kbrandsma Posted November 8, 2014 Report Share Posted November 8, 2014 Hello, I'm new to the forum as a registered member but have used the site before and have been appreciative of the great stuff here. I recently swapped out my battery and on reinstallation my AVIC-Z140BH showed my custom Splash Screen and then immediately displays "No Applicable Program". I downloaded testmode on a SD Card and was able to check the USER Directory and there was no PRG0 or PRG1 subfolder. How do I reinstall these files? Thanks in advance? KBrandsma Here is the error message Here is the Root Directrory of My AVIC Here is the USER sub-folder Quote Link to post Share on other sites
kbrandsma Posted November 9, 2014 Author Report Share Posted November 9, 2014 Would updating the firmware take care of the missing PRG0 and PRG1 folders and the files inside them? Quote Link to post Share on other sites
kbrandsma Posted November 11, 2014 Author Report Share Posted November 11, 2014 Or by updating the firmware cause damage that can't be undone? Anyone? Quote Link to post Share on other sites
Alexei Navalny Posted November 11, 2014 Report Share Posted November 11, 2014 It's worth a shot. I don't know how you could make it worse. But I wouldn't be surprised if it doesn't work. To me it sounds like a hardware problem. Something wiped-out those files/folders. Who knows what else got clobbered. If it were a computer connected to the internet, I'd suspect a malicious virus - but that's not possible here. Are you sure you didn't attempt any hacks or installing Condi's crap? Quote Link to post Share on other sites
Alexei Navalny Posted November 11, 2014 Report Share Posted November 11, 2014 Another thought - before you try something that might be destructive. If you haven't already - try a hard reset by disconnecting the battery for 30 seconds. That sometimes fixes weird glitches. Quote Link to post Share on other sites
kbrandsma Posted November 12, 2014 Author Report Share Posted November 12, 2014 The HU is stock and very vanilla, no hacks whatsoever. I've tried the hard reset and left the battery disconnected over night at least a couple of times. Any suggestions would be appreciated. Quote Link to post Share on other sites
kbrandsma Posted November 12, 2014 Author Report Share Posted November 12, 2014 I tried doing the Firmware update and got an error message and then the installation stopped and exited the install process. See below? Any help? http://youtu.be/8KSFI9MEnfE Quote Link to post Share on other sites
Alexei Navalny Posted November 12, 2014 Report Share Posted November 12, 2014 I don't know enough about the internal file system to offer intelligent technical advice. I seem to remember that /USER is on a separate physical device (NAND) and is mounted under the root file system - like with Linux. I assume PRG0 and PRG1 are just directories on the USER NAND. I also just took a look at my a backup SD with my /USER files and I see you are missing more than PRG0 and PRG1. Besides SYSTEM, I also have RW and SETUP directories. However, those may be recreated as part of the update installation. Also, there are lots of subdirectories in /USER/SYSTEM. Some of them may be missing on your unit. My only thought is to see if the failure is cause by the fact that neither PRG0 or PRG1 directories are present. So - try running testmode and manually creating them in /USER. I noticed in your video that there was lots of activity reading the SD before it errored. Maybe it was at the point where it was trying to load files in the missing directories. Update: I played with testmode for a while - that are many other diagnostic functions besides file maintenance. There is also a way to examine error logs. BTW, in testmode main menu, use the < > arrows to see several more pages of diagnostic tests. One of test is a NAND test. Use care with this - it can be destructive. But you can do a read test of the sectors of the USER NAND. It takes a while - don't run down your car's battery - Porsches are a pain if the battery get's too low and you can't open the front trunk to get to it (ask me how I know). Other useful diagnostics might be Forced Write and Drive Maintenance. I'm not about to play with these powerful - yet dangerous functions on my good head unit. However you might not have much to loose. Just back up USER first. If all else fails, send in your unit for service. It might be as simple as re-imagining all the firmware. Quote Link to post Share on other sites
kbrandsma Posted November 14, 2014 Author Report Share Posted November 14, 2014 Went to paste PRG0 and PRG1 to the HU Users directory and the previous failed firmware update created a PRG1 folder and placed several files and directories in it. I pasted the directory PRG0 and re-ran the update and again got the same install error message. Should I try creating other directories that I am missing on the root directory? Where can I get a list of directories that should be on the X140BH? Thanks in advance, I really appreciate your help. KBrandsma Quote Link to post Share on other sites
Alexei Navalny Posted November 14, 2014 Report Share Posted November 14, 2014 Went to paste PRG0 and PRG1 to the HU Users directory and the previous failed firmware update created a PRG1 folder and placed several files and directories in it. I pasted the directory PRG0 and re-ran the update and again got the same install error message. Should I try creating other directories that I am missing on the root directory? Where can I get a list of directories that should be on the X140BH? Thanks in advance, I really appreciate your help. KBrandsma I created a back-up of /USER before installing 2013 upgrade. Here is the link (also have some Service Manuals): https://drive.google.com/open?id=0B7hT_tiaAzG2a29uUTZab2YtQTg&authuser=0 Quote Link to post Share on other sites
kbrandsma Posted November 14, 2014 Author Report Share Posted November 14, 2014 Got it. Thanks a lot, I will give it a try! KBRANDSMA Quote Link to post Share on other sites
Travolta Posted November 15, 2014 Report Share Posted November 15, 2014 I created a back-up of /USER before installing 2013 upgrade. Here is the link (also have some Service Manuals): https://drive.google.com/open?id=0B7hT_tiaAzG2a29uUTZab2YtQTg&authuser=0 Can you please make a backup of your User folder after the update. I had the same issue like kbrandsma but now my system reboots while it shows firmware 4.00 and I had already 5.10 (2013) on it. It will be great if you can help me with it. Regards Quote Link to post Share on other sites
Alexei Navalny Posted November 15, 2014 Report Share Posted November 15, 2014 Not gonna happen any time soon. Besides, there's several other things to try before getting that drastic. That's a hail mary when you've got nothing to loose. I'm assuming 2013 (v5.0) installed OK and worked correctly before your problem started. Did you install any other updates (5.x)? So what happened immediately before the problem started? Did you attempt any hacks? BTW, did you try to install Condi's Hackmode? That sounds like a symptom of that mess. Try this: - Boot into testmode. See if a file called /USER/PRG.FLG (its an empty file). If it doesn't create one and copy it there. If it does exist, delete it. This tells the unit to try loading program files from the other alternate directory. If it doesn't exist, PRG0 files are loaded. If it exists, PRG1 files are loaded. - If that doesn't work - put PRG.FLG back the way you found it (either add or remove PRG.FLG) and try re-installing 5.0 from SD. Quote Link to post Share on other sites
Travolta Posted November 15, 2014 Report Share Posted November 15, 2014 Did you install any other updates (5.x)? Yes, I tried to install Pioneerus on my device and that was the biggest mistake I did. The device won't boot after that. I've tried to remove PRG.FLG and restarted the machine, it begann to update the firmware and the same thing.... I'll try to recreate and flash the newest firmware 5.0 or 5.10. I'm trying to install 2013 Maps, but no luck... It won't start from the SD.. Regards Quote Link to post Share on other sites
Travolta Posted November 16, 2014 Report Share Posted November 16, 2014 I just would like to thank you and tell you, my device is working now. I disconnected the Battery Cable and plugged back. That was the problem, now everything is working as before. Regards Quote Link to post Share on other sites
