j431dean Posted August 1, 2009 Report Share Posted August 1, 2009 Just applied the update, but now my backup Cam will not work...Any Suggestions???? Thanks again Quote Link to post Share on other sites
garrettoomey Posted August 1, 2009 Report Share Posted August 1, 2009 av settings, set camera to 'on' Quote Link to post Share on other sites
j431dean Posted August 1, 2009 Report Share Posted August 1, 2009 Thanks Just did that and it work. Thanks again Quote Link to post Share on other sites
avsfan Posted October 13, 2009 Report Share Posted October 13, 2009 I have a z2 and I have done the two wire bypass. My unit is upgraded with the pioneer firmware (i had freezing issues). It was professionally installed the first time but installed it myself this time. (was going to return it due to freezing issues) Everything is working great except one thing. My library and any cd's or dvd's i put in dont play sound. I have not downloaded the file for the bypass but it still shows video while im driving. Do i need to put in the cd with those files for the sound to play? If not do you have any possible troubleshooting techniques. Im a rookie at all this. Quote Link to post Share on other sites
garrettoomey Posted October 13, 2009 Report Share Posted October 13, 2009 If video is playing, then you do not need the other update. The sound problem is a wiring issue, and can be tested by changing your auto ANT setting to 'power' per the PM that I replied to last night. Quote Link to post Share on other sites
jdubsky21 Posted May 13, 2010 Report Share Posted May 13, 2010 So if i choose to do method number two, do i still have to do the 2-wire bypass? Or will the download file for method 2 do all of the work? Quote Link to post Share on other sites
garrettoomey Posted May 17, 2010 Report Share Posted May 17, 2010 You will have to do the 2 wire bypass. Quote Link to post Share on other sites
jdubsky21 Posted June 16, 2010 Report Share Posted June 16, 2010 I had my unit professionally installed. If my Parking Brake Wire (Light Green Wire) is attached to another wire, does that mean that it is grounded? Everytime that i turn on my unit it comes up with the warning message talking about my parking brake. Does this mean that it is grounded? If not, what wire can i connect it to in order to ground it? Quote Link to post Share on other sites
dawgbone Posted June 16, 2010 Report Share Posted June 16, 2010 I had my unit professionally installed. If my Parking Brake Wire (Light Green Wire) is attached to another wire, does that mean that it is grounded? Everytime that i turn on my unit it comes up with the warning message talking about my parking brake. Does this mean that it is grounded? If not, what wire can i connect it to in order to ground it? Â Ground it..... doesn't matter how... But to give you a hinter... you can just use a quick splice and tap it into the head unit's ground....i.e... the black wire Quote Link to post Share on other sites
jdubsky21 Posted June 17, 2010 Report Share Posted June 17, 2010 I had my unit professionally installed. If my Parking Brake Wire (Light Green Wire) is attached to another wire, does that mean that it is grounded? Everytime that i turn on my unit it comes up with the warning message talking about my parking brake. Does this mean that it is grounded? If not, what wire can i connect it to in order to ground it?  Ground it..... doesn't matter how... But to give you a hinter... you can just use a quick splice and tap it into the head unit's ground....i.e... the black wire   As of right now, the parking brake wire is spliced to the head units (black wire) ground wire along with the bluetooth ground wire. What could be the problem? Quote Link to post Share on other sites
dawgbone Posted June 17, 2010 Report Share Posted June 17, 2010 I had my unit professionally installed. If my Parking Brake Wire (Light Green Wire) is attached to another wire, does that mean that it is grounded? Everytime that i turn on my unit it comes up with the warning message talking about my parking brake. Does this mean that it is grounded? If not, what wire can i connect it to in order to ground it?  Ground it..... doesn't matter how... But to give you a hinter... you can just use a quick splice and tap it into the head unit's ground....i.e... the black wire   As of right now, the parking brake wire is spliced to the head units (black wire) ground wire along with the bluetooth ground wire. What could be the problem?  You need to ground the other wire as described in this forum...... hence...the "two wire bypass" http://www.sminntech.com/z1flash.html#newbypass Quote Link to post Share on other sites
jdubsky21 Posted June 20, 2010 Report Share Posted June 20, 2010 Okay.. So i did exactly what the directions said in the two wire bypass method. However, there is no change... Â What could be the problem....i checked wire 1 & 2 many times and they are situated properly. Quote Link to post Share on other sites
dawgbone Posted June 20, 2010 Report Share Posted June 20, 2010 What firmware do you have? If you have a very early firmware...then you will need to download the "hacked" firmware update.... The super early Z1 firmware needed the "hacked" firmware.... Â Otherwise... check your grounding... Quote Link to post Share on other sites
jdubsky21 Posted June 20, 2010 Report Share Posted June 20, 2010 My unit is an AVIC Z2 not Z1 Quote Link to post Share on other sites
VBLUE42 Posted June 20, 2010 Report Share Posted June 20, 2010 Make sure you have the latest Z2 update. The first Z2's were unbypassable. Quote Link to post Share on other sites
Join the conversation
