JasonH Posted April 2, 2007 Report Share Posted April 2, 2007 "Necro" created a great Flash Tutorial for bypassing the D3. It's located here: http://www.avic411.com/D3Bypass Thanks Necro! Quote Link to post Share on other sites
necro Posted April 2, 2007 Report Share Posted April 2, 2007 Thanks for hosting it Jason. If anyone finds this tutorial helpful, please use my referral code: pe7ar-538s2-w5387 The last part of the gallery shows the Parking Brake wire and the Ground wire. You can use the wire tap that is already on the parking brake wire to tap into the ground wire shown. You could also use a tap to connect the Mute wire to the ground wire. I have confirmed this and you only have to use that one wire to ground. I tapped into the ground on the wiring harness in case I ever need to change the other harness (if I get that new truck I'm eyeing). Quote Link to post Share on other sites
coocho Posted April 3, 2007 Report Share Posted April 3, 2007 tightness. Do one for the Z2 now Quote Link to post Share on other sites
HUSKRFJ Posted April 3, 2007 Report Share Posted April 3, 2007 When placing the mute wire in the new slot. Does it have to be pushed all the way in til it clicks? I am having a heck of a time getting it in there. Quote Link to post Share on other sites
necro Posted April 3, 2007 Report Share Posted April 3, 2007 The pin on the mute wire has a flat side and a side that has a gap in it. The gap goes on the inside and the flat side goes towards the outside (where the plastic clip is). Take a look at the pictures again to see what I mean. Push the mute wire in all the way, then try and pull it out. If it comes out, it's not in all the way. Quote Link to post Share on other sites
elchorizon Posted April 6, 2007 Report Share Posted April 6, 2007 Nice tutorial, made it a breeze and work like a charm..Thanks Quote Link to post Share on other sites
MisFit Posted April 6, 2007 Report Share Posted April 6, 2007 great idea, i hope people find this and stop asking the same question over and over again Quote Link to post Share on other sites
cntrylvr79 Posted April 6, 2007 Report Share Posted April 6, 2007 I just did the bypass for my d3 and the video stops after 15 mph what did I do wrong? Quote Link to post Share on other sites
coocho Posted April 7, 2007 Report Share Posted April 7, 2007 I just did the bypass for my d3 and the video stops after 15 mph what did I do wrong? you didnt listen to cntrylvr79 Quote Link to post Share on other sites
sinisterskube Posted June 4, 2007 Report Share Posted June 4, 2007 sweet Quote Link to post Share on other sites
YoungDru Posted June 5, 2007 Report Share Posted June 5, 2007 I envy you guys, ya'll got alot of time on your hands, not bad though. Quote Link to post Share on other sites
necro Posted June 5, 2007 Report Share Posted June 5, 2007 ^^^ Ha! That took me a total of 20 minutes to make. Don't knock what you don't understand. Quote Link to post Share on other sites
eddie_k_ Posted June 9, 2007 Report Share Posted June 9, 2007 Awesome! Necro you are a prince amogst men! Quote Link to post Share on other sites
necro Posted July 2, 2007 Report Share Posted July 2, 2007 There is a confirmation screen that comes up everytime the NAV is loaded so that is normal. Quote Link to post Share on other sites
