westindiesfinest Posted February 27, 2008 Report Share Posted February 27, 2008 the huge gaps you are seeing should be from the old factory radio it had a shape like this (___) there are kits available online or at a local car audio shop that u can buy for a few bucks...the vss however i am not sure... if the pros on here recommend a dif color vss go with that hoever if they dont... if u do see a pick/grey wire back there odds are that yes thats the wire I am adduming u are using a wireharness and all your other wires should be hooked up by now... if you wanted to test it just use the tap supplied to tap into the wire.... then go to the connection status screen in the d3... with your car in park... push on the gas.. if you dont hear any beeps means you didnt tap into a wire that is always supplying 12v or u didnt tap into the tach wire which is good.... then try going in reverse u should hear a few beeps going back and forth a general distance but actually driving would give u a better answer.... the faster you go the more frequent u should hear the beeps... hope this helps Quote Link to post Share on other sites
Join the conversation
