garrettoomey Posted August 18, 2009 Report Share Posted August 18, 2009 Looks like i messed up. I now have a z3 HD in my z1 that was originally bypassed with the ducati device that I purchased through this forum years ago. Now even with my parking break on, I can not plan a route or watch videos. My Jetta GLI and Z3 is now just a music player with a map. what do i do now? You have 2 options. 1) Do the 2 wire bypass for full functionality all the time. 2) Properly connect your parking brake according to the installation manual. You will only have full functionality when the brake is on. Quote Link to post Share on other sites
ajmi982 Posted August 18, 2009 Report Share Posted August 18, 2009 So the ducati bypass is no longer valid at all? If that was the original install method, can the two wire bypass still be done? If so, how long does it take? Where is the best sticky so I can get this done. Garrett, are you local to Laurel/College Park MD? I would be willing to pay for u to do the two wire bypass. Thanks. Quote Link to post Share on other sites
ajmi982 Posted August 18, 2009 Report Share Posted August 18, 2009 Also, now the the HD is Z3 image, the "flashing" bypass no longer works, which means the adapter i purchased no longer works? The only option to have full functionality all the time is to pull out headunit and do 2wire bypass? Quote Link to post Share on other sites
ajmi982 Posted August 18, 2009 Report Share Posted August 18, 2009 Will I have to purchase anything else now?! Quote Link to post Share on other sites
garrettoomey Posted August 18, 2009 Report Share Posted August 18, 2009 So the ducati bypass is no longer valid at all? If that was the original install method, can the two wire bypass still be done? If so, how long does it take? Where is the best sticky so I can get this done. Garrett, are you local to Laurel/College Park MD? I would be willing to pay for u to do the two wire bypass. Thanks. Correct, ducati flasher will no longer work at all. You can remove it, or leave it in. Makes no difference. If you remove it, you will have a cleaner install. I am not local to MD. I live in TX. For instructions for the 2 wire bypass. Go to the Z series hacks forum, and look at the sticky posts at the top. Ducatiboy has a link for the 2 wire bypass. Quote Link to post Share on other sites
garrettoomey Posted August 18, 2009 Report Share Posted August 18, 2009 Also, now the the HD is Z3 image, the "flashing" bypass no longer works, which means the adapter i purchased no longer works? The only option to have full functionality all the time is to pull out headunit and do 2wire bypass? Yes. Here is a direct link to the bypass instructions: http://www.sminntech.com/z1flash.html#newbypass Quote Link to post Share on other sites
garrettoomey Posted August 18, 2009 Report Share Posted August 18, 2009 Will I have to purchase anything else now?! No. Quote Link to post Share on other sites
ajmi982 Posted August 18, 2009 Report Share Posted August 18, 2009 is my light green parking break wire already grounded if i have the ducati curcuit? If so, I only have to ground one more wire? Quote Link to post Share on other sites
garrettoomey Posted August 18, 2009 Report Share Posted August 18, 2009 is my light green parking break wire already grounded if i have the ducati curcuit? If so, I only have to ground one more wire? Chances are that your light green wire is not connected to anything. If it was, the buttons would NOT be greyed out. Quote Link to post Share on other sites
galzamar Posted September 11, 2009 Report Share Posted September 11, 2009 Just downloaded the z3 image last night, The directions say you need to unzip it, it was not zipped? Also I want to to the restore and it said "This is not the first sector of the image" I went and looked in the files that I downloaded with a torrent and I have z3_virgin 2 - 9 z3_virgin 12-14 Does anyone know if it is suposto be like this? Did the torrent miss up downloaded it says that I am done with it. Quote Link to post Share on other sites
galzamar Posted September 11, 2009 Report Share Posted September 11, 2009 ok well I figured it out I did a force recheck on utorrent and it says now that I am only 78% done with it. /sigh I was looking forward to getting the z3 update installed on it. Once I get this thing downloaded I will leave it up to seed for other people, I have it on my work computer that really doesnt get used much so I should have no problem seeding for a while for you all. Can I get some seeders please. There is only 2 seeders and they dont have the same sections that I dont have 1, 10, 11 Thank you in advance Quote Link to post Share on other sites
illjuan3 Posted September 15, 2009 Report Share Posted September 15, 2009 After this update was there a noticiabke speed diff in iPod search or any diff at all in overall operating speed? Quote Link to post Share on other sites
garrettoomey Posted September 15, 2009 Report Share Posted September 15, 2009 After this update was there a noticiabke speed diff in iPod search or any diff at all in overall operating speed? No. Not unless you use a faster hdd, but even then it is only a minor speed difference. Quote Link to post Share on other sites
AFMagnum Posted September 28, 2009 Author Report Share Posted September 28, 2009 Instructions updated for the 2009 map update. Quote Link to post Share on other sites
timsmith93 Posted September 29, 2009 Report Share Posted September 29, 2009 Uploading torrent w/09 maps @ 300K/sec for 2 days, downloading @ 40k a sec... Looks like very few others are uploading? Quote Link to post Share on other sites
