instal  the entire folder inside your flash disk and do the same for voice
https://drive.google.com/file/d/0B4MAukIOceEXRXU0YUt2TnVYLTQ/view?usp=sharing
put the 2 folders inside a sd card with next testmode and with total commander open storage card and your flash disk and open in your flash disk apl2 and igo and content and copy 2 folders to replace the folders inside your flash disk
Link to post
  • 2 weeks later...
OK...I did it. It worked!
With Guizmo backup but it worked. Now I have maps.
Thank you Guizmo!
Can you tell me how can I revert to to the original IGO interface for AVIC?
I mean without 3d car and the fancy menu over the map and other stuff?
I think in the ordinary IGO for pda and smartphone it's called scheme...
How can I change to original Pioneer scheme?
Regards!
Link to post
Hi!
Trying to update to update my EW 2.009 unit I found out the following:
- applying the WinCE update and copying only the APL Folder and the four version files as in post #23 leads to permanent restarts and I doubt this is related to the missing lpue080data mentioned by comandante in post #121.
- using guizmos's backup instead and adding ezrider, (license,) map, poi and building as in #109 and #124 with his latest lang and voice uploads fixes the unit.
- however even with replaced APL and APL2\iGo\CONTENT\SCHEME some things have red buttons and french text. Moreover, speedcam warning controls do not work.
- unfortunately the Settings are often lost on reboot (e.g. the language is often reset to UK and the Illumination to blue), indifferent what was set up.
@guizmo: Merci beaucoup! Could you please answer post  #121 and please explain why you use a different wince than the one in your lpue080 upload?
Therefore I am looking for untouched 3.xx backups or original upgrade data for V2 Units to put together a clean Version. Can anyone help?
Thanks&Regards
Peter
Link to post
  • 3 weeks later...
Hi!
Thanks&Regards
Peter
+1, would love to have an original backup of v2 or v3
Link to post
Hello
I read all the post, i think that this is that i will can do to put the european maps in a Avic X710BT (American), but im not sure if this is the procedure (Correct me if i do something wrong plz).
I download the next 4 files:
Ezrider4001000_patched-SU_MB.rar
license.zip
map,poi,building 2014.zip
testmode.zip
First, i will copy testmode in sd card, later put it in the avic, turn on, and do a backup, and copy this backup in mi computer (In case something is wrong)
Later i delete US Maps and copy this 4 files decompressed in the sd card, and copy to avic
I will try, but if i do something wrong, i would be gratefoul for your help.
The version of maps in the avic is: 02.000400
Version of avic: 3.0300000 (I think that the testmode i download is the correct)
Thx
Link to post
  • 2 weeks later...
Hello Dears, my name is Vova, i from Georgia-Caucasus , please help me!!
i have Avic-MRZ088, on the Japan language , can you give me link with a Russian language Firmware , i know how it is need install firmware .
i have installed this one, from here
http://honda-fit.ru/forums/honda-fit-Proshivka-magnitoly-Carrozzeria-Avic--MRZ088-t39142
after  STEP 2, i Update Windows Se, my Pioneer will not boot, i see only Black screen
please help me. thanks in advance
Link to post
  • 2 weeks later...
Hi
I am a new here, my english isn't perfect!
I bought a car with a pioneer system F900BT, which is never updatet!
So I bought an sd card by the internet, but it didn't work! It start up, and keep saying "System start in progress, please wait"...
So can anyone help me how I can update my navigation (firmware and maps), or which files I need? I'am not very good with computers!
I'am using the dutch version...
Thx
Jeroen
Link to post
Guizmo, im currently running newest igo maps. But i resly dont like them... For every turn there are 4 instructions...
In 900mtr go left
In 600mtr go left
In 300mtr go left
Go left here
Driving me insane :/
Would using tomtom or garmin have other result? Easy to install?
Im running the 4.xxhybrid firmware
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
