bryancx94 Posted April 19, 2007 Report Share Posted April 19, 2007 I gotz an avic-D3 When I am stopped it's at 0 then as I accelerate up to about 10mph it hits around 100, as I go faster it goes higher, as high as 400 and the graph is all the way up. If i leave this screen open I eventually get irregualr speed pulse. I already tried resetting my unit, the vehicle dyanmics do not work either i get, function not avaiable, and i have driven about 500 miles. O yes i also get the shop demo screen loading when i turn my car on. I have tried numerous resets. Is this all related to the VSS wire being on the wrong wire? What's the average climb on the speed pulse? Quote Link to post Share on other sites
MisFit Posted April 19, 2007 Report Share Posted April 19, 2007 it varies from car to car, as long as it goes up with acceleration you should be ok Quote Link to post Share on other sites
cntrylvr79 Posted April 19, 2007 Report Share Posted April 19, 2007 year/make/model of the vehicle and where you tapped vss would be helpful. Quote Link to post Share on other sites
kerrys914 Posted April 19, 2007 Report Share Posted April 19, 2007 On an '02 Audi it looks like reading is 1/100 motor RPM. Quote Link to post Share on other sites
bryancx94 Posted April 20, 2007 Author Report Share Posted April 20, 2007 yeah sorry.. 2005 chevy colorado ext cab. I tapped the yellow/black wire on the PCM. There was two of them, i tapped one of them and started getting signal when i accelerated so I assumed this was correct. Quote Link to post Share on other sites
cntrylvr79 Posted April 20, 2007 Report Share Posted April 20, 2007 Try tapping the other one them. Assumption is the mother of all fu&kups Quote Link to post Share on other sites
bryancx94 Posted April 23, 2007 Author Report Share Posted April 23, 2007 Well i switched to the other wire, no dice. I just disconnected it for now. The other really annoying thing is still the DEMO mode screen. After removing the VSS wire, i reset the unit once again. No luck. Anyone know how to correct this? Quote Link to post Share on other sites
Thundermedic Posted May 31, 2007 Report Share Posted May 31, 2007 I'm Getting the same problem on a 2007 Chevy Colorado, Same Demo screen on startup, and on one wire i get very high numbers, the other is nothing... Quote Link to post Share on other sites
