rocky2985 Posted June 11, 2006 Report Share Posted June 11, 2006 Hey guys, i just installed my unit like a few days ago and when i drive it shows the arrow part of it like oppositly. It thinks i am reversing or something. Is it how the sensor is put? Where is the best place to but it. I have it on the back dash, should i mount it on the front dash? Any ideas and answer help Thanks in advance Quote Link to post Share on other sites
ducatiboy Posted June 11, 2006 Report Share Posted June 11, 2006 [quote name="rocky2985"]Hey guys, i just installed my unit like a few days ago and when i drive it shows the arrow part of it like oppositly. It thinks i am reversing or something. Is it how the sensor is put? Where is the best place to but it. I have it on the back dash, should i mount it on the front dash? Any ideas and answer help Thanks in advance[/quote] Rotate the GPS antenna 180 degrees. I think it's getting confused. No just kidding, don't do that. I think that the only way the arrow will point a different way than what you are traveling is that you have your reverse light sense hooked up and in the head unit it's programmed backwards. The head unit is smart enough to program it to see 12V as "reverse" or Ground as "reverse". My guess is that you have the sense wire connected (or not I guess) and that is programmed backwards. For the life of me I can't find it in the book. And it's cold outside right now and I just got up so I don't want to walk out to the truck. But look around in the settings for "low" or "high" being the signal for backing up. I would guess yours is backwards. Or if you didn't set it, just cange it to the otherway. Quote Link to post Share on other sites
ducatiboy Posted June 11, 2006 Report Share Posted June 11, 2006 Oh, found it, page 154 in the operation manual. System settings, then Camera Input. Look for the polarity section. If that's set up backwards it might thing you are going backwards all the time. If you have no backup camera, it might let you go "backwards" in the GPS but if you had a camera hooked up, it might be showing you what's behind you all the time. If that's not it, then I got nothing. It sounds very weird. Quote Link to post Share on other sites
edrock200 Posted June 12, 2006 Report Share Posted June 12, 2006 I've seen one other case of this, but not with a new unit. A user switched his unit from one car to another and in doing so the orientation of the unit changed slightly. In those cases you have to hard reset the unit and clear all 3d data. Quote Link to post Share on other sites
ImolaVirus Posted June 12, 2006 Report Share Posted June 12, 2006 I had something similar with my D1, but I went from having the VSS hooked up with full 3D, then unhooked the VSS and went back to Hybrid. It was all kinds of confused, so I had to go into the settings and reset it to Hybrid from the 3D setting. Try that. Quote Link to post Share on other sites
gs300ny Posted June 13, 2006 Report Share Posted June 13, 2006 had the same problem simply go to settings - modify corrent location and setup rotate the arrow the way you need -- page 98 Quote Link to post Share on other sites
edrock200 Posted June 13, 2006 Report Share Posted June 13, 2006 [quote name="ImolaVirus"]I had something similar with my D1, but I went from having the VSS hooked up with full 3D, then unhooked the VSS and went back to Hybrid. It was all kinds of confused, so I had to go into the settings and reset it to Hybrid from the 3D setting. Try that.[/quote] Just out of curiosity, why would you unhook VSS? Quote Link to post Share on other sites
lowriderman3 Posted June 14, 2006 Report Share Posted June 14, 2006 Also try to reset the deck, by using the reset button. Quote Link to post Share on other sites
