Phlame217 Posted July 10, 2008 Report Share Posted July 10, 2008 Well i have a friend whose an electrical engineering student at my college and he said he pulled the newer iPod touch apart and an iPod classic and the way they're wired vs some of the older is far different and most likly the cause of the noise. Newer touches and others have integrated circuits that overlap the dock circuit and therefore can cause static due to overlapping electromagnetism. The old ipods had the circuits seperated father away and have different resistors which probably helps reduce noise. Quote Link to post Share on other sites
Flipper Posted September 17, 2008 Report Share Posted September 17, 2008 Well i have a friend whose an electrical engineering student at my college and he said he pulled the newer iPod touch apart and an iPod classic and the way they're wired vs some of the older is far different and most likly the cause of the noise. Newer touches and others have integrated circuits that overlap the dock circuit and therefore can cause static due to overlapping electromagnetism. The old ipods had the circuits seperated father away and have different resistors which probably helps reduce noise. Im betting that most people that are having this problem are using 5G etc ipods. (since most people seem to be steering away from the newer ipods due to compatibility issues etc) My ipod classic has never had a problem with any noise. I would bet that the reason that turning off the charge function fixes the problem is probably due to current going into the ipod from the alternator. An old school GL Isolator (like you used to have to use to get the noise out of your old tapedeck/stereo) would probably do the trick. Quote Link to post Share on other sites
jimmy 2 times Posted March 4, 2009 Report Share Posted March 4, 2009 The new pioneer decks, and the Fseries decks have a ferrite on the usb portion of the deck. And both of my d3's, I put a ferrite on the cord and I don't have the noise. Quote Link to post Share on other sites
Ashhong Posted December 29, 2009 Report Share Posted December 29, 2009 has anybody else had success with a ferrite? does it matter where on the cord you put the ferrite? Quote Link to post Share on other sites
VBLUE42 Posted December 29, 2009 Author Report Share Posted December 29, 2009 A ferrite bead never really solved my noise problem. Quote Link to post Share on other sites
Ashhong Posted December 31, 2009 Report Share Posted December 31, 2009 well that sucks. i guess ill have to turn on the light..what a shame. Quote Link to post Share on other sites
codmyster Posted July 11, 2018 Report Share Posted July 11, 2018 On 9/27/2007 at 3:31 PM, wobbit45 said: I am confused on what noise were actually talking about. I know with my D3 and Ipod dealy, i get some distortion on certain songs, but i think that's because of the bitrate the song is on, because other songs dont do that. it may be also of the level of the recording the mp3,wma,cda,etc. was recorded at the level that is a lot people don't understand and jack up the level a bit much and that will clip the preamp signal every time there for its always good to make sure its all flat when your making the recording you can always pre record and set your setting accordingly so your signal is not clip when your volume is on 23 when your HU is able to go to 45,50, etc. hope this helps some what can yall by the way look at mine and answer any one I got f900bt face and can it work on my x920bt. I got them dam zebra stripes then a black screen and the unit is like locked you can eject a the cd/ dvd but nothing else. please look for my post guys thanks. GOD BLESS Codmyster Quote Link to post Share on other sites
Join the conversation
