jimmy Posted April 3, 2007 Report Share Posted April 3, 2007 1999 lexus gs400 Quote Link to post Share on other sites
MisFit Posted April 3, 2007 Report Share Posted April 3, 2007 Speed Sense purple/white power steering ECU The power steering ECU is between the driver kick and the ABS ECU. Quote Link to post Share on other sites
smiledrs Posted April 5, 2007 Report Share Posted April 5, 2007 Can someone help with Acura 2000 TL. VSS and Reverse wire. Thanks Quote Link to post Share on other sites
esb Posted April 5, 2007 Report Share Posted April 5, 2007 Thanks to all of those providing the info people are requesting. It is such a great resource for the community. Now its my turn to ask. I need to find the VSS and reverse wire for a 2004 Honda Odyssey with the factory radio (no nav or RES). Its funny, but nobody seems to be asking for the parking brake wire . Quote Link to post Share on other sites
kennyken22 Posted April 5, 2007 Report Share Posted April 5, 2007 I need vss and reverse wire location for a 2004 Ford Expedition Eddie Bauer. Please Help. Quote Link to post Share on other sites
cntrylvr79 Posted April 6, 2007 Report Share Posted April 6, 2007 04 Odyssey Reverse Light green/black + driver fuse box, 10 pin plug Speed Sense blue/white cruise ctrl unit to right of column 04 Expedition Reverse Light black/pink + driver kick, harness to rear Speed Sense gray/black wiper motor or PCM Notes: The PCM (Powertrain Control Module) is on the passenger side firewall. The VSS wire is in the plug closest to the fender, pin 13. merry xmas Quote Link to post Share on other sites
noreaga0221 Posted April 9, 2007 Report Share Posted April 9, 2007 2002 Mercedes Benz c230 coupe without the bose stereo. Thanks! Quote Link to post Share on other sites
mykal41 Posted April 13, 2007 Report Share Posted April 13, 2007 2006 dodge ram cummins no factory nav. Anyone know where the vss is in this truck. Also a good place for the reverse wire . The dimer wire needs a home too. Quote Link to post Share on other sites
cntrylvr79 Posted April 13, 2007 Report Share Posted April 13, 2007 Get a canbus interface. That'll give you everything you need at the radio. Save you from having to run wire all over the truck. If you're dead set on not using one of those, search the info has been posted. Quote Link to post Share on other sites
mykal41 Posted April 13, 2007 Report Share Posted April 13, 2007 I used the metra xsvi-6502 and it had no provision for the vss or reverse or dimmer. I searched and I cant find any info on the 06 cummins auto tranny. Could you provide a link. Quote Link to post Share on other sites
cntrylvr79 Posted April 14, 2007 Report Share Posted April 14, 2007 http://www.peripheralelectronics.com/pr ... strSearch= Quote Link to post Share on other sites
scrupul0us Posted April 16, 2007 Report Share Posted April 16, 2007 For a mercury cougar 99-02 it is already behind the stock radio... it is in a wiring harness of its own consisting of the VSS wire and a black ground... i just slid the pioneer wire into the female end... worked great! Quote Link to post Share on other sites
ChristopherLCamacho Posted April 18, 2007 Report Share Posted April 18, 2007 2000 Lincoln Ls VSS, cant find it anyway any help would be appreciated Quote Link to post Share on other sites
idbl_fanatic Posted April 18, 2007 Report Share Posted April 18, 2007 2001 Ford Expedition XLT Need VSS, and Reverse Thanks!! Quote Link to post Share on other sites
cntrylvr79 Posted April 18, 2007 Report Share Posted April 18, 2007 01 Expedition Speed Sense gray/black cruise control module Notes: The cruise control module is on the driver side fender. Reverse Black/pink driver's kick. merry xmas Quote Link to post Share on other sites
